Recalbox 4.1 unstable (google drive) rpi 2/3
- darkallan
probaré desde una instalación limpia la versión estable 4.1 de recalbox, pero no creo que me haga cambiar retropie 4.3 con kodi 17.4 :roll: (aparte no tiene nintendo ds entre sus emuladores :lol: )
- cpcbegin
- Agradecido: 35 veces
- Agradecimiento recibido: 24 veces
Ya le he estado probando, con respecto a la 4.1 unstable por ahora he visto emulación de Commodore 64 y Apple II y una más completa traducción al castellano de los menús, el kodi sigue siendo el 16, pero con respecto a la 4.0 hay muchas más novedades:
## [4.1.0] - 2017-10-13
- Pad: added Microsoft Xbox One S & Elite default mapping
- fix regression in splash video for pi
- BT: no more permanent background scan, just powerup hci0
- Splash video for Odroid XU4 and C2 + updated recalbox splash logo
- Snes9x_next: added a rule to enable multitap support only if there is at least 3 gamepads connected
- Bump virtual gamepad
- Add a script to easily update various package types
- PPSSPP: SNES-like pads can navigate in the menu + add retroarch-like combos
- X86: added xrandr to be able to manually manage video outputs
- X86: disabled screensaver (dpms)
- Commodore 64: added libretro-vice core (by default)
- X86: fixed issue that prevents retroarch shaders to work
- X86: fixed issue that stucks OpenGL on version 2.1
- Added DS4 and NES30 default config in es_inputs.cfg
- X86: now able to flash and boot x86 images on internal hard drive
- Updated libretro-cheats
- reicast: bump + fix RTC clock
- Bump retroarch to solve pad reordering issue
- psp: saves now go to the right folder
- Enhanced gliden64 video plugin configuration
- Pad : added FuSa GamePad Version 0.3 (PSP homebrew) default mapping
- Added noobs integration in archive images
- New review upgrade system
- New video render for retroarch: dispmanx (pi only)
- Bumped Mupen64plus-GlideN64 video plugin to the Public Release 2.0
- Fixed joystick sensitivity issue with mupen64plus
- MAJOR BLUETOOTH CHANGE: users upgrading from 4.0 MUST PAIR AGAIN their controllers
- BT: add a manual fix for xiaomi gamepad
- deploys updates as docker containers
- fixed a BT scan bug
- bump configgen : remove moonlight config files before writing them + 5th moonlight player, remove commas in pad name
- BlueMSX: added F3/F4 buttons on gamepad
- BlueMSX: added .dsk files support
- Amstrad CPC (libretro-cap32 core): Fixed gamepads support + 2 players support + GUI menu
- fixed Nintendo Wiimote sending multiples events
- fix saving recalbox.conf when the same key exists multiple times
- Pad: add idroid default mapping
- added recalbox as default CEC name on rpi
- improve moonlight package
- rewrite usb quirks
- odroic c2: enable H264 hardware decoding
- xarcade: delay the startup of the driver
- xarcade: disable predefined combo keys
- remove unwanted Kodi plugins
- fix upgrade 4.0 -> 4.1 with the share on a FAT32 USB device
- BT : improve startup, pairing and forgetting devices
- Add support for RPI0-W
- advancemame : bump to 3.4 and disable keyboard to prevent a crash when no keyboard is plugged
- Timezone change fixed
- increase the number of inodes for .img
- Better upgrade information
- Update CHANGELOG.md for nicer upgrade logs
- Show progression while downloading an update
- fix lynx core name
- appleII: fix known file extensions
- adding new kernel patch to support natively xinmo 20pins usb encoder
- fix webmanager2's dependencies
- fix sound regression since handling of multiple cards
- Fix muted sound on boot
- samba: definitely remove printer support
- improve CI output + better error logging on failed build
- fix gamecon 1.2
- configgen: scummvm: added fullscreen option
- configgen: libretroConfig.py: would crash when retroarchcustom.cfg didn't exist
- configgen: added n64 to systems not supporting rewind
- configgen: Fix PPSSPP for any pad
- recalbox-manager2: add new locales, stop and restart ES works again
- Solve a bug on .img compression
- Automatically update XBox360 pads configuration for ES
- Force a 2GB root size for .img
- Compress .img in xz
- Don't forget bluetooth paired devices on upgrade
- Proper restart of Emulationstation
- add locales to recalbox-manager2
- Improve sound management when running multiple sound cards
- Bumped recalbox-manager2 to v2.0
- Carefully compare versions to verify if an update is available
- Add a generic SNES pad configuration
- Add Logitech F310 Direct Input mode configuration
- Add Logitech F310 XInput mode (which is recommended) configuration
- Upgrade retroarch config files
- Added Latvian support
- Added Luxembourgish support
- fix missing roms + configs subfolders creation
- fix recalbox.conf not being upgraded
- improve BT connectivity
- fixed black screen on systems with new configgen version
- added Czech language support
- run v2 of manager if version not found in recalbox.conf
- fixed emulationstation.forcebasicgamelistview
- add tft waveshare 3.2 and 3.5 overlays + fbcp program to support them
- add pwm-audio-pi-zero overlay to get audio thanks to PWMs through GPIO Pins 18 and 13 on an Pi Zero equivalent to dtoverlay=pwm-2chan,pin=18,func=2,pin2=13,func2=4
- new web manager
- add rgb-pi overlay
- fixed rgb-pi overlay
- checksum on upgrades, progression percentage much more accurate
- Bump to Bump rpi-userland 8e84b9003d8259472f9c79b385443b1b4975203e and rpi-firmware b365edad4e75126fb9bfee2325652758407e4f74 to change be able to change video résolution on the fly via the vcgencmd command. This will be very useful the get pixel perfect on rgb screen
- Fixing BT firmware copy for Realtek BT devices (81xx 87xx and 88xx)
- Fixing Makelfiles for compilation of libretro-lutro for the bump to release 2377dd37ad3bd37ddef9fc37742bba2531a78407
- Bump retroarch to last release due to integration of libretro-imageviewer in its cores, and delation of the libretro-imageviewer repos
- Update Mame2003 core to get the mame2003-skip_warnings and avoid splash screen
- New emulator : PPSSPP
- Add Mayflash NES/SNES and SEGA SATURN in usbhid.conf
- Added omxplayer to enable Introduction video
- Updated recalbox-configgen to version 4.1.X
- Added linapple-pie to recalbox-rpi3_defconfig
- Added support for vice 2.4.24. This means support for commodore c64 and other commodore systems
- Added theme for commodore c64
- Added two demo ROMs for commodore c64
- Add linapple specific parameters to start fixing an issue.
- Added user's configuration files upgrade
- Merged buildroot upstream
- Added retroachievements hardcore mode
- Add omxplayer to rpi2 & rpi3 defconfig
- Add Kodi default plugins/repositories
- Improved S02splash script for video splash
- linapple-pie download redirected to LaurentMarchelli
- passed to gcc5
- Added pgrep to busybox for omxplayer extensions
- New video version and splash video now stopped when kodi is started
- Added custom ratio per game option
- Dbus implementation to have fade out effect on splash video
- Added Witty Pi powerswitch support with Wiring Pi.
- Network connection manager : ethernet configuration on wire connection
- Network connection manager : multiple wifi configurations
- Wifi : open/wep/wpa/wpa2
- New emulator : reicast
- Bumped retroarch to v1.3.4
- Added retroachievements support to fceunext core
- Reicast : add multiplayer support
- Bump moonlight-embedded to 2.2.3, adds support for GFE 3.3
- Added enet library for moonlight-embedded-2.2.0
- Solved a bug on xarcade where B and HOTKEY were sending the same event
- Slide transition by default in ES
- Power management switch support (power,reset and LED) for pin 3/5/6
- Add ifconfig -a and /boot/recalbox-boot.conf in recalbox-support.sh
- S99Custom now trasmits its init parameter to custom.sh
- Add ipega 9021 rules
- ES now shutdowns the system
- share/roms/saves/bios available via a network point
- bumped SDL to 2.0.4
- disable multitouch axis in SDL 2.0.4
- linux kernel bumped to 4.4.13
- Add new Traditional Chinese Language
- Add DosBox 0.74 (rev 3989) with specific patches: SDL2, with mapping of mouse and all axis of joysticks
- Add lutro extension
- Add a recalbox.conf option to set a video mode only for es
- Add Catalan translation
- Check space left before update
- Added ColecoVison support to bluemsx libretro core
- Added the alternative N64 core GLupeN64 on rpi2/rpi3
- Added IPF format support to libretro-hatari (atarist ST)
- Reenable mp3 support for SDL2 mixer.
- Updated libretro-fba core from FBA 0.2.97.37 to FBA 0.2.97.39
- Added Mad Catz C.T.R.L.R udev rules
- Add configs to recalbox-support.sh
- Add firmwares ASUS BT400 and Qualcomm Atheros AR3011 BT3.0
- S50dropbear kills existing SSH connection at stop
- Add support for PS4 Dualshock4 bluetooth controllers
- Updated gamecon driver from 1.0 to 1.2
- Solve the loading of the DB9 driver
- N64 configgen shouldn't crash anymore if some keys are not mapped
- Add xin-mo 20pins players and ipega 9028
- Add new languages : arabic dutch greek korean norwegian norwegian bokmål polish
- Support PI3 internal bluetooth via bluez5
- Add USB PS2 : GreenAsia Electronics
- PSX: .bin extentions removed (use .cue instead)
- Enable highscores for fba_libretro
- Add mame parent only dat file
- Add ipega pg 9055 rules
- Add xin-mo 18pin, mayflash N64 and correction usbhid
- Add usbhid for Retrobit Genesis to PC USB Adapter
- new arcade emulator: AdvanceMame
- 7z support for fba_libretro
- Synced with buildroot 2016.11
- Added GNU diffutils
- Now shows changelog when updating the system
- Added snes9x libretro core (MSU-1 support)
- Patched xpad driver to support Xbox One S / Elite controllers in USB mode
- Patched xpad driver to fix the blinking xbox leds
- Build on gitlab ci
- Added emulationstation.hidesystemview option in recalbox.conf to hide system view
- Added emulationstation.selectedsystem option in recalbox.conf to select a system on boot
- Added emulationstation.bootongamelist to boot on the system gamelist
- Added emulationstation.gamelistonly to improve boot time
- Bumped libretro cores on last version
- Added Japanese, Russian and Hungarian languages
- Bumped virtualgamepads version - virtualkeyboard now available
- Add usb encoder 3H-Dual-Arcade, Mayflash dreamcast adapter
- Added "Joe Contre Les Pharaons" Amstrad CPC homebrew
- Added RPI3 overclock presets + warning popup if TURBO/EXTREM
- Add support for smb and upnp protocols in Kodi
- Removed xboxdrv driver - broken since kernel's bump
- Deactivated rumble support in pcsx core - causes endless vibrations problems
- Bumped pcsx core - added an option to enable bios splashscreeen (may broke some games - disabled by default)
- Add usbhid quirk for AJ 2 USB 2.4G sans fil manettes (ShanWan Twin USB Joystick PS3)
- Added ScummVM on X86, X86_64, odroid c2 and odroid xu4
- fix gamecon 1.2
- new web manager
- passed to gcc5
