RattyDAVE-v2 RetroPie Imagen. 16/12/16 (PI Zero, PI 1, PI 2, y PI 3)
Publicado: 19 Dic 2016, 00:48
por Kike
Aquí os dejo una imágen reciente para Raspberry Pi compatible con :
¡Es necesario una tarjeta de 128GB!
The Ultimate RetroPie Setup!
RATTYDAVE-V2
This is a Raspberry Pi Image containing a fully setup
Attract Mode,
Emulation Station,
Bezels, shaders.
Full artwork.
All your favorite 8 bit and Retro games in one handy image.
All the classic Arcade games (MAME)
Atari 2600
Atari 7800
Atari Lynx
MSX
MSX2
Nintendo Gameboy
Nintendo Gameboy Color
Nintendo Gameboy Advance
Nintendo Virtual Boy
Nintendo NES
Nintendo Famicom
Nintendo SNES
Nintendo N64
Neo Geo
Neo Geo Pocket
Neo Geo Pocket Color
Sega SG-1000
Sega Master System
Sega Genesis / Megadrive
Sega 32X
Sega CD
Sony Playstation
Sony PSP Mini
SuperGrafx
TurboGrapx-16
New emulators and recompiled ... bezels, shaders, web front end. advmame is not used any more.
duplicate roms removed.. over clocked too..
missing roms added ...
all set up for 1080 displays...
bezals and shaders can be removed.
This will run on a
PI Zero, PI 1, PI 2, and PI 3.
All emulators compiled from source.
Latest Kernel 16/12/2016
Torrent para Descargar Imagen:
Re: RattyDAVE-v2 RetroPie Imagen. 16/12/16 (PI Zero, PI 1, PI 2, y PI 3)
Publicado: 19 Dic 2016, 01:02
por kpi
Que sepa todo el mundo,para que no se vuelva locos,que es la imagen famosa de "Rey" pero mejorada,con muchos de sus fallos ya resueltos.
This contains the latest retropie compiled from source, kernel updates and all package updates up to 15th Dec 2016.
I have tried the new kernel 4.8 and at this time it does not work with retropie. OpenGL errors and failure to run when recompiled.
This image contains customised shaders and bezels. This is all setup for a 1080 screen. The Shader and Bezel script is customised for this image. It also contains options to remove, change the shaders and bezels.
*** Expand File system ****
Press ESCAPE on keyboard and quit.
At the prompt type
sudo raspi-config
Select option 1 and reboot.
*** Set up wifi ***
In attract mode press D and select "Attract Mode Setup"
Select "RetroPie Setup" from menu.
In the next menu select "C Configuration / tools"
then (at the bottom) "830 wifi - Configure Wifi"
then follow the instructions.
** Setting up the controls. ***
1) Attract Mode.
To change in attract mode. Plug a keyboard in and press ESC. Select Controls.
Here you will see BACK, UP, DOWN, LEFT, RIGHT and SELECT are defined.
Go into each of them and press ADD INPUT. Then press the button/move joystick.
2) Emulationstation.
Select "Emulationstation" from menu.
This should then ask for the controller config.
Once done exit emulation station.
3) Controller issues.
If the above does not work you may need to clear the controller config by the following.
Exit Attract Mode to the terminal by pressing ESCAPE on the keyboard.
At the prompt type:
rm ~/.emulationstation/es_input.cfg
emulationstation
This will delete the config file for emulationstation and then start emulation station and then it will ask you to set up the controller. Once done you can then Reboot and this will take you back to Attract Mode.
************ TESTING ***************
If you have issues with your controller config then from Attract mode.
Run
/opt/retropie/emulators/advmame/1.4/bin/advj
Here you SHOULD see all the joysticks and buttons that are attached. Pres CTRL-C to exit.
Publicado: 19 Dic 2016, 01:33
por Jorgeuk
Si es la de Rey mejorada faltan emuladores en la lista y nunca se uso adv mame en la de Rey. que no digo que no lo sea pero algo no cuadra
Publicado: 19 Dic 2016, 01:44
por kpi
Tengo ahora mismo la de Rey delante y usa adv-mame,quizas tengamos versiones diferentes....pero la mia va asi.
pd : aparte que he hablado con el tal Dave y me ha comentado varios de los cambios y que su "base" es la de Rey.
Publicado: 19 Dic 2016, 06:50
por NQ78
Mmm pinta bien entonces, no? Habrá que bajarla y probarla!
Publicado: 19 Dic 2016, 22:54
por NQ78
Pero si en MAME hay juegos con multiples versiones, bootlegs, etc... ¿no decían que esos los habían quitado? El mando PRO de Wii U no se me acaba de configurar correctamente..
Voy a volver a usar la v3.1 By LuciFeR & Solrac, que tiene menos juegos pero está muy pero que muy currada, con fondos personalizados para muchas recreativas, filtros muy chulos, y me funcionaba todo perfectamente.
Publicado: 19 Dic 2016, 23:18
por NQ78
cosgarion escribió:cosgarion escribió:NQ78 escribió:Pero si en MAME hay juegos con multiples versiones, bootlegs, etc... ¿no decían que esos los habían quitado? El mando PRO de Wii U no se me acaba de configurar correctamente..
En eso si está bien. No están quitados los clones dentro del listado de ES pero desde AM las listas están limpias. Por lo menos lo que yo he mirado en MAME. Por ejemplo solo hay uno de cada de: 1941 - 1942 - 1943 -1943 kai - 1945 III, eso cuadra con listas limpias.
Yo veo que esta imagen tiene problemas. Los videos en gris como la de REY, aleatorio, y luego muchos juegos no van. Por ejemplo 1943 desde AM no funciona.
Por mi parte no la recomiendo, lo mejor que tiene son las listas personalizadas.... que las voy a copiar aparte
una duda, esa de lucifer y solrac solo era de Retropie, sin attract mode ¿verdad?
Si, solo Emulation Station. Estaría genial con Attract Mode tambien, pero no lo tiene.
Publicado: 20 Dic 2016, 18:11
por kpi
Eso googleando un poco es facil de solucionar,simplemente cambiando el decoder de video.
Publicado: 22 Dic 2016, 15:51
por ericpower91
¿Cuáles son las contraseñas para conectarse con FileZilla favor
Publicado: 22 Dic 2016, 16:12
por kpi
ericpower91 escribió:¿Cuáles son las contraseñas para conectarse con FileZilla favor
¿para conectarse a tu pi?
usuario pi
pass raspberry
Publicado: 22 Dic 2016, 19:18
por ericpower91
Rattydave Buenas noches y gracias por la rápida respuesta y su trabajo .Soy francés y no habla muy bien el español. es conectar mi frambuesa pi es mi PC con FileZilla o putty :adios .
psfreire84
Publicado: 23 Dic 2016, 00:14
por psfreire84
Hola buenas!
Me encanta el aspecto visual de esta imagen y las listas. Pero tengo un gran problema y es que no logro configurar correctamente el mando de la xbox 360. Soy incapaz. He probado desde emulestation, lo configuro correctamente pero reinicio de nuevo en attrac mode y muchos de los botones del mando son inútiles de tal forma que no puedo jugar.
Agradezco la ayuda. Un saludo.
Publicado: 24 Dic 2016, 01:19
por Maligno
Yo sigo bajando la imagen dar las gracias a kike por ponerla y a rattydave por el trabajo que se ha pegado
Enviado desde mi Redmi Note 3 Pro mediante Tapatalk
Publicado: 25 Dic 2016, 16:44
por mottarj
Yo uso un control genérico USB (Dragonrise) y no es posible operar el (SEL + start) para salir del juego. He hecho todos los ajustes. = (
Publicado: 28 Dic 2016, 11:21
por juandyzz
Hola a todos , me he bajado la imagen y la he grabado a una SD de 128GB y en principio la grabacion dio OK,
El problema es que arranca con el logo de retropie y luego carga un video de AM y entra en este modo.
No la he expandido aun pero puedo ver en el prompt de carga que cuando va a vargar el video de AM hay como 2 ficheros que dan error intentando como cargar un video , se ve que no los encuentra en esas carpetas y carga uno simple de AM.
Es esto normal?, debria de dar esos errores el prompt de que no puede cargar esos videos?
muchas graicas y FELICES FIESTAS!!!!
:roll:
Publicado: 31 Dic 2016, 05:27
por Rene Gallegos
Hola consulta a alguien le pasa que despues de agregar la pantalla principal de menu se borre yo la tenia toda configurada y ahora me toca cargar la imagen nuevamente aqui les dejo el proceso que ocupe para agregar la pantalla de menu principal
https://www.youtube.com/watch?v=9cmLjCjWxRQ
Aqui resumidos los comando a ejecutar una vez fuera de del Attract Mode
cd
mkdir develop
git clone --depth 1
https://github.com/mickelson/attract attract
cd attract
make USE_GLES=1
sudo make install
cd
rm -r -f develop
