Virtualman V3.0 Remix-Revamp Retropie+EmulationStation 128GB
Publicado: 07 Feb 2018, 14:21
por XeNoMoRPH
descarga: https://back-ups.me/details.php?id=376140
RELEASE NOTES (added on top of 2.0):
** EMPHASIS - TARGETED ALL DECADES 70's, 80's, 90's and 2000+ there is something for everyone that should bring back good memories! **
** EMPHASIS - TARGETED for future BUILDERS with the hope EmulationStation and Recalbox will team up to have the best of the best features all integrated into one system.
- Total 8005 console/arcade/ports/pc games (I DO NOT ENDORSE ANYONE MAKING ANY MONEY WITH THIS BUILD, ONLY FOR HOBBY AND TESTING PURPOSES!)
- Compressed all ROMS (zip) and CD based games (PBP,CHD,CSO)
- Managed to squeeze 120 PSX, 52 SegaCD, 4 Dreamcast and more Arcade games to keep the suspense/discovery.
- Added 6 Ports (Quake Bundle, Duke Nukem 3D & **BRUTAL DOOM!**)
- Note: Best experience with keyboard/mouse but controllers have limited functions and it works.
*Shout out to Randyslim76 for the support and recommendation!* You can all expand on much more ports/mods as you see fit.
- Added one unique PC game using stratagus to play "StarCraft - Brood War" - runs native and totally fun!
- Note: Best experience with keyboard/mouse.
- Completely revamp artwork with video snaps!(however I have retain all previous /boxart /cartart /wheel /snap, I can see ES providing view style to have boxart or mixart on the fly...)
- /mixart = 3 images (game screenshot, marquee/wheel & boxart)
- /boxart = 1 image (game boxart style)
*Special Notes: I added custom script that you can access from RPsetup menu that will allow you to switch /mixart to /boxart and vice versa.*
- Added few additional RetroPie Setup menu (Disable Music, Power Function, Switch artstyle (mixart/boxart) etc...)
- Fixed several Arcade games to boot and perform better. *Kudos to MadlittlePixel for the awesome support - emulators.cfg file was key with over 3000+ entries!
- Retain Custom Arcade Old School collection (160 games with custom overlays)
*Special Note: I added custom shaders "crt-curve for horizontal and vertical games) for only this collection. You can easily disable/enable this from RetroArch menus.
- All consoles & most Arcade use custom bezels/overlays (** NOTE: You can easily remove overlays **)
- You will need 128GB SD card, this is jammed pack - not much room left just under 1GB free.
- Updated all core packages to latest and greatest 4.3.10
- Fix lots of boxart/snaps (Spent 3 full days - I may have missed a few for Arcade only)
- My playlist music collection (not annoying but you can customize or disable for RPMenu)
- 5 top random splashscreen videos on boot (can customize)
- Added some preferred pre-loaded themes boxalloyred, greenalicious, crazycard and comicbook. All work well and tested.
*Special Notes: customized fonts for boxalloyred and added extra system for stratagus.
- Attract Mode removed /home/pi/.attract to save space
- Added extra custom launcher splashscreens (once you load a game)
EMULATIONSTATION FRONT-END BASICS:
- When in Game (for all consoles and Arcade):
START+SELECT (returns you back to EmulationStation)
X+SELECT (RetroArch configuration, ex: set overlays/bezels/shaders etc.)
- When in Game (for Scummvm)
CTRL+Q or F5 (returns you back to EmulationStation)
- When in Game for Ports and PC/Stratagus
X+SELECT will work only on few games, but you can easily quite from in game menu and it will take you back to ES.
TOOLS & TIPS:
1. Download and install SD Memory Card Formater
https://www.sdcard.org/downloads/form...
Note: This will format your SDCARD in fat32/extfat.
2. Download and install Win32 Disk Imager from this link:
http://sourceforge.net/projects/win32...
Note: This is the tool you will need to write img to your SDCARD
3. Plug the SD card to your Raspberry Pi3 and enjoy!
Note: Upon boot it should recognize any controller you may have plugged in via USB (it supports bluetooh as well). I personally use 8bitdo and rock solid. Make sure to assign your hotkey to be select.
TIPS:
- You can easily get to content/configs via network \\retropie or using sftp/filezilla account (pi/raspberry).
- If you want quick access to your SDCARD without a Raspberry Pi, any linux/chromebook can mount it and you will have full access to content.
RECOMMENDED HARDWARE:
- Raspberry Pi 3 + Power Adapter 2.5A combo - https://tinyurl.com/ybqnop6k
- snes pi case or nes pi + fan https://tinyurl.com/yb74s3zw
- 8bitdo controller - https://tinyurl.com/yb74s3zw
- Any controller works (xbox, playstation via bluetooth or usb)
- 128GB Sandisk SD card - https://tinyurl.com/y9ju4z4j
*SPECIAL ANNOUCEMENT: This is my last build and want to thank everyone on Discord, you-tube, INTERNET in general for all the help/support!
I really want to sit down and enjoy these games with friends/family!
I will remain on discord to provide guidance/support with your very own RetroPie/Recalbox/Emulationstation setup.
RetroPie + EmulationStation on Discord: https://discord.gg/nvFHyAj
BUILDS/VIDEOS (These videos do not justify the entire setup but you get an ideal. It's truly an experience once you have it loaded on your Raspberry Pie3.)
- DrewTalks official review Virtualman V2.0 Mix Build - https://youtu.be/bc0rBZcEO3Q
- DrewTalks official review Virtualman V1.0 PiStation Build - https://youtu.be/gOpuq8fOHKs
- Virtualman V3.0 Remix-Revamp showcase - https://youtu.be/76Bi295JfHI
- Virtualman V2.0 Mix showcase - https://youtu.be/gFJWK7d8WFo
- Virtualman V1.0 PiStation showcase - https://youtu.be/kBB7OUNGdAA
Re: Virtualman V3.0 Remix-Revamp Retropie+EmulationStation 128GB
Publicado: 08 Feb 2018, 23:28
por patillerox
¡Hola! ¿Hay modo de acceder al torrent de forma pública? :)
(lo digo por tratarse de un tracker privado, donde parece que, a mí al menos, el registro no me funciona :desesperado )
¡Gracias!
Publicado: 09 Feb 2018, 15:10
por XeNoMoRPH
de momento no que yo sepa :triste
Publicado: 09 Feb 2018, 16:23
por patillerox
No sé que ha pasado, que de repente ya me deja acceder.
Muchas gracias en cualquier caso :)
Publicado: 09 Feb 2018, 20:12
por Mikelco
patillerox escribió: 09 Feb 2018, 16:23 No sé que ha pasado, que de repente ya me deja acceder.
Como has accedido? Has creado una cuenta?
Publicado: 10 Feb 2018, 12:19
por electrico
La cuenta se hace en menos de 1 minuto.
Publicado: 11 Feb 2018, 13:19
por patillerox
¡Iep! sí, cree una cuenta.
Pero tardaron en activarla (lo deben hacer los admins de la página) más de día y medio.
La imagen está bastante bien, la verdad. Falta algún sistema (lynx, o atari 7800, entre otros), pero lo importante está todo :)
Publicado: 20 Feb 2018, 09:30
por AlberEspinosa
Buenas tengo un problema. Compré una tarjeta SD de 128 gb exclusivamente para esta imagen. Más concretamente compréla Tarjeta de memoria SanDisk Extreme microSDXC de 128 GB. Hago los pasos de siempre, tengo la imagen ya descargada en mi escritorio, uso el SD formatter para formatear en FAT32 la imagen y el quick en ON. Después uso el Wink32 image para grabar la imagen en la tarjeta y al darle a Write me sale un error de espacio. Miro el espacio y tengo 119 gb en la tarjeta, y la ISO ocupa exactamente 119 gb también. Sé que pierden algo de espacio pero no sé tengo la sensación que por muy poco espacio no me deja.
Lo intento más de una vez formatearla y hacerlo pero no hay manera.
Alguna solución rápida y sencilla para noob? No uso Linux y en el Raspberry me defiendo bastante mal si hay que meter comandos. Si es una solución a través de Windows lo agradecería.
Mucha gracias de antemano.
