Hola a tod@S!!!!
Hoy al entrar en el Menú de retropie --> Retropie Setup "Para instalar un Manege Packages" no soy capaz, he intentado ejecutar cualquiera de las opciones que aparecen en este menú pero siempre con el mismo resultado. Incluso he intentado entrar desde SSH y no hay manera. El resto de Menus "emuladores y ROMS" funcionan sin problemas.
Al ejecutar cualquiera de las opciones el resultado es el que os muestro y adjunto en archivo y vuelve nuevamente al menú:
pi@retropie:~ $ cd RetroPie-Setup
pi@retropie:~/RetroPie-Setup $ sudo ./retropie_setup.sh
Did not find needed dependencies: python3-pyudev dirmngr. Trying to install them now.
Hit:1 http://raspbian.raspberrypi.org/raspbian stretch InRelease
Hit:2 http://archive.raspberrypi.org/debian stretch InRelease
Reading package lists... Done
Building dependency tree
Reading state information... Done
You might want to run 'apt --fix-broken install' to correct these.
The following packages have unmet dependencies:
libsdl2-dev : Depends: libibus-1.0-dev but it is not going to be installed
Depends: libdbus-1-dev but it is not going to be installed
Depends: fcitx-libs-dev but it is not going to be installed
Depends: libsndio-dev
Depends: libxcursor-dev but it is not going to be installed
Depends: libxi-dev but it is not going to be installed
Depends: libxinerama-dev but it is not going to be installed
Depends: libxrandr-dev but it is not going to be installed
Depends: libxss-dev but it is not going to be installed
Depends: libxt-dev but it is not going to be installed
Depends: libxv-dev but it is not going to be installed
Depends: libegl1-mesa-dev but it is not going to be installed
Depends: libgles2-mesa-dev but it is not going to be installed
Depends: libgbm-dev but it is not going to be installed
python3-pyudev : Depends: python3-six but it is not going to be installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or speci fy a solution).
Unable to install packages required by /home/pi/RetroPie-Setup/retropie_packages.sh - Could not install package(s): python3-pyudev dirmngr.
Alguna solución!!!?
Muchas gracias!!!!
No me funcionan las opciones del menú de Retropie
Bueno, parece que tienes un problema de dependencias, a nivel de sistema operativo.
Prueba a hacer una actualización manual:
sudo apt-get update
Y luego:
sudo apt-get upgrade
A ver si el segundo comando (upgrade) te funciona bien o te da algún error.
sudo apt-get update
Y luego:
Sarpipet
Muchas gracias por tu respuesta!!egrueda escribió: 18 Ene 2021, 14:10 Bueno, parece que tienes un problema de dependencias, a nivel de sistema operativo.
sudo apt-get update
Y luego:
Pero tra seguir los pasos que me has indicado y ejecutar sudo apt-get upgrade, sigue sin funcionar. Adjunto captura.
Se te ocurre algo?. No tengo una imagen creada y la verdad que me fastidiaría bastante, porque le he echado muchas horas en todo lo que tengo configurado.
Muchas gracias una vez mas!!!!!
Mirando con más detalle los datos, veo que estás usando la vesión de Raspbian 9 (Stretch) pero la versión actual es la 10 (Buster)
Antes de hacer una actualización del sistema operativo completo, prueba lo que te indica en la pantalla:
sudo apt --fix-broken install
Eso intentará arreglar la base de datos de paquetes y sus dependencias.
P.D. Si no me equivoco, Raspbian 9 (Stretch) usa kernel 4.14 y raspbian 10 (Buster) usa kernel 4.19
Y tú usas stretch con kernel 4.19 xD
Parece que el paquete libsdl2-dev está atravesado...
Veamos si te deja borrarlo:
sudo apt-get remove --purge libsdl2-dev
