Aug 23 16:48:44 raspberrypi systemd[1]: Started udev Coldplug all Devices.
Aug 23 16:48:44 raspberrypi systemd[1]: Starting Helper to synchronize boot up for ifupdown...
Aug 23 16:48:44 raspberrypi systemd[1]: Started Helper to synchronize boot up for ifupdown.
Aug 23 16:48:44 raspberrypi systemd[1]: Started Remount Root and Kernel File Systems.
Aug 23 16:48:44 raspberrypi systemd[1]: Starting Create System Users...
Aug 23 16:48:44 raspberrypi systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
Aug 23 16:48:44 raspberrypi systemd[1]: Started Create System Users.
Aug 23 16:48:44 raspberrypi systemd[1]: Starting Create Static Device Nodes in /dev...
Aug 23 16:48:44 raspberrypi systemd[1]: Started Create Static Device Nodes in /dev.
Aug 23 16:48:44 raspberrypi systemd[1]: Starting udev Kernel Device Manager...
Aug 23 16:48:44 raspberrypi systemd[1]: Reached target Local File Systems (Pre).
Aug 23 16:48:44 raspberrypi systemd[1]: Started udev Kernel Device Manager.
Aug 23 16:48:44 raspberrypi systemd[1]: Found device SanDisk_3.2Gen1 1.
Aug 23 16:48:44 raspberrypi systemd[1]: Started Uncomplicated firewall.
Aug 23 16:48:44 raspberrypi systemd[1]: var.mount: Directory /var to mount over is not empty, mounting anyway.
Aug 23 16:48:44 raspberrypi systemd[1]: Mounting /var...
Aug 23 16:48:44 raspberrypi systemd[1]: Mounted /var.
Aug 23 16:48:44 raspberrypi mtp-probe: checking bus 1, device 5: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5"
Aug 23 16:48:44 raspberrypi mtp-probe: checking bus 1, device 4: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3"
Aug 23 16:48:44 raspberrypi mtp-probe: checking bus 1, device 3: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1"
Aug 23 16:48:44 raspberrypi mtp-probe: bus: 1, device: 5 was not an MTP device
Aug 23 16:48:44 raspberrypi mtp-probe: bus: 1, device: 4 was not an MTP device
Aug 23 16:48:44 raspberrypi mtp-probe: bus: 1, device: 3 was not an MTP device
Aug 23 16:48:44 raspberrypi systemd-udevd[206]: Using default interface naming scheme 'v240'.
Aug 23 16:48:44 raspberrypi systemd[1]: Found device /dev/disk/by-partuuid/0f0cf00c-01.
Aug 23 16:48:44 raspberrypi systemd-udevd[212]: Using default interface naming scheme 'v240'.
Aug 23 16:48:44 raspberrypi systemd-udevd[211]: Process '/usr/sbin/th-cmd --socket /var/run/thd.socket --passfd --udev' failed with exit code 1.
Aug 23 16:48:44 raspberrypi systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
Aug 23 16:48:44 raspberrypi systemd[1]: Condition check resulted in FUSE Control File System being skipped.
Aug 23 16:48:44 raspberrypi systemd[1]: Condition check resulted in Huge Pages File System being skipped.
Aug 23 16:48:44 raspberrypi systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
Aug 23 16:48:44 raspberrypi systemd[1]: Starting File System Check on /dev/disk/by-partuuid/0f0cf00c-01...
Aug 23 16:48:44 raspberrypi systemd[1]: Starting Load/Save Random Seed...
Aug 23 16:48:44 raspberrypi systemd[1]: Starting Flush Journal to Persistent Storage...
Aug 23 16:48:44 raspberrypi systemd[1]: Starting Load/Save RF Kill Switch Status...
Aug 23 16:48:44 raspberrypi systemd[1]: Started Load/Save Random Seed.
Aug 23 16:48:44 raspberrypi systemd[1]: Started Load/Save RF Kill Switch Status.
Aug 23 16:48:44 raspberrypi systemd[1]: Started Flush Journal to Persistent Storage.
Aug 23 16:48:44 raspberrypi systemd-fsck[375]: fsck.fat 4.1 (2017-01-24)
Aug 23 16:48:44 raspberrypi systemd-fsck[375]: /dev/mmcblk0p1: 276 files, 98343/516190 clusters
Aug 23 16:48:44 raspberrypi systemd[1]: Started File System Check on /dev/disk/by-partuuid/0f0cf00c-01.
Aug 23 16:48:44 raspberrypi systemd[1]: Mounting /boot...
Aug 23 16:48:44 raspberrypi systemd[1]: Mounted /boot.
Aug 23 16:48:44 raspberrypi systemd[1]: Reached target Local File Systems.
Aug 23 16:48:44 raspberrypi systemd[1]: Starting Set console font and keymap...
Aug 23 16:48:44 raspberrypi systemd[1]: Starting netfilter persistent configuration...
Aug 23 16:48:44 raspberrypi systemd[1]: Starting Preprocess NFS configuration...
Aug 23 16:48:44 raspberrypi systemd[1]: Starting Create Volatile Files and Directories...
Aug 23 16:48:44 raspberrypi systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
Aug 23 16:48:44 raspberrypi systemd[1]: Started Set console font and keymap.
Aug 23 16:48:44 raspberrypi systemd[1]: nfs-config.service: Succeeded.
Aug 23 16:48:44 raspberrypi systemd[1]: Started Preprocess NFS configuration.
Aug 23 16:48:44 raspberrypi netfilter-persistent[383]: run-parts: executing /usr/share/netfilter-persistent/plugins.d/15-ip4tables start
Aug 23 16:48:44 raspberrypi systemd[1]: Condition check resulted in RPC security service for NFS client and server being skipped.
Aug 23 16:48:44 raspberrypi systemd[1]: Condition check resulted in RPC security service for NFS server being skipped.
Aug 23 16:48:44 raspberrypi systemd[1]: Reached target NFS client services.
Aug 23 16:48:44 raspberrypi systemd[1]: Reached target Remote File Systems (Pre).
Aug 23 16:48:44 raspberrypi systemd[1]: Reached target Remote File Systems.
Aug 23 16:48:44 raspberrypi netfilter-persistent[383]: run-parts: executing /usr/share/netfilter-persistent/plugins.d/25-ip6tables start
Aug 23 16:48:44 raspberrypi systemd[1]: Started Create Volatile Files and Directories.
Aug 23 16:48:44 raspberrypi systemd[1]: Starting Network Time Synchronization...
Aug 23 16:48:44 raspberrypi systemd[1]: Starting Update UTMP about System Boot/Shutdown...
Aug 23 16:48:44 raspberrypi systemd[1]: Started netfilter persistent configuration.
Aug 23 16:48:44 raspberrypi systemd[1]: Reached target Network (Pre).
Aug 23 16:48:44 raspberrypi systemd[1]: Starting Raise network interfaces...
Aug 23 16:48:44 raspberrypi systemd[1]: Started Update UTMP about System Boot/Shutdown.
Aug 23 16:48:44 raspberrypi systemd[1]: Started Network Time Synchronization.
Aug 23 16:48:44 raspberrypi systemd[1]: Reached target System Initialization.
Aug 23 16:48:44 raspberrypi systemd[1]: Listening on triggerhappy.socket.
Aug 23 16:48:44 raspberrypi systemd[1]: Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
Aug 23 16:48:44 raspberrypi systemd[1]: Listening on D-Bus System Message Bus Socket.
Aug 23 16:48:44 raspberrypi systemd[1]: Reached target Sockets.
Aug 23 16:48:44 raspberrypi systemd[1]: Reached target Basic System.
Aug 23 16:48:44 raspberrypi systemd[1]: Started Manage Sound Card State (restore and store).
Aug 23 16:48:44 raspberrypi systemd[1]: Condition check resulted in Turn on SSH if /boot/ssh is present being skipped.
Aug 23 16:48:44 raspberrypi systemd[1]: Starting Configure Bluetooth Modems connected by UART...
Aug 23 16:48:44 raspberrypi systemd[1]: Condition check resulted in Copy user wpa_supplicant.conf being skipped.
Aug 23 16:48:44 raspberrypi alsactl[448]: alsactl 1.1.8 daemon started
Aug 23 16:48:44 raspberrypi systemd[1]: Starting triggerhappy global hotkey daemon...
Aug 23 16:48:44 raspberrypi systemd[1]: Starting dphys-swapfile - set up, mount/unmount, and delete a swap file...
Aug 23 16:48:44 raspberrypi systemd[1]: Starting Restore /etc/resolv.conf if the system crashed before the ppp link was shut down...
Aug 23 16:48:44 raspberrypi systemd[1]: Started Regular background program processing daemon.
Aug 23 16:48:44 raspberrypi systemd[1]: Starting Login Service...
Aug 23 16:48:44 raspberrypi thd[450]: Found socket passed from systemd
Aug 23 16:48:44 raspberrypi cron[457]: (CRON) INFO (pidfile fd = 3)
Aug 23 16:48:44 raspberrypi systemd[1]: Started D-Bus System Message Bus.
Aug 23 16:48:44 raspberrypi cron[457]: (CRON) INFO (Running @reboot jobs)
Aug 23 16:48:44 raspberrypi systemd[1]: Starting WPA supplicant...
Aug 23 16:48:44 raspberrypi systemd[1]: Starting Check for Raspberry Pi EEPROM updates...
Aug 23 16:48:44 raspberrypi systemd[1]: Starting LSB: Start Motion detection...
Aug 23 16:48:44 raspberrypi systemd[1]: Starting Save/Restore Sound Card State...
Aug 23 16:48:44 raspberrypi systemd[1]: Condition check resulted in getty on tty2-tty6 if dbus and logind are not available being skipped.
Aug 23 16:48:44 raspberrypi systemd[1]: Starting rng-tools.service...
Aug 23 16:48:44 raspberrypi systemd[1]: Starting LSB: Switch to ondemand cpu governor (unless shift key is pressed)...
Aug 23 16:48:44 raspberrypi systemd[1]: Starting Avahi mDNS/DNS-SD Stack...
Aug 23 16:48:44 raspberrypi systemd[1]: Starting System Logging Service...
Aug 23 16:48:44 raspberrypi rng-tools[487]: Starting Hardware RNG entropy gatherer daemon: rngd.
Aug 23 16:48:44 raspberrypi rngd[502]: rngd 2-unofficial-mt.14 starting up...
Aug 23 16:48:44 raspberrypi rpi-eeprom-update[479]: This tool only works with a Raspberry Pi 4
Aug 23 16:48:44 raspberrypi systemd[1]: Starting dhcpcd on all interfaces...
Aug 23 16:48:44 raspberrypi systemd[1]: Started Daily Cleanup of Temporary Directories.
Aug 23 16:48:44 raspberrypi systemd[1]: Reached target System Time Synchronized.
Aug 23 16:48:44 raspberrypi systemd[1]: Started Daily apt download activities.
Aug 23 16:48:44 raspberrypi rngd[502]: entropy feed to the kernel ready
Aug 23 16:48:44 raspberrypi systemd[1]: Started Daily apt upgrade and clean activities.
Aug 23 16:48:44 raspberrypi systemd[1]: Started Daily man-db regeneration.
Aug 23 16:48:44 raspberrypi systemd[1]: Started Daily rotation of log files.
Aug 23 16:48:44 raspberrypi systemd[1]: Reached target Timers.
Aug 23 16:48:44 raspberrypi systemd[1]: Starting LSB: weewx weather system...
Aug 23 16:48:44 raspberrypi btuart[449]: Cannot open directory '/etc/firmware': No such file or directory
Aug 23 16:48:44 raspberrypi btuart[449]: Patch not found, continue anyway
Aug 23 16:48:44 raspberrypi systemd[1]: Started triggerhappy global hotkey daemon.
Aug 23 16:48:44 raspberrypi systemd[1]: Started Raise network interfaces.
Aug 23 16:48:44 raspberrypi systemd[1]: pppd-dns.service: Succeeded.
Aug 23 16:48:44 raspberrypi systemd[1]: Started Restore /etc/resolv.conf if the system crashed before the ppp link was shut down.
Aug 23 16:48:44 raspberrypi systemd[1]: Started Check for Raspberry Pi EEPROM updates.
Aug 23 16:48:44 raspberrypi systemd[1]: Started Save/Restore Sound Card State.
Aug 23 16:48:44 raspberrypi avahi-daemon[495]: Found user 'avahi' (UID 108) and group 'avahi' (GID 113).
Aug 23 16:48:44 raspberrypi avahi-daemon[495]: Successfully dropped root privileges.
Aug 23 16:48:44 raspberrypi avahi-daemon[495]: avahi-daemon 0.7 starting up.
Aug 23 16:48:44 raspberrypi systemd[1]: Started rng-tools.service.
Aug 23 16:48:44 raspberrypi dphys-swapfile[452]: want /var/swap=10000MByte, restricting to config limit: 2048MBytes, checking existing: keeping it
Aug 23 16:48:44 raspberrypi dhcpcd[516]: dev: loaded udev
Aug 23 16:48:44 raspberrypi rsyslogd: imuxsock: Acquired UNIX socket '/run/systemd/journal/syslog' (fd 3) from systemd. [v8.1901.0]
Aug 23 16:48:44 raspberrypi rsyslogd: [origin software="rsyslogd" swVersion="8.1901.0" x-pid="499" x-info="https://www.rsyslog.com"] start
Aug 23 16:48:44 raspberrypi avahi-daemon[495]: Successfully called chroot().
Aug 23 16:48:44 raspberrypi avahi-daemon[495]: Successfully dropped remaining capabilities.
Aug 23 16:48:44 raspberrypi systemd[1]: Started System Logging Service.
Aug 23 16:48:44 raspberrypi avahi-daemon[495]: No service file found in /etc/avahi/services.
Aug 23 16:48:44 raspberrypi kernel: [ 1.950867] FS-Cache: Netfs 'nfs' registered for caching
Aug 23 16:48:44 raspberrypi kernel: [ 1.951793] NFS: Registering the id_resolver key type
Aug 23 16:48:44 raspberrypi kernel: [ 1.951865] Key type id_resolver registered
Aug 23 16:48:44 raspberrypi kernel: [ 1.951895] Key type id_legacy registered
Aug 23 16:48:44 raspberrypi kernel: [ 1.952064] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
Aug 23 16:48:44 raspberrypi kernel: [ 1.952099] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
Aug 23 16:48:44 raspberrypi kernel: [ 1.953335] Key type asymmetric registered
Aug 23 16:48:44 raspberrypi kernel: [ 1.953368] Asymmetric key parser 'x509' registered
Aug 23 16:48:44 raspberrypi kernel: [ 1.953441] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
Aug 23 16:48:44 raspberrypi kernel: [ 1.953481] io scheduler mq-deadline registered
Aug 23 16:48:44 raspberrypi kernel: [ 1.953510] io scheduler kyber registered
Aug 23 16:48:44 raspberrypi kernel: [ 1.958746] bcm2708_fb soc:fb: FB found 1 display(s)
Aug 23 16:48:44 raspberrypi kernel: [ 1.971216] Console: switching to colour frame buffer device 82x26
Aug 23 16:48:44 raspberrypi kernel: [ 1.978523] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 656x416
Aug 23 16:48:44 raspberrypi kernel: [ 1.989100] bcm2835-rng 3f104000.rng: hwrng registered
Aug 23 16:48:44 raspberrypi kernel: [ 1.992090] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
Aug 23 16:48:44 raspberrypi kernel: [ 1.998001] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
Aug 23 16:48:44 raspberrypi kernel: [ 2.015462] brd: module loaded
Aug 23 16:48:44 raspberrypi kernel: [ 2.030267] loop: module loaded
Aug 23 16:48:44 raspberrypi kernel: [ 2.034745] Loading iSCSI transport class v2.0-870.
Aug 23 16:48:44 raspberrypi kernel: [ 2.039026] libphy: Fixed MDIO Bus: probed
Aug 23 16:48:44 raspberrypi kernel: [ 2.041947] usbcore: registered new interface driver lan78xx
Aug 23 16:48:44 raspberrypi kernel: [ 2.044655] usbcore: registered new interface driver smsc95xx
Aug 23 16:48:44 raspberrypi kernel: [ 2.047201] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
Aug 23 16:48:44 raspberrypi kernel: [ 2.778025] Core Release: 2.80a
Aug 23 16:48:44 raspberrypi kernel: [ 2.780507] Setting default values for core params
Aug 23 16:48:44 raspberrypi avahi-daemon[495]: Network interface enumeration completed.
Aug 23 16:48:44 raspberrypi kernel: [ 2.782963] Finished setting default values for core params
Aug 23 16:48:44 raspberrypi kernel: [ 2.985838] Using Buffer DMA mode
Aug 23 16:48:44 raspberrypi kernel: [ 2.988302] Periodic Transfer Interrupt Enhancement - disabled
Aug 23 16:48:44 raspberrypi kernel: [ 2.990844] Multiprocessor Interrupt Enhancement - disabled
Aug 23 16:48:44 raspberrypi kernel: [ 2.993376] OTG VER PARAM: 0, OTG VER FLAG: 0
Aug 23 16:48:44 raspberrypi kernel: [ 2.995881] Dedicated Tx FIFOs mode
Aug 23 16:48:44 raspberrypi kernel: [ 2.998766]
Aug 23 16:48:44 raspberrypi kernel: [ 2.998788] WARN::dwc_otg_hcd_init:1074: FIQ DMA bounce buffers: virt = b7504000 dma = 0xf7504000 len=9024
Aug 23 16:48:44 raspberrypi kernel: [ 3.005753] FIQ FSM acceleration enabled for :
Aug 23 16:48:44 raspberrypi kernel: [ 3.005753] Non-periodic Split Transactions
Aug 23 16:48:44 raspberrypi kernel: [ 3.005753] Periodic Split Transactions
Aug 23 16:48:44 raspberrypi kernel: [ 3.005753] High-Speed Isochronous Endpoints
Aug 23 16:48:44 raspberrypi kernel: [ 3.005753] Interrupt/Control Split Transaction hack enabled
Aug 23 16:48:44 raspberrypi kernel: [ 3.016647] dwc_otg: Microframe scheduler enabled
Aug 23 16:48:44 raspberrypi kernel: [ 3.016715]
Aug 23 16:48:44 raspberrypi kernel: [ 3.016725] WARN::hcd_init_fiq:457: FIQ on core 1
Aug 23 16:48:44 raspberrypi kernel: [ 3.021034]
Aug 23 16:48:44 raspberrypi kernel: [ 3.021044] WARN::hcd_init_fiq:458: FIQ ASM at 807c8de0 length 36
Aug 23 16:48:44 raspberrypi kernel: [ 3.025475]
Aug 23 16:48:44 raspberrypi kernel: [ 3.025484] WARN::hcd_init_fiq:497: MPHI regs_base at bb810000
Aug 23 16:48:44 raspberrypi kernel: [ 3.029947] dwc_otg 3f980000.usb: DWC OTG Controller
Aug 23 16:48:44 raspberrypi kernel: [ 3.032261] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
Aug 23 16:48:44 raspberrypi kernel: [ 3.034656] dwc_otg 3f980000.usb: irq 89, io mem 0x00000000
Aug 23 16:48:44 raspberrypi kernel: [ 3.036982] Init: Port Power? op_state=1
Aug 23 16:48:44 raspberrypi kernel: [ 3.039214] Init: Power Port (0)
Aug 23 16:48:44 raspberrypi kernel: [ 3.041746] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
Aug 23 16:48:44 raspberrypi kernel: [ 3.046364] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Aug 23 16:48:44 raspberrypi kernel: [ 3.048829] usb usb1: Product: DWC OTG Controller
Aug 23 16:48:44 raspberrypi kernel: [ 3.051185] usb usb1: Manufacturer: Linux 5.10.52-v7+ dwc_otg_hcd
Aug 23 16:48:44 raspberrypi kernel: [ 3.053579] usb usb1: SerialNumber: 3f980000.usb
Aug 23 16:48:44 raspberrypi kernel: [ 3.056758] hub 1-0:1.0: USB hub found
Aug 23 16:48:44 raspberrypi kernel: [ 3.059206] hub 1-0:1.0: 1 port detected
Aug 23 16:48:44 raspberrypi kernel: [ 3.062798] dwc_otg: FIQ enabled
Aug 23 16:48:44 raspberrypi kernel: [ 3.062811] dwc_otg: NAK holdoff enabled
Aug 23 16:48:44 raspberrypi kernel: [ 3.062823] dwc_otg: FIQ split-transaction FSM enabled
Aug 23 16:48:44 raspberrypi kernel: [ 3.062841] Module dwc_common_port init
Aug 23 16:48:44 raspberrypi kernel: [ 3.063149] usbcore: registered new interface driver usb-storage
Aug 23 16:48:44 raspberrypi kernel: [ 3.065889] mousedev: PS/2 mouse device common for all mice
Aug 23 16:48:44 raspberrypi kernel: [ 3.069528] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
Aug 23 16:48:44 raspberrypi kernel: [ 3.074801] sdhci: Secure Digital Host Controller Interface driver
Aug 23 16:48:44 raspberrypi kernel: [ 3.077332] sdhci: Copyright(c) Pierre Ossman
Aug 23 16:48:44 raspberrypi kernel: [ 3.080412] mmc-bcm2835 3f300000.mmcnr: could not get clk, deferring probe
Aug 23 16:48:44 raspberrypi kernel: [ 3.083656] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
Aug 23 16:48:44 raspberrypi kernel: [ 3.086506] sdhci-pltfm: SDHCI platform and OF driver helper
Aug 23 16:48:44 raspberrypi kernel: [ 3.090963] ledtrig-cpu: registered to indicate activity on CPUs
Aug 23 16:48:44 raspberrypi kernel: [ 3.093979] hid: raw HID events driver (C) Jiri Kosina
Aug 23 16:48:44 raspberrypi kernel: [ 3.096797] usbcore: registered new interface driver usbhid
Aug 23 16:48:44 raspberrypi kernel: [ 3.099395] usbhid: USB HID core driver
Aug 23 16:48:44 raspberrypi kernel: [ 3.107219] Initializing XFRM netlink socket
Aug 23 16:48:44 raspberrypi kernel: [ 3.109831] NET: Registered protocol family 17
Aug 23 16:48:44 raspberrypi kernel: [ 3.112445] Key type dns_resolver registered
Aug 23 16:48:44 raspberrypi kernel: [ 3.115503] Registering SWP/SWPB emulation handler
Aug 23 16:48:44 raspberrypi kernel: [ 3.118001] registered taskstats version 1
Aug 23 16:48:44 raspberrypi kernel: [ 3.120337] Loading compiled-in X.509 certificates
Aug 23 16:48:44 raspberrypi kernel: [ 3.123573] Key type ._fscrypt registered
Aug 23 16:48:44 raspberrypi kernel: [ 3.125931] Key type .fscrypt registered
Aug 23 16:48:44 raspberrypi kernel: [ 3.128259] Key type fscrypt-provisioning registered
Aug 23 16:48:44 raspberrypi kernel: [ 3.142243] uart-pl011 3f201000.serial: cts_event_workaround enabled
Aug 23 16:48:44 raspberrypi kernel: [ 3.144792] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 114, base_baud = 0) is a PL011 rev2
Aug 23 16:48:44 raspberrypi kernel: [ 3.151846] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
Aug 23 16:48:44 raspberrypi kernel: [ 3.156098] mmc-bcm2835 3f300000.mmcnr: mmc_debug:0 mmc_debug2:0
Aug 23 16:48:44 raspberrypi kernel: [ 3.158577] mmc-bcm2835 3f300000.mmcnr: DMA channel allocated
Aug 23 16:48:44 raspberrypi kernel: [ 3.185936] Indeed it is in host mode hprt0 = 00021501
Aug 23 16:48:44 raspberrypi kernel: [ 3.248467] sdhost: log_buf @ (ptrval) (f7507000)
Aug 23 16:48:44 raspberrypi kernel: [ 3.286639] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
Aug 23 16:48:44 raspberrypi kernel: [ 3.290646] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
Aug 23 16:48:44 raspberrypi kernel: [ 3.294551] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
Aug 23 16:48:44 raspberrypi kernel: [ 3.299716] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
Aug 23 16:48:44 raspberrypi kernel: [ 3.301863] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
Aug 23 16:48:44 raspberrypi kernel: [ 3.306960] of_cfs_init
Aug 23 16:48:44 raspberrypi kernel: [ 3.309280] of_cfs_init: OK
Aug 23 16:48:44 raspberrypi kernel: [ 3.312419] Waiting for root device PARTUUID=0f0cf00c-02...
Aug 23 16:48:44 raspberrypi kernel: [ 3.391123] mmc0: host does not support reading read-only switch, assuming write-enable
Aug 23 16:48:44 raspberrypi kernel: [ 3.395503] usb 1-1: new high-speed USB device number 2 using dwc_otg
Aug 23 16:48:44 raspberrypi kernel: [ 3.398018] Indeed it is in host mode hprt0 = 00001101
Aug 23 16:48:44 raspberrypi motion[480]: Not starting motion daemon, disabled via /etc/default/motion ... (warning).
Aug 23 16:48:44 raspberrypi avahi-daemon[495]: Server startup complete. Host name is raspberrypi.local. Local service cookie is 2544864061.
Aug 23 16:48:44 raspberrypi systemd[1]: Started dphys-swapfile - set up, mount/unmount, and delete a swap file.
Aug 23 16:48:44 raspberrypi kernel: [ 3.461935] mmc0: new high speed SDHC card at address aaaa
Aug 23 16:48:44 raspberrypi kernel: [ 3.465316] mmcblk0: mmc0:aaaa SB16G 14.8 GiB
Aug 23 16:48:44 raspberrypi kernel: [ 3.473499] mmcblk0: p1 p2
Aug 23 16:48:44 raspberrypi kernel: [ 3.502397] mmc1: new high speed SDIO card at address 0001
Aug 23 16:48:44 raspberrypi kernel: [ 3.508588] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
Aug 23 16:48:44 raspberrypi kernel: [ 3.513055] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
Aug 23 16:48:44 raspberrypi kernel: [ 3.526557] devtmpfs: mounted
Aug 23 16:48:44 raspberrypi kernel: [ 3.535851] Freeing unused kernel memory: 1024K
Aug 23 16:48:44 raspberrypi kernel: [ 3.574903] Run /sbin/init as init process
Aug 23 16:48:44 raspberrypi kernel: [ 3.577272] with arguments:
Aug 23 16:48:44 raspberrypi kernel: [ 3.577284] /sbin/init
Aug 23 16:48:44 raspberrypi kernel: [ 3.577294] with environment:
Aug 23 16:48:44 raspberrypi kernel: [ 3.577305] HOME=/
Aug 23 16:48:44 raspberrypi kernel: [ 3.577317] TERM=linux
Aug 23 16:48:44 raspberrypi kernel: [ 3.634779] usb 1-1: New USB device found, idVendor=0424, idProduct=9514, bcdDevice= 2.00
Aug 23 16:48:44 raspberrypi kernel: [ 3.639939] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Aug 23 16:48:44 raspberrypi kernel: [ 3.643572] hub 1-1:1.0: USB hub found
Aug 23 16:48:44 raspberrypi kernel: [ 3.646451] hub 1-1:1.0: 5 ports detected
Aug 23 16:48:44 raspberrypi kernel: [ 3.964444] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
Aug 23 16:48:44 raspberrypi kernel: [ 4.094797] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00, bcdDevice= 2.00
Aug 23 16:48:44 raspberrypi kernel: [ 4.100295] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Aug 23 16:48:44 raspberrypi kernel: [ 4.106043] smsc95xx v2.0.0
Aug 23 16:48:44 raspberrypi kernel: [ 4.274714] libphy: smsc95xx-mdiobus: probed
Aug 23 16:48:44 raspberrypi kernel: [ 4.278625] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:d5:83:a9
Aug 23 16:48:44 raspberrypi kernel: [ 4.371381] NET: Registered protocol family 10
Aug 23 16:48:44 raspberrypi kernel: [ 4.375975] Segment Routing with IPv6
Aug 23 16:48:44 raspberrypi btuart[449]: bcm43xx_init
Aug 23 16:48:44 raspberrypi btuart[449]: Set BDADDR UART: b8:27:eb:7f:29:03
Aug 23 16:48:44 raspberrypi btuart[449]: Set Controller UART speed to 921600 bit/s
Aug 23 16:48:44 raspberrypi btuart[449]: Device setup complete
Aug 23 16:48:44 raspberrypi systemd[1]: Started LSB: Start Motion detection.
Aug 23 16:48:44 raspberrypi kernel: [ 4.584459] usb 1-1.3: new high-speed USB device number 4 using dwc_otg
Aug 23 16:48:44 raspberrypi kernel: [ 4.715864] usb 1-1.3: New USB device found, idVendor=0781, idProduct=5591, bcdDevice= 1.00
Aug 23 16:48:44 raspberrypi kernel: [ 4.721757] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Aug 23 16:48:44 raspberrypi kernel: [ 4.724964] usb 1-1.3: Product: SanDisk 3.2Gen1
Aug 23 16:48:44 raspberrypi kernel: [ 4.727935] usb 1-1.3: Manufacturer: USB
Aug 23 16:48:44 raspberrypi kernel: [ 4.730803] usb 1-1.3: SerialNumber: 01016a07c919d4884424d42e1af4c5f764dd74221ff5797c428f1753a3715ab1667400000000000000000000e431d0f1ff932d0091558107532b6bb5
Aug 23 16:48:44 raspberrypi kernel: [ 4.755437] usb-storage 1-1.3:1.0: USB Mass Storage device detected
Aug 23 16:48:44 raspberrypi kernel: [ 4.784540] scsi host0: usb-storage 1-1.3:1.0
Aug 23 16:48:44 raspberrypi kernel: [ 4.884446] usb 1-1.5: new high-speed USB device number 5 using dwc_otg
Aug 23 16:48:44 raspberrypi kernel: [ 5.043343] usb 1-1.5: New USB device found, idVendor=6366, idProduct=3370, bcdDevice= 1.00
Aug 23 16:48:44 raspberrypi kernel: [ 5.049260] usb 1-1.5: New USB device strings: Mfr=2, Product=1, SerialNumber=3
Aug 23 16:48:44 raspberrypi kernel: [ 5.052266] usb 1-1.5: Product: USB 2.0 Camera
Aug 23 16:48:44 raspberrypi kernel: [ 5.055170] usb 1-1.5: Manufacturer: Sonix Technology Co., Ltd.
Aug 23 16:48:44 raspberrypi kernel: [ 5.058021] usb 1-1.5: SerialNumber: SN0001
Aug 23 16:48:44 raspberrypi kernel: [ 5.542010] random: systemd: uninitialized urandom read (16 bytes read)
Aug 23 16:48:44 raspberrypi kernel: [ 5.561373] random: systemd: uninitialized urandom read (16 bytes read)
Aug 23 16:48:44 raspberrypi kernel: [ 5.572586] random: systemd: uninitialized urandom read (16 bytes read)
Aug 23 16:48:44 raspberrypi kernel: [ 5.835859] scsi 0:0:0:0: Direct-Access USB SanDisk 3.2Gen1 1.00 PQ: 0 ANSI: 6
Aug 23 16:48:44 raspberrypi kernel: [ 5.841453] sd 0:0:0:0: [sda] 240353280 512-byte logical blocks: (123 GB/115 GiB)
Aug 23 16:48:44 raspberrypi kernel: [ 5.847284] sd 0:0:0:0: [sda] Write Protect is off
Aug 23 16:48:44 raspberrypi kernel: [ 5.847304] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
Aug 23 16:48:44 raspberrypi kernel: [ 5.847847] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
Aug 23 16:48:44 raspberrypi kernel: [ 5.938186] sda: sda1
Aug 23 16:48:44 raspberrypi kernel: [ 5.944047] sd 0:0:0:0: [sda] Attached SCSI removable disk
Aug 23 16:48:44 raspberrypi kernel: [ 6.633888] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
Aug 23 16:48:44 raspberrypi kernel: [ 7.172911] sd 0:0:0:0: Attached scsi generic sg0 type 0
Aug 23 16:48:44 raspberrypi kernel: [ 7.705150] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
Aug 23 16:48:44 raspberrypi kernel: [ 7.707714] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
Aug 23 16:48:44 raspberrypi kernel: [ 7.707742] [vc_sm_connected_init]: start
Aug 23 16:48:44 raspberrypi kernel: [ 7.718222] [vc_sm_connected_init]: installed successfully
Aug 23 16:48:44 raspberrypi kernel: [ 7.740711] mc: Linux media interface: v0.10
Aug 23 16:48:44 raspberrypi kernel: [ 7.824174] videodev: Linux video capture interface: v2.00
Aug 23 16:48:44 raspberrypi kernel: [ 7.836717] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
Aug 23 16:48:44 raspberrypi kernel: [ 7.875113] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
Aug 23 16:48:44 raspberrypi kernel: [ 7.875484] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
Aug 23 16:48:44 raspberrypi kernel: [ 7.876594] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
Aug 23 16:48:44 raspberrypi kernel: [ 7.880935] bcm2835_audio bcm2835_audio: card created with 8 channels
Aug 23 16:48:44 raspberrypi kernel: [ 7.890507] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
Aug 23 16:48:44 raspberrypi kernel: [ 7.895965] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
Aug 23 16:48:44 raspberrypi kernel: [ 7.912025] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
Aug 23 16:48:44 raspberrypi kernel: [ 7.930923] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
Aug 23 16:48:44 raspberrypi kernel: [ 7.952592] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
Aug 23 16:48:44 raspberrypi kernel: [ 7.954214] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
Aug 23 16:48:44 raspberrypi kernel: [ 7.955236] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
Aug 23 16:48:44 raspberrypi kernel: [ 7.955285] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
Aug 23 16:48:44 raspberrypi kernel: [ 7.955325] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
Aug 23 16:48:44 raspberrypi kernel: [ 7.955345] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
Aug 23 16:48:44 raspberrypi kernel: [ 7.955369] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
Aug 23 16:48:44 raspberrypi kernel: [ 7.955617] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
Aug 23 16:48:44 raspberrypi kernel: [ 7.958350] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
Aug 23 16:48:44 raspberrypi kernel: [ 7.996043] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
Aug 23 16:48:44 raspberrypi kernel: [ 7.996260] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
Aug 23 16:48:44 raspberrypi kernel: [ 8.000815] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
Aug 23 16:48:44 raspberrypi kernel: [ 8.000872] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
Aug 23 16:48:44 raspberrypi kernel: [ 8.005222] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
Aug 23 16:48:44 raspberrypi kernel: [ 8.005397] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
Aug 23 16:48:44 raspberrypi kernel: [ 8.278397] cfg80211: Loading compiled-in X.509 certificates for regulatory database
Aug 23 16:48:44 raspberrypi kernel: [ 8.419444] uvcvideo: Found UVC 1.00 device USB 2.0 Camera (6366:3370)
Aug 23 16:48:44 raspberrypi kernel: [ 8.426709] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
Aug 23 16:48:44 raspberrypi kernel: [ 8.453162] input: USB 2.0 Camera: USB Camera as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5:1.0/input/input0
Aug 23 16:48:44 raspberrypi kernel: [ 8.453644] usbcore: registered new interface driver uvcvideo
Aug 23 16:48:44 raspberrypi kernel: [ 8.453657] USB Video Class driver (1.1.1)
Aug 23 16:48:44 raspberrypi kernel: [ 8.464810] usbcore: registered new interface driver uas
Aug 23 16:48:44 raspberrypi kernel: [ 8.539394] brcmfmac: F1 signature read @0x18000000=0x1541a9a6
Aug 23 16:48:44 raspberrypi kernel: [ 8.550949] usb 1-1.5: 3:1: cannot get freq at ep 0x84
Aug 23 16:48:44 raspberrypi kernel: [ 8.555263] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
Aug 23 16:48:44 raspberrypi kernel: [ 8.555637] usbcore: registered new interface driver brcmfmac
Aug 23 16:48:44 raspberrypi kernel: [ 8.689180] usbcore: registered new interface driver snd-usb-audio
Aug 23 16:48:44 raspberrypi kernel: [ 8.774275] random: crng init done
Aug 23 16:48:44 raspberrypi kernel: [ 8.774294] random: 7 urandom warning(s) missed due to ratelimiting
Aug 23 16:48:44 raspberrypi kernel: [ 8.792056] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
Aug 23 16:48:44 raspberrypi kernel: [ 8.792214] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
Aug 23 16:48:44 raspberrypi kernel: [ 8.792308] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-2), device may have limited channels available
Aug 23 16:48:44 raspberrypi kernel: [ 8.793362] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM43430/1 wl0: Oct 22 2019 01:59:28 version 7.45.98.94 (r723000 CY) FWID 01-3b33decd
Aug 23 16:48:44 raspberrypi kernel: [ 11.601270] uart-pl011 3f201000.serial: no DMA platform data
Aug 23 16:48:44 raspberrypi kernel: [ 11.831264] Bluetooth: Core ver 2.22
Aug 23 16:48:44 raspberrypi kernel: [ 11.831434] NET: Registered protocol family 31
Aug 23 16:48:44 raspberrypi kernel: [ 11.831448] Bluetooth: HCI device and connection manager initialized
Aug 23 16:48:44 raspberrypi kernel: [ 11.832093] 8021q: 802.1Q VLAN Support v1.8
Aug 23 16:48:44 raspberrypi kernel: [ 11.844693] Adding 2097148k swap on /var/swap. Priority:-2 extents:18 across:2424828k FS
Aug 23 16:48:44 raspberrypi kernel: [ 11.852524] Bluetooth: HCI socket layer initialized
Aug 23 16:48:44 raspberrypi kernel: [ 11.852556] Bluetooth: L2CAP socket layer initialized
Aug 23 16:48:44 raspberrypi kernel: [ 11.852613] Bluetooth: SCO socket layer initialized
Aug 23 16:48:44 raspberrypi kernel: [ 11.896606] Bluetooth: HCI UART driver ver 2.3
Aug 23 16:48:44 raspberrypi kernel: [ 11.896641] Bluetooth: HCI UART protocol H4 registered
Aug 23 16:48:44 raspberrypi kernel: [ 11.896788] Bluetooth: HCI UART protocol Three-wire (H5) registered
Aug 23 16:48:44 raspberrypi kernel: [ 11.897084] Bluetooth: HCI UART protocol Broadcom registered
Aug 23 16:48:44 raspberrypi wpa_supplicant[478]: Successfully initialized wpa_supplicant
Aug 23 16:48:44 raspberrypi systemd[1]: Started Configure Bluetooth Modems connected by UART.
Aug 23 16:48:44 raspberrypi dhcpcd[516]: wlan0: connected to Access Point `'
Aug 23 16:48:44 raspberrypi systemd[1]: Created slice system-bthelper.slice.
Aug 23 16:48:44 raspberrypi dbus-daemon[466]: [system] Successfully activated service 'org.freedesktop.systemd1'
Aug 23 16:48:44 raspberrypi systemd[1]: Starting Raspberry Pi bluetooth helper...
Aug 23 16:48:44 raspberrypi systemd[1]: Reached target Sound Card.
Aug 23 16:48:44 raspberrypi systemd[1]: Started Login Service.
Aug 23 16:48:44 raspberrypi systemd[1]: Started WPA supplicant.
Aug 23 16:48:44 raspberrypi systemd[1]: Started Avahi mDNS/DNS-SD Stack.
Aug 23 16:48:44 raspberrypi bthelper[567]: Raspberry Pi BDADDR already set
Aug 23 16:48:44 raspberrypi systemd[1]: Started Raspberry Pi bluetooth helper.
Aug 23 16:48:44 raspberrypi systemd[1]: Starting Bluetooth service...
Aug 23 16:48:44 raspberrypi dhcpcd[516]: eth0: waiting for carrier
Aug 23 16:48:44 raspberrypi kernel: [ 12.247376] SMSC LAN8700 usb-001:003:01: attached PHY driver [SMSC LAN8700] (mii_bus:phy_addr=usb-001:003:01, irq=POLL)
Aug 23 16:48:44 raspberrypi kernel: [ 12.247881] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
Aug 23 16:48:44 raspberrypi kernel: [ 12.256105] smsc95xx 1-1.1:1.0 eth0: Link is Down
Aug 23 16:48:44 raspberrypi dhcpcd[516]: wlan0: waiting for carrier
Aug 23 16:48:44 raspberrypi kernel: [ 12.301623] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
Aug 23 16:48:44 raspberrypi bluetoothd[577]: Bluetooth daemon 5.50
Aug 23 16:48:44 raspberrypi systemd[1]: Started Bluetooth service.
Aug 23 16:48:44 raspberrypi systemd[1]: Reached target Bluetooth.
Aug 23 16:48:44 raspberrypi bluetoothd[577]: Starting SDP server
Aug 23 16:48:44 raspberrypi kernel: [ 12.470671] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Aug 23 16:48:44 raspberrypi kernel: [ 12.470695] Bluetooth: BNEP filters: protocol multicast
Aug 23 16:48:44 raspberrypi kernel: [ 12.470728] Bluetooth: BNEP socket layer initialized
Aug 23 16:48:44 raspberrypi dbus-daemon[466]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.5' (uid=0 pid=577 comm="/usr/lib/bluetooth/bluetoothd ")
Aug 23 16:48:44 raspberrypi bluetoothd[577]: Bluetooth management interface 1.18 initialized
Aug 23 16:48:44 raspberrypi bluetoothd[577]: Sap driver initialization failed.
Aug 23 16:48:44 raspberrypi bluetoothd[577]: sap-server: Operation not permitted (1)
Aug 23 16:48:44 raspberrypi systemd[1]: Starting Hostname Service...
Aug 23 16:48:44 raspberrypi bluetoothd[577]: Failed to set privacy: Rejected (0x0b)
Aug 23 16:48:44 raspberrypi dbus-daemon[466]: [system] Successfully activated service 'org.freedesktop.hostname1'
Aug 23 16:48:45 raspberrypi systemd[1]: Started Hostname Service.
Aug 23 16:48:45 raspberrypi raspi-config[493]: Checking if shift key is held down: No. Switching to ondemand scaling governor.
Aug 23 16:48:45 raspberrypi systemd[1]: Started LSB: Switch to ondemand cpu governor (unless shift key is pressed).
Aug 23 16:48:45 raspberrypi weewx[563] INFO __main__: Initializing weewx version 4.5.1
Aug 23 16:48:45 raspberrypi weewx[563] INFO __main__: Using Python 3.7.3 (default, Jan 22 2021, 20:04:44) #012[GCC 8.3.0]
Aug 23 16:48:45 raspberrypi weewx[563] INFO __main__: Platform Linux-5.10.52-v7+-armv7l-with-debian-10.10
Aug 23 16:48:45 raspberrypi weewx[563] INFO __main__: Locale is 'es_ES.UTF-8'
Aug 23 16:48:45 raspberrypi weewx[563] INFO __main__: PID file is /var/run/weewx.pid
Aug 23 16:48:45 raspberrypi weewx[583] INFO __main__: Using configuration file /etc/weewx/weewx.conf
Aug 23 16:48:45 raspberrypi weewx[583] INFO __main__: Debug is 0
Aug 23 16:48:45 raspberrypi weewx[583] INFO weewx.engine: Loading station type Interceptor (user.interceptor)
Aug 23 16:48:45 raspberrypi weewx[519]: Starting weewx weather system: weewx.
Aug 23 16:48:45 raspberrypi systemd[1]: Started LSB: weewx weather system.
Aug 23 16:48:45 raspberrypi weewx[583] INFO user.interceptor: driver version is 0.53
Aug 23 16:48:45 raspberrypi weewx[583] INFO user.interceptor: device type: observer
Aug 23 16:48:45 raspberrypi weewx[583] INFO user.interceptor: mode is listen
Aug 23 16:48:45 raspberrypi weewx[583] INFO user.interceptor: listen on :8001
Aug 23 16:48:45 raspberrypi weewx[583] INFO user.interceptor: sensor map: {'pressure': 'pressure', 'barometer': 'barometer', 'outHumidity': 'humidity_out', 'inHumidity': 'humidity_in', 'outTemp': 'temperature_out', 'inTemp': 'temperature_in', 'windSpeed': 'wind_speed', 'windGust': 'wind_gust', 'windDir': 'wind_dir', 'windGustDir': 'wind_gust_dir', 'radiation': 'solar_radiation', 'dewpoint': 'dewpoint', 'windchill': 'windchill', 'rain': 'rain', 'rainRate': 'rain_rate', 'UV': 'uv', 'txBatteryStatus': 'battery', 'extraTemp1': 'temperature_1', 'extraTemp2': 'temperature_2', 'extraTemp3': 'temperature_3', 'extraHumid1': 'humidity_1', 'extraHumid2': 'humidity_2', 'soilTemp1': 'soil_temperature_1', 'soilTemp2': 'soil_temperature_2', 'soilMoist1': 'soil_moisture_1', 'soilMoist2': 'soil_moisture_2', 'soilMoist3': 'soil_moisture_3', 'soilMoist4': 'soil_moisture_4', 'leafWet1': 'leafwetness_1', 'leafWet2': 'leafwetness_2', 'pm2_5': 'pm2_5', 'extraTemp4': 'temperature_4', 'extraTemp5': 'temperature_5', 'extraTemp6': 'temperature_6', 'extraTemp7': 'temperature_7', 'extraTemp8': 'temperature_8', 'extraHumid3': 'humidity_3', 'extraHumid4': 'humidity_4', 'extraHumid5': 'humidity_5', 'extraHumid6': 'humidity_6', 'extraHumid7': 'humidity_7', 'extraHumid8': 'humidity_8', 'soilTemp3': 'soil_temperature_3', 'soilTemp4': 'soil_temperature_4'}
Aug 23 16:48:45 raspberrypi weewx[583] INFO weewx.engine: StdConvert target unit is 0x1
Aug 23 16:48:46 raspberrypi weewx[583] INFO weewx.engine: Archive will use data binding wx_binding
Aug 23 16:48:46 raspberrypi weewx[583] INFO weewx.engine: Record generation will be attempted in 'hardware'
Aug 23 16:48:46 raspberrypi weewx[583] INFO weewx.engine: Using archive interval of 300 seconds (specified in weewx configuration)
Aug 23 16:48:46 raspberrypi weewx[583] INFO weewx.restx: StationRegistry: Registration not requested.
Aug 23 16:48:46 raspberrypi weewx[583] INFO weewx.restx: Wunderground: Posting not enabled.
Aug 23 16:48:46 raspberrypi weewx[583] INFO weewx.restx: PWSweather: Posting not enabled.
Aug 23 16:48:46 raspberrypi weewx[583] INFO weewx.restx: CWOP: Posting not enabled.
Aug 23 16:48:46 raspberrypi weewx[583] INFO weewx.restx: WOW: Posting not enabled.
Aug 23 16:48:46 raspberrypi weewx[583] INFO weewx.restx: AWEKAS: Posting not enabled.
Aug 23 16:48:46 raspberrypi weewx[583] INFO __main__: Starting up weewx version 4.5.1
Aug 23 16:48:46 raspberrypi weewx[583] INFO weewx.engine: Using binding 'wx_binding' to database 'weewx.sdb'
Aug 23 16:48:46 raspberrypi weewx[583] INFO weewx.manager: Starting backfill of daily summaries
Aug 23 16:48:46 raspberrypi weewx[583] INFO weewx.manager: Daily summaries up to date
Aug 23 16:48:46 raspberrypi weewx[583] INFO weewx.engine: Starting main packet loop.
Aug 23 16:48:46 raspberrypi dhcpcd[516]: eth0: carrier acquired
Aug 23 16:48:46 raspberrypi kernel: [ 14.315112] smsc95xx 1-1.1:1.0 eth0: Link is Up - 100Mbps/Full - flow control off
Aug 23 16:48:46 raspberrypi kernel: [ 14.315146] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Aug 23 16:48:46 raspberrypi dhcpcd[516]: DUID 00:01:00:01:27:5a:4b:69:b8:27:eb:d5:83:a9
Aug 23 16:48:46 raspberrypi dhcpcd[516]: eth0: IAID eb:d5:83:a9
Aug 23 16:48:46 raspberrypi dhcpcd[516]: eth0: adding address fe80::6f6:c559:aeb0:f037
Aug 23 16:48:46 raspberrypi avahi-daemon[495]: Joining mDNS multicast group on interface eth0.IPv6 with address fe80::6f6:c559:aeb0:f037.
Aug 23 16:48:46 raspberrypi dhcpcd[516]: eth0: probing address 192.168.0.2/24
Aug 23 16:48:46 raspberrypi avahi-daemon[495]: New relevant interface eth0.IPv6 for mDNS.
Aug 23 16:48:46 raspberrypi avahi-daemon[495]: Registering new address record for fe80::6f6:c559:aeb0:f037 on eth0.*.
Aug 23 16:48:46 raspberrypi dhcpcd[516]: eth0: soliciting an IPv6 router
Aug 23 16:48:49 raspberrypi systemd[1]: systemd-rfkill.service: Succeeded.
Aug 23 16:48:49 raspberrypi bthelper[567]: Changing power off succeeded
Aug 23 16:48:49 raspberrypi bthelper[567]: Changing power on succeeded
Aug 23 16:48:51 raspberrypi dhcpcd[516]: eth0: using static address 192.168.0.2/24
Aug 23 16:48:51 raspberrypi dhcpcd[516]: eth0: adding route to 192.168.0.0/24
Aug 23 16:48:51 raspberrypi dhcpcd[516]: eth0: adding default route via 192.168.0.1
Aug 23 16:48:51 raspberrypi avahi-daemon[495]: Joining mDNS multicast group on interface eth0.IPv4 with address 192.168.0.2.
Aug 23 16:48:51 raspberrypi avahi-daemon[495]: New relevant interface eth0.IPv4 for mDNS.
Aug 23 16:48:51 raspberrypi avahi-daemon[495]: Registering new address record for 192.168.0.2 on eth0.IPv4.
Aug 23 16:48:51 raspberrypi dhcpcd[516]: forked to background, child pid 637
Aug 23 16:48:51 raspberrypi systemd[1]: Started dhcpcd on all interfaces.
Aug 23 16:48:51 raspberrypi systemd[1]: Reached target Network.
Aug 23 16:48:51 raspberrypi systemd[1]: Starting dnsmasq - A lightweight DHCP and caching DNS server...
Aug 23 16:48:51 raspberrypi systemd[1]: Starting Advanced IEEE 802.11 AP and IEEE 802.1X/WPA/WPA2/EAP Authenticator...
Aug 23 16:48:51 raspberrypi systemd[1]: Starting Permit User Sessions...
Aug 23 16:48:51 raspberrypi systemd[1]: Reached target Network is Online.
Aug 23 16:48:51 raspberrypi systemd[1]: Starting LSB: web-based administration interface for Unix systems...
Aug 23 16:48:51 raspberrypi systemd[1]: Starting /etc/rc.local Compatibility...
Aug 23 16:48:51 raspberrypi systemd[1]: Starting LSB: Update dynamic domain name service entries...
Aug 23 16:48:51 raspberrypi systemd[1]: Starting Lighttpd Daemon...
Aug 23 16:48:51 raspberrypi systemd[1]: Condition check resulted in fast remote file copy program daemon being skipped.
Aug 23 16:48:51 raspberrypi systemd[1]: Starting OpenBSD Secure Shell server...
Aug 23 16:48:51 raspberrypi systemd[1]: Started Permit User Sessions.
Aug 23 16:48:51 raspberrypi systemd[1]: Started /etc/rc.local Compatibility.
Aug 23 16:48:51 raspberrypi systemd[1]: Started Getty on tty1.
Aug 23 16:48:51 raspberrypi systemd[1]: Reached target Login Prompts.
Aug 23 16:48:51 raspberrypi hostapd[639]: Configuration file: /etc/hostapd/hostapd.conf
Aug 23 16:48:52 raspberrypi dnsmasq[638]: dnsmasq: revisión de sintaxis OK.
Aug 23 16:48:52 raspberrypi hostapd[639]: wlan0: interface state UNINITIALIZED->COUNTRY_UPDATE
Aug 23 16:48:52 raspberrypi systemd[1]: Started Advanced IEEE 802.11 AP and IEEE 802.1X/WPA/WPA2/EAP Authenticator.
Aug 23 16:48:52 raspberrypi kernel: [ 19.954442] usb 1-1.2: new high-speed USB device number 6 using dwc_otg
Aug 23 16:48:52 raspberrypi dhcpcd[637]: wlan0: carrier acquired
Aug 23 16:48:52 raspberrypi kernel: [ 20.026219] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Aug 23 16:48:52 raspberrypi dhcpcd[637]: wlan0: IAID eb:80:d6:fc
Aug 23 16:48:52 raspberrypi dhcpcd[637]: wlan0: adding address fe80::1dd7:174e:ddbc:cb12
Aug 23 16:48:52 raspberrypi avahi-daemon[495]: Joining mDNS multicast group on interface wlan0.IPv6 with address fe80::1dd7:174e:ddbc:cb12.
Aug 23 16:48:52 raspberrypi avahi-daemon[495]: New relevant interface wlan0.IPv6 for mDNS.
Aug 23 16:48:52 raspberrypi dhcpcd[637]: wlan0: probing address 192.168.10.1/24
Aug 23 16:48:52 raspberrypi avahi-daemon[495]: Registering new address record for fe80::1dd7:174e:ddbc:cb12 on wlan0.*.
Aug 23 16:48:52 raspberrypi dnsmasq[665]: iniciado, versión 2.80 tamaño de caché 150
Aug 23 16:48:52 raspberrypi dnsmasq[665]: opciones de compilación: IPv6 GNU-getopt DBus i18n IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth DNSSEC loop-detect inotify dumpfile
Aug 23 16:48:52 raspberrypi dnsmasq[665]: advertencia: interfase wlan0 no existe actualmente
Aug 23 16:48:52 raspberrypi dnsmasq-dhcp[665]: DHCP, IP range 192.168.10.3 -- 192.168.10.5, tiempo de concesión1d
Aug 23 16:48:52 raspberrypi dnsmasq[665]: leyendo /run/dnsmasq/resolv.conf
Aug 23 16:48:52 raspberrypi dnsmasq[665]: usando nombre de servidor 8.8.8.8#53
Aug 23 16:48:52 raspberrypi dnsmasq[665]: usando nombre de servidor 4.4.4.4#53
Aug 23 16:48:52 raspberrypi dnsmasq[665]: direcciónes /etc/hosts - 5 leídas
Aug 23 16:48:52 raspberrypi kernel: [ 20.096572] usb 1-1.2: New USB device found, idVendor=19d2, idProduct=1421, bcdDevice=50.15
Aug 23 16:48:52 raspberrypi kernel: [ 20.096590] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Aug 23 16:48:52 raspberrypi kernel: [ 20.096598] usb 1-1.2: Product: ZTE Mobile Broadband
Aug 23 16:48:52 raspberrypi kernel: [ 20.096606] usb 1-1.2: Manufacturer: ZTE,Incorporated
Aug 23 16:48:52 raspberrypi kernel: [ 20.096613] usb 1-1.2: SerialNumber: 1234567890ABCDEF
Aug 23 16:48:52 raspberrypi kernel: [ 20.098782] usb-storage 1-1.2:1.0: USB Mass Storage device detected
Aug 23 16:48:52 raspberrypi kernel: [ 20.101226] scsi host1: usb-storage 1-1.2:1.0
Aug 23 16:48:52 raspberrypi mtp-probe: checking bus 1, device 6: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2"
Aug 23 16:48:52 raspberrypi mtp-probe: bus: 1, device: 6 was not an MTP device
Aug 23 16:48:52 raspberrypi systemd[1]: Started OpenBSD Secure Shell server.
Aug 23 16:48:52 raspberrypi dnsmasq[666]: Too few arguments.
Aug 23 16:48:52 raspberrypi systemd[1]: Started dnsmasq - A lightweight DHCP and caching DNS server.
Aug 23 16:48:52 raspberrypi systemd[1]: Reached target Host and Network Name Lookups.
Aug 23 16:48:52 raspberrypi systemd[1]: Started LSB: Update dynamic domain name service entries.
Aug 23 16:48:52 raspberrypi systemd[1]: Started Lighttpd Daemon.
Aug 23 16:48:52 raspberrypi ddclient[725]: WARNING: file /var/cache/ddclient/ddclient.cache, line 4: Invalid Value for keyword 'ip' = ''
Aug 23 16:48:52 raspberrypi ddclient[725]: WARNING: skipping update of www.con-ip.com/actualiza_subdominio.php?subdominio=meteo&user=chve&id=98c094ff839ccac735274b545982858b from <nothing> to 192.168.0.2.
Aug 23 16:48:52 raspberrypi ddclient[725]: WARNING: last updated <never> but last attempt on Mon Aug 23 16:44:34 2021 failed.
Aug 23 16:48:52 raspberrypi ddclient[725]: WARNING: Wait at least 5 minutes between update attempts.
Aug 23 16:48:52 raspberrypi dhcpcd[637]: wlan0: soliciting an IPv6 router
Aug 23 16:48:53 raspberrypi kernel: [ 21.116696] scsi 1:0:0:0: CD-ROM ZTE USB SCSI CD-ROM 2.31 PQ: 0 ANSI: 2
Aug 23 16:48:53 raspberrypi kernel: [ 21.117191] scsi 1:0:0:0: Attached scsi generic sg1 type 5
Aug 23 16:48:53 raspberrypi kernel: [ 21.119439] scsi 1:0:0:1: Direct-Access ZTE MMC Storage 2.31 PQ: 0 ANSI: 2
Aug 23 16:48:53 raspberrypi kernel: [ 21.121574] sd 1:0:0:1: Power-on or device reset occurred
Aug 23 16:48:53 raspberrypi kernel: [ 21.125277] sd 1:0:0:1: Attached scsi generic sg2 type 0
Aug 23 16:48:53 raspberrypi kernel: [ 21.140459] sr 1:0:0:0: Power-on or device reset occurred
Aug 23 16:48:53 raspberrypi kernel: [ 21.148479] sr 1:0:0:0: [sr0] scsi-1 drive
Aug 23 16:48:53 raspberrypi kernel: [ 21.148495] cdrom: Uniform CD-ROM driver Revision: 3.20
Aug 23 16:48:53 raspberrypi kernel: [ 21.193585] sd 1:0:0:1: [sdb] Attached SCSI removable disk
Aug 23 16:48:53 raspberrypi kernel: [ 21.205511] sr 1:0:0:0: Attached scsi CD-ROM sr0
Aug 23 16:48:57 raspberrypi dhcpcd[637]: wlan0: using static address 192.168.10.1/24
Aug 23 16:48:57 raspberrypi avahi-daemon[495]: Joining mDNS multicast group on interface wlan0.IPv4 with address 192.168.10.1.
Aug 23 16:48:57 raspberrypi dhcpcd[637]: wlan0: adding route to 192.168.10.0/24
Aug 23 16:48:57 raspberrypi avahi-daemon[495]: New relevant interface wlan0.IPv4 for mDNS.
Aug 23 16:48:57 raspberrypi avahi-daemon[495]: Registering new address record for 192.168.10.1 on wlan0.IPv4.
Aug 23 16:48:57 raspberrypi systemd[1]: Started LSB: web-based administration interface for Unix systems.
Aug 23 16:48:57 raspberrypi systemd[1]: Reached target Multi-User System.
Aug 23 16:48:57 raspberrypi systemd[1]: Reached target Graphical Interface.
Aug 23 16:48:57 raspberrypi systemd[1]: Starting Update UTMP about System Runlevel Changes...
Aug 23 16:48:57 raspberrypi systemd[1]: Started Wvdial GSM Modem.
Aug 23 16:48:57 raspberrypi systemd[1]: systemd-update-utmp-runlevel.service: Succeeded.
Aug 23 16:48:57 raspberrypi systemd[1]: Started Update UTMP about System Runlevel Changes.
Aug 23 16:48:57 raspberrypi systemd[1]: Startup finished in 4.135s (kernel) + 20.953s (userspace) = 25.088s.
Aug 23 16:48:57 raspberrypi wvdial[757]: --> WvDial: Internet dialer version 1.61
Aug 23 16:48:57 raspberrypi wvdial[757]: --> Cannot open /dev/ttyUSB1: No such file or directory
Aug 23 16:48:57 raspberrypi systemd[1]: wvdial.service: Main process exited, code=exited, status=1/FAILURE
Aug 23 16:48:57 raspberrypi systemd[1]: wvdial.service: Failed with result 'exit-code'.
Aug 23 16:48:57 raspberrypi systemd[1]: wvdial.service: Service RestartSec=100ms expired, scheduling restart.
Aug 23 16:48:57 raspberrypi systemd[1]: wvdial.service: Scheduled restart job, restart counter is at 1.
Aug 23 16:48:57 raspberrypi systemd[1]: Stopped Wvdial GSM Modem.
Aug 23 16:48:57 raspberrypi wvdial[758]: --> WvDial: Internet dialer version 1.61
Aug 23 16:48:57 raspberrypi wvdial[758]: --> Cannot open /dev/ttyUSB1: No such file or directory
Aug 23 16:48:57 raspberrypi systemd[1]: wvdial.service: Scheduled restart job, restart counter is at 2.
Aug 23 16:48:57 raspberrypi wvdial[759]: --> WvDial: Internet dialer version 1.61
Aug 23 16:48:57 raspberrypi wvdial[759]: --> Cannot open /dev/ttyUSB1: No such file or directory
Aug 23 16:48:58 raspberrypi systemd[1]: wvdial.service: Service RestartSec=100ms expired, scheduling restart.
Aug 23 16:48:58 raspberrypi systemd[1]: wvdial.service: Scheduled restart job, restart counter is at 3.
Aug 23 16:48:58 raspberrypi systemd[1]: Stopped Wvdial GSM Modem.
Aug 23 16:48:58 raspberrypi systemd[1]: Started Wvdial GSM Modem.
Aug 23 16:48:58 raspberrypi wvdial[765]: --> WvDial: Internet dialer version 1.61
Aug 23 16:48:58 raspberrypi wvdial[765]: --> Cannot open /dev/ttyUSB1: No such file or directory
Aug 23 16:48:58 raspberrypi systemd[1]: wvdial.service: Main process exited, code=exited, status=1/FAILURE
Aug 23 16:48:58 raspberrypi systemd[1]: wvdial.service: Failed with result 'exit-code'.
Aug 23 16:48:58 raspberrypi systemd[1]: wvdial.service: Scheduled restart job, restart counter is at 4.
Aug 23 16:48:58 raspberrypi wvdial[773]: --> WvDial: Internet dialer version 1.61
Aug 23 16:48:58 raspberrypi wvdial[773]: --> Cannot open /dev/ttyUSB1: No such file or directory
Aug 23 16:48:58 raspberrypi kernel: [ 26.308124] usb 1-1.2: USB disconnect, device number 6
Aug 23 16:48:58 raspberrypi systemd[1]: wvdial.service: Scheduled restart job, restart counter is at 5.
Aug 23 16:48:58 raspberrypi systemd[1]: wvdial.service: Start request repeated too quickly.
Aug 23 16:48:58 raspberrypi systemd[1]: Failed to start Wvdial GSM Modem.
Aug 23 16:48:59 raspberrypi kernel: [ 26.884452] usb 1-1.2: new high-speed USB device number 7 using dwc_otg
Aug 23 16:48:59 raspberrypi kernel: [ 27.026576] usb 1-1.2: New USB device found, idVendor=19d2, idProduct=1282, bcdDevice=50.15
Aug 23 16:48:59 raspberrypi kernel: [ 27.026592] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Aug 23 16:48:59 raspberrypi kernel: [ 27.026600] usb 1-1.2: Product: ZTE Mobile Broadband
Aug 23 16:48:59 raspberrypi kernel: [ 27.026608] usb 1-1.2: Manufacturer: ZTE,Incorporated
Aug 23 16:48:59 raspberrypi kernel: [ 27.026615] usb 1-1.2: SerialNumber: 1234567890ABCDEF
Aug 23 16:48:59 raspberrypi kernel: [ 27.030849] usb-storage 1-1.2:1.4: USB Mass Storage device detected
Aug 23 16:48:59 raspberrypi kernel: [ 27.031285] scsi host1: usb-storage 1-1.2:1.4
Aug 23 16:48:59 raspberrypi mtp-probe: checking bus 1, device 7: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2"
Aug 23 16:48:59 raspberrypi mtp-probe: bus: 1, device: 7 was not an MTP device
Aug 23 16:48:59 raspberrypi kernel: [ 27.097403] usbcore: registered new interface driver usbserial_generic
Aug 23 16:48:59 raspberrypi kernel: [ 27.097476] usbserial: USB Serial support registered for generic
Aug 23 16:48:59 raspberrypi kernel: [ 27.114230] usbcore: registered new interface driver option
Aug 23 16:48:59 raspberrypi kernel: [ 27.114287] usbserial: USB Serial support registered for GSM modem (1-port)
Aug 23 16:48:59 raspberrypi kernel: [ 27.116253] option 1-1.2:1.0: GSM modem (1-port) converter detected
Aug 23 16:48:59 raspberrypi kernel: [ 27.116598] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB0
Aug 23 16:48:59 raspberrypi kernel: [ 27.116909] option 1-1.2:1.1: GSM modem (1-port) converter detected
Aug 23 16:48:59 raspberrypi kernel: [ 27.117171] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB1
Aug 23 16:48:59 raspberrypi kernel: [ 27.117457] option 1-1.2:1.2: GSM modem (1-port) converter detected
Aug 23 16:48:59 raspberrypi kernel: [ 27.117707] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB2
Aug 23 16:48:59 raspberrypi kernel: [ 27.118006] option 1-1.2:1.3: GSM modem (1-port) converter detected
Aug 23 16:48:59 raspberrypi kernel: [ 27.118829] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB3
Aug 23 16:49:00 raspberrypi dhcpcd[637]: eth0: no IPv6 Routers available
Aug 23 16:49:00 raspberrypi kernel: [ 28.076779] scsi 1:0:0:0: CD-ROM ZTE USB SCSI CD-ROM 2.31 PQ: 0 ANSI: 2
Aug 23 16:49:00 raspberrypi kernel: [ 28.085053] sr 1:0:0:0: [sr0] scsi-1 drive
Aug 23 16:49:00 raspberrypi kernel: [ 28.156517] sr 1:0:0:0: Attached scsi CD-ROM sr0
Aug 23 16:49:00 raspberrypi kernel: [ 28.157570] sr 1:0:0:0: Attached scsi generic sg1 type 5
Aug 23 16:49:00 raspberrypi kernel: [ 28.205955] scsi 1:0:0:1: Direct-Access ZTE MMC Storage 2.31 PQ: 0 ANSI: 2
Aug 23 16:49:00 raspberrypi kernel: [ 28.207451] sd 1:0:0:1: Attached scsi generic sg2 type 0
Aug 23 16:49:00 raspberrypi kernel: [ 28.209819] sd 1:0:0:1: Power-on or device reset occurred
Aug 23 16:49:00 raspberrypi kernel: [ 28.257985] sd 1:0:0:1: [sdb] Attached SCSI removable disk
que cosas ehh!!!...
Egrueda, ¿y si hacemos que ejecute el script en vez del demonio en el arranque?... Seria otra alternativa, ¿no?...
