Acabo de empezar, he instalado minibian, me he conectado por Putty y cuando hago el paso de
PREPARAR NUESTRO DISCO DURO Y MONTARLO EN EXT4
viewtopic.php?f=6&t=113
Cuando llego a
Ahora para asegurar que está correctamente ,pondremos:
CÓDIGO: SELECCIONAR TODO
df -h
me sale esto
login as: root
root@192.168.1.17's password:
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Thu Sep 22 23:13:46 2016 from 192.168.1.12
root@minibian:~# df –h
df: ‘–h’: No such file or directory
root@minibian:~# dmesg
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.1.18-v7+ (dc4@dc4-XPS13-9333) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611) ) #846 SMP Thu Feb 25 14:22:53 GMT 2016
[ 0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine model: Raspberry Pi 3 Model B Rev 1.2
[ 0.000000] cma: Reserved 8 MiB at 0x3d400000
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] On node 0 totalpages: 253952
[ 0.000000] free_area_init_node: node 0, pgdat 80876f80, node_mem_map bcb48000
[ 0.000000] Normal zone: 2232 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 253952 pages, LIFO batch:31
[ 0.000000] [bcm2709_smp_init_cpus] enter (9420->f3003010)
[ 0.000000] [bcm2709_smp_init_cpus] ncores=4
[ 0.000000] PERCPU: Embedded 12 pages/cpu @bdfb0000 s20416 r8192 d20544 u49152
[ 0.000000] pcpu-alloc: s20416 r8192 d20544 u49152 alloc=12*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 251720
[ 0.000000] Kernel command line: 8250.nr_uarts=1 dma.dmachans=0x7f35 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2709.boardrev=0xa02082 bcm2709.serial=0x5c6d7ad7 smsc95xx.macaddr=B8:27:EB:6D:7A:D7 bcm2708_fb.fbswap=1 bcm2709.uart_clock=48000000 vc_mem.mem_base=0x3ea00000 vc_mem.mem_size=0x3f000000 dwc_otg.lpm_enable=0 console=ttyS0,115200 kgdboc=ttyAMA0,115200 console=tty1 elevator=deadline root=/dev/mmcblk0p2 rootfstype=ext4 fsck.repair=yes rootwait
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 988136K/1015808K available (6024K kernel code, 534K rwdata, 1660K rodata, 448K init, 757K bss, 19480K reserved, 8192K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xbe800000 - 0xff000000 (1032 MB)
lowmem : 0x80000000 - 0xbe000000 ( 992 MB)
modules : 0x7f000000 - 0x80000000 ( 16 MB)
.text : 0x80008000 - 0x807895a0 (7686 kB)
.init : 0x8078a000 - 0x807fa000 ( 448 kB)
.data : 0x807fa000 - 0x8087fac0 ( 535 kB)
.bss : 0x80882000 - 0x8093f79c ( 758 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] Additional per-CPU info printed with stalls.
[ 0.000000] NR_IRQS:608
[ 0.000000] Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000008] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000026] Switching to timer-based delay loop, resolution 52ns
[ 0.000242] Console: colour dummy device 80x30
[ 0.001288] console [tty1] enabled
[ 0.001341] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ 0.001410] pid_max: default: 32768 minimum: 301
[ 0.001732] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001775] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.002772] Initializing cgroup subsys blkio
[ 0.002822] Initializing cgroup subsys memory
[ 0.002871] Initializing cgroup subsys devices
[ 0.002913] Initializing cgroup subsys freezer
[ 0.002962] Initializing cgroup subsys net_cls
[ 0.003031] CPU: Testing write buffer coherency: ok
[ 0.003117] ftrace: allocating 20309 entries in 60 pages
[ 0.048562] CPU0: update cpu_capacity 1024
[ 0.048627] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.048660] [bcm2709_smp_prepare_cpus] enter
[ 0.048824] Setting up static identity map for 0x8240 - 0x8274
[ 0.050594] [bcm2709_boot_secondary] cpu:1 started (0) 17
[ 0.050945] [bcm2709_secondary_init] enter cpu:1
[ 0.050987] CPU1: update cpu_capacity 1024
[ 0.050994] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.051366] [bcm2709_boot_secondary] cpu:2 started (0) 17
[ 0.051622] [bcm2709_secondary_init] enter cpu:2
[ 0.051643] CPU2: update cpu_capacity 1024
[ 0.051649] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.052006] [bcm2709_boot_secondary] cpu:3 started (0) 17
[ 0.052189] [bcm2709_secondary_init] enter cpu:3
[ 0.052210] CPU3: update cpu_capacity 1024
[ 0.052216] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.052277] Brought up 4 CPUs
[ 0.052375] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.052405] CPU: All CPU(s) started in HYP mode.
[ 0.052431] CPU: Virtualization extensions available.
[ 0.053127] devtmpfs: initialized
[ 0.071427] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[ 0.071693] clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.072554] pinctrl core: initialized pinctrl subsystem
[ 0.073099] NET: Registered protocol family 16
[ 0.078245] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.079240] bcm2709.uart_clock = 48000000
[ 0.083202] bcm2709: Mini UART enabled
[ 0.083713] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.083761] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.083932] Serial: AMBA PL011 UART driver
[ 0.084081] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 83, base_baud = 0) is a PL011 rev2
[ 0.084517] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.149289] bcm2708-dmaengine 3f007000.dma: DMA legacy API manager at f3007000, dmachans=0xf35
[ 0.149359] bcm2708-dmaengine 3f007000.dma: Initialized 7 DMA channels (+ 1 legacy)
[ 0.149950] bcm2708-dmaengine 3f007000.dma: Load BCM2835 DMA engine driver
[ 0.149986] bcm2708-dmaengine 3f007000.dma: dma_debug:0
[ 0.150564] SCSI subsystem initialized
[ 0.150760] usbcore: registered new interface driver usbfs
[ 0.150867] usbcore: registered new interface driver hub
[ 0.150989] usbcore: registered new device driver usb
[ 0.151534] raspberrypi-firmware soc:firmware: Attached to firmware from 2016-02-25 14:26
[ 0.178644] Switched to clocksource arch_sys_counter
[ 0.220173] FS-Cache: Loaded
[ 0.220460] CacheFiles: Loaded
[ 0.229634] NET: Registered protocol family 2
[ 0.230595] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.230736] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.230947] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.231061] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.231130] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.231461] NET: Registered protocol family 1
[ 0.231783] RPC: Registered named UNIX socket transport module.
[ 0.231815] RPC: Registered udp transport module.
[ 0.231843] RPC: Registered tcp transport module.
[ 0.231870] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.232842] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[ 0.233942] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.247344] VFS: Disk quotas dquot_6.6.0
[ 0.247679] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.249758] FS-Cache: Netfs 'nfs' registered for caching
[ 0.250687] NFS: Registering the id_resolver key type
[ 0.250755] Key type id_resolver registered
[ 0.250784] Key type id_legacy registered
[ 0.252842] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 0.253004] io scheduler noop registered
[ 0.253043] io scheduler deadline registered (default)
[ 0.253332] io scheduler cfq registered
[ 0.255584] BCM2708FB: allocated DMA memory fd800000
[ 0.255630] BCM2708FB: allocated DMA channel 0 @ f3007000
[ 0.260558] Console: switching to colour frame buffer device 82x26
[ 0.264889] Serial: 8250/16550 driver, 1 ports, IRQ sharing disabled
[ 0.270033] console [ttyS0] disabled
[ 0.271501] 3f215040.uart: ttyS0 at MMIO 0x3f215040 (irq = 29, base_baud = 50000000) is a 16550
[ 1.471239] console [ttyS0] enabled
[ 1.478796] KGDB: Registered I/O driver kgdboc
[ 1.509132] vc-cma: Videocore CMA driver
[ 1.516841] vc-cma: vc_cma_base = 0x00000000
[ 1.525825] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 1.535882] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 1.546056] vc-mem: phys_addr:0x00000000 mem_base=0x3ea00000 mem_size:0x3f000000(1008 MiB)
[ 1.573305] brd: module loaded
[ 1.586401] loop: module loaded
[ 1.593572] vchiq: vchiq_init_state: slot_zero = 0xbd880000, is_master = 0
[ 1.607554] Loading iSCSI transport class v2.0-870.
[ 1.617437] usbcore: registered new interface driver smsc95xx
[ 1.628137] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.839087] Core Release: 2.80a
[ 1.845518] Setting default values for core params
[ 1.854668] Finished setting default values for core params
[ 2.065399] Using Buffer DMA mode
[ 2.072092] Periodic Transfer Interrupt Enhancement - disabled
[ 2.082883] Multiprocessor Interrupt Enhancement - disabled
[ 2.093216] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 2.101597] Dedicated Tx FIFOs mode
[ 2.108863] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xbd814000 dma = 0xfd814000 len=9024
[ 2.127551] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
[ 2.160187] dwc_otg: Microframe scheduler enabled
[ 2.160236] WARN::hcd_init_fiq:412: FIQ on core 1 at 0x8040ecc0
[ 2.171222] WARN::hcd_init_fiq:413: FIQ ASM at 0x8040f030 length 36
[ 2.182786] WARN::hcd_init_fiq:438: MPHI regs_base at 0xbe89c000
[ 2.193930] dwc_otg 3f980000.usb: DWC OTG Controller
[ 2.203358] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 2.216618] dwc_otg 3f980000.usb: irq 32, io mem 0x00000000
[ 2.227051] Init: Port Power? op_state=1
[ 2.234749] Init: Power Port (0)
[ 2.241479] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.253863] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.266941] usb usb1: Product: DWC OTG Controller
[ 2.275904] usb usb1: Manufacturer: Linux 4.1.18-v7+ dwc_otg_hcd
[ 2.286988] usb usb1: SerialNumber: 3f980000.usb
[ 2.296430] hub 1-0:1.0: USB hub found
[ 2.303872] hub 1-0:1.0: 1 port detected
[ 2.311871] dwc_otg: FIQ enabled
[ 2.311881] dwc_otg: NAK holdoff enabled
[ 2.311888] dwc_otg: FIQ split-transaction FSM enabled
[ 2.311920] Module dwc_common_port init
[ 2.312174] usbcore: registered new interface driver usb-storage
[ 2.323371] mousedev: PS/2 mouse device common for all mice
[ 2.334342] bcm2835-cpufreq: min=600000 max=1200000
[ 2.343815] sdhci: Secure Digital Host Controller Interface driver
[ 2.355161] sdhci: Copyright(c) Pierre Ossman
[ 2.363817] sdhost: log_buf @ bd813000 (fd813000)
[ 2.448679] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 2.481273] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[ 2.492093] mmc-bcm2835 3f300000.mmc: DMA channels allocated
[ 2.508746] Indeed it is in host mode hprt0 = 00021501
[ 2.519642] mmc0: host does not support reading read-only switch, assuming write-enable
[ 2.538170] mmc0: new high speed SDHC card at address 0007
[ 2.538762] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.539130] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.539250] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.539433] usbcore: registered new interface driver usbhid
[ 2.539436] usbhid: USB HID core driver
[ 2.539840] Initializing XFRM netlink socket
[ 2.539863] NET: Registered protocol family 17
[ 2.539976] Key type dns_resolver registered
[ 2.540431] Registering SWP/SWPB emulation handler
[ 2.578988] registered taskstats version 1
[ 2.579159] vc-sm: Videocore shared memory driver
[ 2.579168] [vc_sm_connected_init]: start
[ 2.580412] vc_vchi_sm_init: failed to open VCHI service (-1)
[ 2.580413] [vc_sm_connected_init]: failed to initialize shared memory service
[ 2.580417] [vc_sm_connected_init]: end - returning -1
[ 2.688680] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 2.690947] Indeed it is in host mode hprt0 = 00001101
[ 2.712802] Waiting for root device /dev/mmcblk0p2...
[ 2.722551] mmcblk0: mmc0:0007 SL32G 29.0 GiB
[ 2.732578] mmcblk0: p1 p2
[ 2.755143] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 2.766903] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.778598] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.791469] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 2.844272] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.859834] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 2.884415] devtmpfs: mounted
[ 2.888947] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 2.888956] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.889638] hub 1-1:1.0: USB hub found
[ 2.889727] hub 1-1:1.0: 5 ports detected
[ 2.893046] mmc1: new high speed SDIO card at address 0001
[ 2.941752] Freeing unused kernel memory: 448K (8078a000 - 807fa000)
[ 3.168702] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 3.278955] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 3.291545] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.304839] random: systemd urandom read with 47 bits of entropy available
[ 3.307551] smsc95xx v1.0.4
[ 3.326926] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
[ 3.351808] systemd[1]: Detected architecture 'arm'.
[ 3.371742] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:6d:7a:d7
[ 3.547421] NET: Registered protocol family 10
[ 3.557521] systemd[1]: Inserted module 'ipv6'
[ 3.569906] systemd[1]: Set hostname to <minibian>.
[ 3.838702] usb 1-1.5: new high-speed USB device number 4 using dwc_otg
[ 4.029699] usb 1-1.5: New USB device found, idVendor=1058, idProduct=25a3
[ 4.042491] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 4.055931] usb 1-1.5: Product: Elements 25A3
[ 4.064525] usb 1-1.5: Manufacturer: Western Digital
[ 4.074082] usb 1-1.5: SerialNumber: 57434334453543534A523548
[ 4.085692] usb-storage 1-1.5:1.0: USB Mass Storage device detected
[ 4.098069] scsi host0: usb-storage 1-1.5:1.0
[ 4.110118] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory.
[ 4.141172] systemd[1]: Expecting device dev-ttyS0.device...
[ 4.153894] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[ 4.169449] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 4.184901] systemd[1]: Starting Remote File Systems (Pre).
[ 4.197536] systemd[1]: Reached target Remote File Systems (Pre).
[ 4.209196] systemd[1]: Starting Encrypted Volumes.
[ 4.220720] systemd[1]: Reached target Encrypted Volumes.
[ 4.231279] systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point.
[ 4.251209] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 4.270121] systemd[1]: Starting Dispatch Password Requests to Console Directory Watch.
[ 4.286896] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 4.303409] systemd[1]: Starting Paths.
[ 4.313511] systemd[1]: Reached target Paths.
[ 4.322384] systemd[1]: Starting Swap.
[ 4.332055] systemd[1]: Reached target Swap.
[ 4.340658] systemd[1]: Expecting device dev-mmcblk0p1.device...
[ 4.353895] systemd[1]: Starting Root Slice.
[ 4.364364] systemd[1]: Created slice Root Slice.
[ 4.373632] systemd[1]: Starting User and Session Slice.
[ 4.385798] systemd[1]: Created slice User and Session Slice.
[ 4.396705] systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
[ 4.410856] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 4.423706] systemd[1]: Starting Delayed Shutdown Socket.
[ 4.435703] systemd[1]: Listening on Delayed Shutdown Socket.
[ 4.446484] systemd[1]: Starting Journal Socket (/dev/log).
[ 4.458767] systemd[1]: Listening on Journal Socket (/dev/log).
[ 4.469896] systemd[1]: Starting udev Kernel Socket.
[ 4.481192] systemd[1]: Listening on udev Kernel Socket.
[ 4.491361] systemd[1]: Starting udev Control Socket.
[ 4.502851] systemd[1]: Listening on udev Control Socket.
[ 4.513168] systemd[1]: Starting Journal Socket.
[ 4.524016] systemd[1]: Listening on Journal Socket.
[ 4.533667] systemd[1]: Starting System Slice.
[ 4.544198] systemd[1]: Created slice System Slice.
[ 4.553649] systemd[1]: Starting File System Check on Root Device...
[ 4.569219] systemd[1]: Starting system-getty.slice.
[ 4.581119] systemd[1]: Created slice system-getty.slice.
[ 4.591472] systemd[1]: Starting system-serial\x2dgetty.slice.
[ 4.604580] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 4.616420] systemd[1]: Starting Increase datagram queue length...
[ 4.632113] systemd[1]: Starting Restore / save the current clock...
[ 4.666157] systemd[1]: Started Set Up Additional Binary Formats.
[ 4.694618] systemd[1]: Starting Load Kernel Modules...
[ 4.709082] systemd[1]: Mounting POSIX Message Queue File System...
[ 4.725244] systemd[1]: Mounting Debug File System...
[ 4.739560] systemd[1]: Starting udev Coldplug all Devices...
[ 4.756977] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[ 4.780038] systemd[1]: Mounted Huge Pages File System.
[ 4.790515] systemd[1]: Starting Slices.
[ 4.801292] systemd[1]: Reached target Slices.
[ 4.814343] systemd[1]: Mounted Debug File System.
[ 4.825862] systemd[1]: Mounted POSIX Message Queue File System.
[ 4.840355] systemd[1]: Started Increase datagram queue length.
[ 4.871672] systemd[1]: Started Restore / save the current clock.
[ 4.886091] systemd[1]: Started Load Kernel Modules.
[ 4.901957] systemd[1]: Started Create list of required static device nodes for the current kernel.
[ 4.926481] systemd[1]: Started File System Check on Root Device.
[ 4.938691] systemd[1]: Time has been changed
[ 4.950516] systemd[1]: Started udev Coldplug all Devices.
[ 5.099243] scsi 0:0:0:0: Direct-Access WD Elements 25A3 1013 PQ: 0 ANSI: 6
[ 5.105169] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 5.129866] sd 0:0:0:0: [sda] Spinning up disk...
[ 5.142227] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 5.159851] systemd[1]: Mounting Configuration File System...
[ 5.175183] systemd[1]: Mounted FUSE Control File System.
[ 5.176783] EXT4-fs (mmcblk0p2): re-mounted. Opts: errors=remount-ro,commit=120
[ 5.199964] systemd[1]: Starting Apply Kernel Variables...
[ 5.214940] systemd[1]: Starting Syslog Socket.
[ 5.226594] systemd[1]: Listening on Syslog Socket.
[ 5.236351] systemd[1]: Starting Journal Service...
[ 5.252393] systemd[1]: Started Journal Service.
[ 5.379830] systemd-udevd[113]: starting version 215
[ 5.788448] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 5.923522] cfg80211: Calling CRDA to update world regulatory domain
[ 5.985013] brcmfmac: brcmf_sdio_drivestrengthinit: No SDIO Drive strength init done for chip 43430 rev 1 pmurev 24
[ 6.007266] usbcore: registered new interface driver brcmfmac
[ 6.019352] brcmfmac_sdio mmc1:0001:1: Direct firmware load for brcm/brcmfmac43430-sdio.bin failed with error -2
[ 6.138809] .
[ 6.152606] systemd-journald[112]: Received request to flush runtime journal from PID 1
[ 6.462652] bcm2835-rng 3f104000.rng: hwrng registered
[ 6.473482] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 6.870874] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 6.884497] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 7.056468] brcmfmac: brcmf_sdio_htclk: HT Avail timeout (1000000): clkctl 0x50
[ 7.148668] .
[ 8.078846] brcmfmac: brcmf_sdio_htclk: HT Avail timeout (1000000): clkctl 0x50
[ 8.158662] .
[ 8.431696] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 8.446398] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
[ 9.078680] cfg80211: Calling CRDA to update world regulatory domain
[ 9.168669] ....
[ 12.238690] cfg80211: Calling CRDA to update world regulatory domain
[ 13.208666] ...ready
[ 15.233759] sd 0:0:0:0: [sda] Very big device. Trying to use READ CAPACITY(16).
[ 15.247764] sd 0:0:0:0: [sda] 7813969920 512-byte logical blocks: (4.00 TB/3.64 TiB)
[ 15.263970] sd 0:0:0:0: [sda] 4096-byte physical blocks
[ 15.275063] sd 0:0:0:0: [sda] Write Protect is off
[ 15.284663] sd 0:0:0:0: [sda] Mode Sense: 47 00 10 08
[ 15.285085] sd 0:0:0:0: [sda] No Caching mode page found
[ 15.295457] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 15.308882] sd 0:0:0:0: [sda] Very big device. Trying to use READ CAPACITY(16).
[ 15.391378] sda: sda1
[ 15.398251] sd 0:0:0:0: [sda] Very big device. Trying to use READ CAPACITY(16).
[ 15.411936] cfg80211: Calling CRDA to update world regulatory domain
[ 15.415526] random: nonblocking pool is initialized
[ 15.430790] sd 0:0:0:0: [sda] Attached SCSI disk
[ 18.588692] cfg80211: Calling CRDA to update world regulatory domain
[ 21.748694] cfg80211: Calling CRDA to update world regulatory domain
[ 24.908701] cfg80211: Calling CRDA to update world regulatory domain
[ 28.068689] cfg80211: Calling CRDA to update world regulatory domain
[ 31.228700] cfg80211: Calling CRDA to update world regulatory domain
[ 34.388709] cfg80211: Calling CRDA to update world regulatory domain
[ 37.548722] cfg80211: Calling CRDA to update world regulatory domain
[ 40.708702] cfg80211: Exceeded CRDA call max attempts. Not calling CRDA
root@minibian:~# df -h
Filesystem Size Used Avail Use% Mounted on
/dev/root 705M 446M 208M 69% /
devtmpfs 483M 0 483M 0% /dev
tmpfs 487M 0 487M 0% /dev/shm
tmpfs 487M 6.5M 481M 2% /run
tmpfs 5.0M 0 5.0M 0% /run/lock
tmpfs 487M 0 487M 0% /sys/fs/cgroup
tmpfs 487M 0 487M 0% /tmp
/dev/mmcblk0p1 61M 35M 27M 57% /boot
tmpfs 98M 0 98M 0% /run/user/0
Esta claro que algo estoy haciendo mal, pero no se el que????
Porque entiendo que lo primero, antes de instalar Transmission , es preparar el disco, no??
El cual, lo tengo alimentado externamente y conectado a un USB a la placa.
Ya me imaginaba yo que no iba a ser facil... :x
