Re: Torrent Box 2021 (Transmission+Bazarr+Radarr+Sonarr+Prowlarr o Jackett)
Publicado: 19 May 2023, 20:02
que no pare la música...
hoy lo intento con la guía de la wiki de bazarr -> https://wiki.bazarr.media/Getting-Start ... nux/linux/
Indican que es necesario actualizar Python a 3.7 o superior (como conté en el capítulo anterior tengo la la 3.10.9).
Todo correcto hasta que ejecuto
En este paso revienta con:
lo he preguntado en el discord, pero deben estar en otros temas.
Next chapter soon(R)
python3 -m pip install -r requirements.txt
pi@choam:/opt/bazarr $ python3 -m pip install -r requirements.txt
Defaulting to user installation because normal site-packages is not writeable
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Requirement already satisfied: setuptools in /usr/lib/python3.10/site-packages (from -r requirements.txt (line 1)) (65.5.0)
Collecting lxml>=4.3.0 (from -r requirements.txt (line 2))
Using cached lxml-4.9.2-cp310-cp310-linux_armv7l.whl
Collecting numpy>=1.12.0 (from -r requirements.txt (line 3))
Using cached numpy-1.24.3-cp310-cp310-linux_armv7l.whl
Collecting webrtcvad-wheels>=2.0.10 (from -r requirements.txt (line 4))
Using cached webrtcvad_wheels-2.0.11.post1-cp310-cp310-linux_armv7l.whl
Collecting Pillow>=9.0.0 (from -r requirements.txt (line 5))
Using cached Pillow-9.5.0.tar.gz (50.5 MB)
Installing build dependencies ... done
Getting requirements to build wheel ... done
Preparing metadata (pyproject.toml) ... done
Building wheels for collected packages: Pillow
Building wheel for Pillow (pyproject.toml) ... error
error: subprocess-exited-with-error
× Building wheel for Pillow (pyproject.toml) did not run successfully.
│ exit code: 1
╰─> [198 lines of output]
running bdist_wheel
running build
running build_py
creating build
creating build/lib.linux-armv7l-cpython-310
creating build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/Jpeg2KImagePlugin.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/EpsImagePlugin.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/ImageCms.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/PdfParser.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/MpegImagePlugin.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/Hdf5StubImagePlugin.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/ImageEnhance.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/GimpPaletteFile.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/ImageGrab.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/ImageWin.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/PaletteFile.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/MpoImagePlugin.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/ImageStat.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/CurImagePlugin.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/features.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/ImageChops.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/JpegPresets.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/DdsImagePlugin.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/ImageColor.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/FitsImagePlugin.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/GbrImagePlugin.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/WmfImagePlugin.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/ImImagePlugin.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/SunImagePlugin.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/ImageMorph.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/ImageMode.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/FpxImagePlugin.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/BufrStubImagePlugin.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/PcdImagePlugin.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/ImagePath.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/ImageTk.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/IcnsImagePlugin.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/IcoImagePlugin.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/TiffImagePlugin.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/GribStubImagePlugin.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/ImageFont.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/IptcImagePlugin.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/_version.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/SgiImagePlugin.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/ImageShow.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/ImageFilter.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/GimpGradientFile.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/BdfFontFile.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/MspImagePlugin.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/PcfFontFile.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/PdfImagePlugin.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/ImtImagePlugin.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/ImageFile.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/PixarImagePlugin.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/BmpImagePlugin.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/PpmImagePlugin.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/_util.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/XVThumbImagePlugin.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/FontFile.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/PyAccess.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/ImageMath.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/JpegImagePlugin.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/ImagePalette.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/GifImagePlugin.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/_tkinter_finder.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/FitsStubImagePlugin.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/SpiderImagePlugin.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/MicImagePlugin.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/XpmImagePlugin.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/QoiImagePlugin.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/TiffTags.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/ImageTransform.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/ImageOps.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/__main__.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/ImageDraw.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/PalmImagePlugin.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/ContainerIO.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/GdImageFile.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/XbmImagePlugin.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/WalImageFile.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/PcxImagePlugin.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/WebPImagePlugin.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/ImageQt.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/FliImagePlugin.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/PsdImagePlugin.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/_deprecate.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/ExifTags.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/BlpImagePlugin.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/ImageSequence.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/_binary.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/PSDraw.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/DcxImagePlugin.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/ImageDraw2.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/TarIO.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/__init__.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/FtexImagePlugin.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/McIdasImagePlugin.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/Image.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/PngImagePlugin.py -> build/lib.linux-armv7l-cpython-310/PIL
copying src/PIL/TgaImagePlugin.py -> build/lib.linux-armv7l-cpython-310/PIL
running egg_info
writing src/Pillow.egg-info/PKG-INFO
writing dependency_links to src/Pillow.egg-info/dependency_links.txt
writing requirements to src/Pillow.egg-info/requires.txt
writing top-level names to src/Pillow.egg-info/top_level.txt
reading manifest file 'src/Pillow.egg-info/SOURCES.txt'
reading manifest template 'MANIFEST.in'
warning: no files found matching '*.c'
warning: no files found matching '*.h'
warning: no files found matching '*.sh'
warning: no files found matching '*.txt'
warning: no previously-included files found matching '.appveyor.yml'
warning: no previously-included files found matching '.clang-format'
warning: no previously-included files found matching '.coveragerc'
warning: no previously-included files found matching '.editorconfig'
warning: no previously-included files found matching '.readthedocs.yml'
warning: no previously-included files found matching 'codecov.yml'
warning: no previously-included files found matching 'renovate.json'
warning: no previously-included files matching '.git*' found anywhere in distribution
warning: no previously-included files matching '*.pyc' found anywhere in distribution
warning: no previously-included files matching '*.so' found anywhere in distribution
no previously-included directories found matching '.ci'
adding license file 'LICENSE'
writing manifest file 'src/Pillow.egg-info/SOURCES.txt'
running build_ext
The headers or library files could not be found for jpeg,
a required dependency when compiling Pillow from source.
Please see the install instructions at:
https://pillow.readthedocs.io/en/latest/installation.html
Traceback (most recent call last):
File "<string>", line 993, in <module>
File "/tmp/pip-build-env-7ciy4ulm/overlay/lib/python3.10/site-packages/setuptools/__init__.py", line 107, in setup
return distutils.core.setup(**attrs)
File "/tmp/pip-build-env-7ciy4ulm/overlay/lib/python3.10/site-packages/setuptools/_distutils/core.py", line 185, in setup
return run_commands(dist)
File "/tmp/pip-build-env-7ciy4ulm/overlay/lib/python3.10/site-packages/setuptools/_distutils/core.py", line 201, in run_commands
dist.run_commands()
File "/tmp/pip-build-env-7ciy4ulm/overlay/lib/python3.10/site-packages/setuptools/_distutils/dist.py", line 969, in run_commands
self.run_command(cmd)
File "/tmp/pip-build-env-7ciy4ulm/overlay/lib/python3.10/site-packages/setuptools/dist.py", line 1244, in run_command
super().run_command(command)
File "/tmp/pip-build-env-7ciy4ulm/overlay/lib/python3.10/site-packages/setuptools/_distutils/dist.py", line 988, in run_command
cmd_obj.run()
File "/tmp/pip-build-env-7ciy4ulm/overlay/lib/python3.10/site-packages/wheel/bdist_wheel.py", line 343, in run
self.run_command("build")
File "/tmp/pip-build-env-7ciy4ulm/overlay/lib/python3.10/site-packages/setuptools/_distutils/cmd.py", line 318, in run_command
self.distribution.run_command(command)
cmd_obj.run()
File "/tmp/pip-build-env-7ciy4ulm/overlay/lib/python3.10/site-packages/setuptools/_distutils/command/build.py", line 131, in run
self.run_command(cmd_name)
cmd_obj.run()
File "/tmp/pip-build-env-7ciy4ulm/overlay/lib/python3.10/site-packages/setuptools/command/build_ext.py", line 84, in run
_build_ext.run(self)
File "/tmp/pip-build-env-7ciy4ulm/overlay/lib/python3.10/site-packages/setuptools/_distutils/command/build_ext.py", line 345, in run
self.build_extensions()
File "<string>", line 809, in build_extensions
__main__.RequiredDependencyException: jpeg
During handling of the above exception, another exception occurred:
File "/usr/lib/python3.10/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 353, in <module>
main()
File "/usr/lib/python3.10/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 335, in main
json_out['return_val'] = hook(**hook_input['kwargs'])
File "/usr/lib/python3.10/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 251, in build_wheel
return _build_backend().build_wheel(wheel_directory, config_settings,
File "/tmp/pip-build-env-7ciy4ulm/overlay/lib/python3.10/site-packages/setuptools/build_meta.py", line 416, in build_wheel
return self._build_with_temp_dir(['bdist_wheel'], '.whl',
File "/tmp/pip-build-env-7ciy4ulm/overlay/lib/python3.10/site-packages/setuptools/build_meta.py", line 401, in _build_with_temp_dir
self.run_setup()
File "/tmp/pip-build-env-7ciy4ulm/overlay/lib/python3.10/site-packages/setuptools/build_meta.py", line 487, in run_setup
super(_BuildMetaLegacyBackend,
File "/tmp/pip-build-env-7ciy4ulm/overlay/lib/python3.10/site-packages/setuptools/build_meta.py", line 338, in run_setup
exec(code, locals())
File "<string>", line 1010, in <module>
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
ERROR: Failed building wheel for Pillow
Failed to build Pillow
ERROR: Could not build wheels for Pillow, which is required to install pyproject.toml-based projects
