el Sonido no funciona aparte la imagen se ve muy grande no tiene le tamaño de la tele
ya probé con una sd limpia me pasa lo mismo y aparte también cambie de distribución y sigue igual alguna solución
muchas gracias de antemano
# For more options and information see
# http://rpf.io/configtxt
# Some settings may impact device functionality. See link above for details
# Load the 64-bit kernel
arm_64bit=1
# Kernel
kernel=boot/linux
initramfs boot/initrd.lz4
# Firmware configurations
start_file=start.elf
fixup_file=fixup.dat
# sets the initial CEC name of the device
cec_osd_name=batocera
# uncomment will lead to "safe mode" settings being used to try to boot with maximum HDMI compatibility.
#hdmi_safe=1
# uncomment this if your display has a black border of unused pixels visible
# and your display can output without overscan
# at 0, it causes flickering on hdmi output
disable_overscan=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
# uncomment if hdmi display is not detected and composite is being output
#hdmi_force_hotplug=1
# uncomment the hdmi_group command which defines the HDMI output group to be either...
# 1 use CEA (Consumer Electronics Association, the standard typically used by TVs) or
# 2 use DMT (Display Monitor Timings, the standard typically used by monitors).
# This setting should be used in conjunction with hdmi_mode.
#hdmi_group=2
# uncomment to apply an appropriate CEA or DMT mode for your display
# see the web site below for valid options depending on the hdmi_group setting
# https://www.raspberrypi.org/documentati ... t/video.md
#hdmi_mode=4
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
#hdmi_drive=2
# uncomment will remove all other modes except the ones specified by hdmi_mode and hdmi_group from the internal list
# meaning they will not appear in any enumerated lists of modes.
# this option may help if a display seems to be ignoring the hdmi_mode and hdmi_group settings.
#hdmi_force_mode=1
# use this option to allow selection of 4k 60Hz refresh rates.
# note, this will increase power consumption and increase the temperature of the Raspberry Pi.
# it is not possible to output 4Kp60 on both micro HDMI ports simultaneously.
#hdmi_enable_4kp60=1
# forces the EDID content type to a specific value.
# the options are:
# 0 = EDID_ContentType_NODATA, content type none.
# 1 = EDID_ContentType_Graphics, content type graphics, ITC must be set to 1
# 2 = EDID_ContentType_Photo, content type photo
# 3 = EDID_ContentType_Cinema, content type cinema
# 4 = EDID_ContentType_Game, content type game
#edid_content_type=4
# if you plug your tv at the same time as your rpi and that the rpi switches from the hdmi or give a low resolution because tv had no enough time to initialize it
boot_delay=3
# uncomment to enable composite output via 4 pole TRRS ("headphone") socket.
# note: slightly slows down the entire system on Pi 4 models.
#enable_tvout=1
# uncomment for composite mode.
# 0 Normal NTSC (defult)
# 1 Japanese version of NTSC – no pedestal
# 2 Normal PAL
# 3 Brazilian version of PAL – 525/60 rather than 625/50, different subcarrier
# 16 Progressive scan NTSC
# 18 Progressive scan PAL
#sdtv_mode=2
# uncomment to define the wide aspect ratio for composite video output above.
# 1 4:3 (default)
# 2 14:9
# 3 16:9
#sdtv_aspect=3
# uncomment if you have slow sound issues on composite output
#audio_pwm_mode=0
# uncomment to pretend that all audio formats are supported by the display
# allowing passthrough of DTS/AC3 even when this is not reported as supported.
#hdmi_force_edid_audio=1
# uncomment to pretend that all audio formats are unsupported by the display.
# this means ALSA will default to the analogue audio (headphone) jack.
# hdmi_ignore_edid_audio=1
# uncomment to avoid the firmware parsing the EDID of any HDMI attached display
# that way the Linux video mode system (KMS) will then parse the EDID itself and pick an appropriate mode.
#disable_fw_kms_setup=1
# uncomment for lirc-rpi
#dtoverlay=lirc-rpi
# uncomment if you don't want the rainbow at startup
disable_splash=1
# enable UART (required for for retroflag)
# affect rpi performances
# enable_uart=1
# Uncomment some or all of these to enable the optional hardware interfaces
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
# Uncomment this to enable infrared communication.
#dtoverlay=gpio-ir,gpio_pin=17
#dtoverlay=gpio-ir-tx,gpio_pin=18
# Automatically load overlays for detected DSI displays
display_auto_detect=1
# Enable audio (loads snd_bcm2835)
dtparam=audio=on
# Enable bluetooth
dtparam=krnbt=on
# Enable DRM VC4 V3D driver
dtoverlay=vc4-kms-v3d
[DPI]
# Put any DPI required display code here
# i.e. Official 7" DSI Raspberry Pi Touch Display for 'Full' KMS
#ignore_lcd=1
#dtoverlay=vc4-kms-dsi-7inch
[all]
