Dietpi
Publicado: 21 May 2016, 00:10
por caracolgeek
Esta es una distribución de linux que solo esta para Orange Pi PC (tienen soporte también para otras marcas de placas). La Distro tiene un peso de 64 mb y viene pelada. En la distro viene preinstalado dietpi-software con la cual se puede instalar todo este software:
DietPi-Software:
Desktops:
- LXDE: Desktop - Highly optimized lightweight desktop without the "bloatware".
- LXDE: VNC Server - LXDE Desktop for remote connection.
Media Systems:
- Kodi - Media Centre / Player
- HiFi - Web Interface Music /Radio Player
- MiniDLNA - Media streaming server (DLNA, UPnP)
- SubSonic - Feature rich media streaming server with web interface.
- SqueezeBox - Also known as Logitech Media Server.
- SqueezeLite - Audio player for SqueezeBox.
- Ampache - Web interface media streaming server.
- Emby - Web interface media streaming server.
- Shairport Sync - AirPlay audio player with multiroom sync
- BruteFIR - EQ and Digital Room Correction via ALSA.
- Murmur - Mumble VoIP Server
BitTorrent:
- Transmission - Lightweight BitTorrent server with web interface
- Deluge - Alternative BitTorrent server with web interface
Gaming:
- OpenTyrian - Gaming
Camera / Surveillance:
- DietPi-Cam - RPi Camera / Web Interface Surveillance
Cloud / Backups:
- OwnCloud - Your own personal cloud based backup/data storage system
- Pydio - Feature-rich backup and sync server with web interface.
Social Media:
- Forums - phpbb3
- Wordpress - Website Blog and Publishing platform.
- Image Gallery - Host and browse your images from a web interface.
- BaiKal - Lightweight CalDAV + CardDAV server.
- OpenBazaar - Decentralized peer to peer market server using BitCoin.
WiFi HotSpot
- WiFi HotSpot - Turn your device into a wireless hotspot/access point.
- Tor HotSpot - Optional: Routes all WiFi HotSpot traffic through the Tor network.
Home Automation:
- EmonPi - Lightweight Energy usage stats with EmonPi PCB.
- Grasshopper - Web App to control Bticino MyHome
RPi Hardware Projects:
- RPi.GPIO - GPIO Interface library for RPi (python).
- WiringPi - GPIO Interface library for RPi (c).
- WebIOPi - Web interface to control RPi GPIO.
- I2c - Enables support for I2c based hardware.
Remote Access:
- Weaved - Access your device over the internet.
System Stats / Management:
- DietPi-Cloudshell - Lightweight system stats for your LCD display or monitor.
- Raspcontrol - Web interface system stats
- Linux Dash - Web interface system stats
- PhpSysInfo - Web interface system stats
- RPi Monitor - Web interface system stats
- NetData - Web interface system stats
System Security:
- Fail2Ban - Protects your system from brute-force attacks
Webserver Stacks:
- LAMP Webserver - Apache2 / MySql / PHP
- LASP Webserver - Apache2 / SQLite / PHP
- LAAP Webserver - Apache2 / MariaDB / PHP
- LEMP Webserver - Nginx / MySql / PHP
- LESP Webserver - Nginx / SQLite / PHP
- LEAP Webserver - Nginx / MariaDB / PHP
- LLMP Webserver - Lighttpd / MySql / PHP
- LLSP Webserver - Lighttpd / SQLite / PHP
- LLAP Webserver - Lighttpd / MariaDB/ PHP
- phpMyAdmin - Web interface SQL admin tool
- Lets Encrypt - Free, automated SSL cert creation and setup, allowing https.
DNS Servers:
- Pi-hole - A DNS/Web server that will block ads for any device on your network.
VPN Servers:
- OpenVPN - Easy to use, minimal hassle VPN server
Network Load Balancing:
- HaProxy - High performance TCP/HTTP load balancer.
Website URL's:
- NoIp - Website URL Address
File Server Choices:
- ProFTP - Simple, efficient, lightweight file server.
- Samba - Feature rich file server.
SSH Server Choices:
- Dropbear - Lightweight SSH Server
- OpenSSH - Feature rich SSH server with SFTP/SCP support.
Log System Choices:
- DietPi-Ramlog - Lightweight RAM logging.
- Full - Full logging system with Rsyslog and Logrotate.
Webserver Preference System:
- Apache2 - Feature-rich webserver
- Nginx - Lightweight webserver
- Lighttpd - Extremely lightweight webserver
Pre-Installed Applications:
dietpi-launcher (Select and Run any of the DietPi programs, all from one place.)
dietpi-config (Feature rich configuration tool for your device)
dietpi-software (Install optimized and ready to run software)
dietpi-uninstall (Allows you to uninstall DietPi software)
dietpi-update (Update your version of DietPi)
dietpi-backup -(Backup or restore your DietPi system)
dietpi-sync - (Allows you to sync/duplicate one directory to another).
dietpi-process_tool - (Tweak system wide nice/priority levels, for most software and processes).
dietpi-cleaner (Remove unwanted "junk" from your DietPi system and free up filesystem space)
dietpi-bugreport (Sends a bug report to DietPi)
dietpi-cron (Allows you to modify all start times for Cron Jobs)
dietpi-logclear (Keep ontop of your log files, features clearing and backup modes).
dietpi-morsecode (Converts a text file to morse code, then outputs to your screen)
dietpi-letsencrypt (Frontend for Lets Encrypt and DietPi integration)
htop (The only resource monitor you'll ever need)
DietPi-Ramlog #1 (Mounts /var/log to RAM. Saves your SD card writes, and, uses less than 0.1mb~ of RAM).
Dropbear (Lightweight SSH server)
Pre-Installed Scripts:
treesize (Shows current directory/file sizes, recursive)n
La verdad es que pinta bien aunque antes de nada habría que probarla primero.
Un par de vídeos de un portugués, el primero como se instala:
https://youtu.be/v03j_7yP-Rs
El segundo primer arranque y repaso de todas las opciones:
https://youtu.be/XLK5ZlY0Pmw
Re: Dietpi
Publicado: 26 Feb 2017, 20:17
por animexepo
Uff tiene de todo, en cuanto pueda la pruebo 8-)
Re: Dietpi
Publicado: 28 Feb 2017, 18:17
por Carlos38
yo la tengo instalada y funciona de maravilla en la opi pc plus 2 e
Re: Dietpi
Publicado: 23 Mar 2017, 02:01
por yusoy
Olas...
A mi me funciona bastante bien en una orangepi plus, aunque parece que esta bastante por hacer....
Quisiera consultaros un problema que tengo y es que no puedo ejecutar cualquier comando a traves de lirc y un mando a distancia, tengo la sensacion de que alg esta capado, pero no se muy bien como ni donde...
Lo digo porque los mismos comandos me funcionan perfectamente en una rasp3....por mas vueltas que he dado no he conseguido nada.
Lo mas extraño es que con el mando a distancia puedo reiniciar o apagar el sistema, por medio de comandos, pero no puedo ejecutar programas a traves de comandos...
Alguna idea?
Re: Dietpi
Publicado: 10 Abr 2017, 13:03
por Langostaman
Buenas!!
Yo acabo de instalarlo en rapsberry....sabeis como puedo actualizar el kodi?
gracias!!
Re: Dietpi
Publicado: 10 Abr 2017, 19:49
por tatxen
Puesto que DietPI está basado en Jessie no deberia haber problema en meter el repo de Pippleware y asi poder instalar Kodi 17.1
echo 'deb http://pipplware.pplware.pt/pipplware/dists/jessie/main/binary /' | sudo tee --append /etc/apt/sources.list.d/pipplware_jessie.list
wget -O - http://pipplware.pplware.pt/pipplware/key.asc | sudo apt-key add -
sudo apt-get update
sudo apt-get install kodi
Re: Dietpi
Publicado: 10 Abr 2017, 21:24
por Langostaman
Ya lo hice. Mil gracias!
:mrgreen:
Re: Dietpi
Publicado: 03 May 2017, 14:39
por Davitxito
Yo la tengo instalada y configurada con un monton de servicios. Todos corriendo estupendamente...me queda añadir alguno por mi mismo pero la verdad que falicita mucho las configuraciones
