Error con NGINX al tratar de instalarlo
Publicado: 13 May 2020, 14:28
por borislf
Hola amigos necesito instalar nginx en mi Pi por ser indispensable para poner una solución POS en mi Raspberry pero no lo logro, pongo aquí debajo lo que devuelve a ver si alguien más entendido en el tema, que yo que soy un neófito me podrá ayudar.
Desde ya gracias por adelantado y Cuídense.
Setting up nginx-full (1.10.3-1+deb9u3) ...
Job for nginx.service failed because the control process exited with error code.
See "systemctl status nginx.service" and "journalctl -xe" for details.
invoke-rc.d: initscript nginx, action "start" failed.
● nginx.service - A high performance web server and a reverse proxy server
   Loaded: loaded (/lib/systemd/system/nginx.service; enabled; vendor preset: enabled)
   Active: failed (Result: exit-code) since Wed 2020-05-13 02:00:44 CDT; 71ms ago
     Docs: man:nginx(8)
  Process: 1805 ExecStart=/usr/sbin/nginx -g daemon on; master_process on; (code=exited, status=1/FAILURE)
  Process: 1802 ExecStartPre=/usr/sbin/nginx -t -q -g daemon on; master_process on; (code=exited, status=0/SUCCESS)
May 13 02:00:43 raspberrypi nginx[1805]: nginx: [emerg] bind() to [::]:80 fa…se)
May 13 02:00:43 raspberrypi nginx[1805]: nginx: [emerg] bind() to 0.0.0.0:80…se)
May 13 02:00:44 raspberrypi nginx[1805]: nginx: [emerg] bind() to 0.0.0.0:80…se)
May 13 02:00:44 raspberrypi nginx[1805]: nginx: [emerg] bind() to [::]:80 fa…se)
May 13 02:00:44 raspberrypi nginx[1805]: nginx: [emerg] still could not bind()
May 13 02:00:44 raspberrypi systemd[1]: nginx.service: Control process exite…s=1
May 13 02:00:44 raspberrypi systemd[1]: Failed to start A high performance w…er.
May 13 02:00:44 raspberrypi systemd[1]: nginx.service: Unit entered failed s…te.
May 13 02:00:44 raspberrypi systemd[1]: nginx.service: Failed with result 'e…e'.
Hint: Some lines were ellipsized, use -l to show in full.
dpkg: error processing package nginx-full (--configure):
 subprocess installed post-installation script returned error exit status 1
dpkg: dependency problems prevent configuration of nginx:
 nginx depends on nginx-full (<< 1.10.3-1+deb9u3.1~) | nginx-light (<< 1.10.3-1+deb9u3.1~) | nginx-extras (<< 1.10.3-1+deb9u3.1~); however:
  Package nginx-full is not configured yet.
  Package nginx-light is not installed.
  Package nginx-extras is not installed.
 nginx depends on nginx-full (>= 1.10.3-1+deb9u3) | nginx-light (>= 1.10.3-1+deb9u3) | nginx-extras (>= 1.10.3-1+deb9u3); however:
dpkg: error processing package nginx (--configure):
 dependency problems - leaving unconfigured
Errors were encountered while processing:
 nginx-full
 nginx
E: Sub-process /usr/bin/dpkg returned an error code (1)
Por si es necesario mi Pi es modelo 3 B con Rasbian como SO.
Re: Error con NGINX al tratar de instalarlo
Publicado: 13 May 2020, 17:20
¿tienes algún otro programa usando el puerto 80? otro servidor web o similar?
Publicado: 13 May 2020, 17:41
por borislf
Tenía apache2 pero lo desinstale o al menos eso pensé debe de haberse quedado algo usando el puerto 80, que podré hacer??, Gracias
Publicado: 13 May 2020, 17:43
1. mira a ver si apache está corriendo
2. páralo si es así
3. mira a ver si el puerto 80 está abierto por algún otro programa
Publicado: 13 May 2020, 17:48
por borislf
No ya comprobé de seguro que apache no está corriendo, pero no sé la verdad como saber si otro programa está ocupando el puerto 80, disculpa mi ignorancia en el tema.
