Buenas.
Veo que ha salido (no se cuando exactamente creo que esta semana)... una Placa Rock64 de los creadores de Pine64
https://www.pine64.org/?product=rockpro ... d-computer
Tiene
ROCKPro64 is the most powerful Single Board Computer released by Pine64. Its powered by a Rockchip RK3399 Hexa-Core (dual ARM Cortex A72 and quad ARM Cortex A53) 64-Bit Processor with MALI T-860 Quad-Core GPU. The ROCKPro64 is equipped with 2GB LPDDR4 system memory and 128Mb SPI boot Flash. There is also an optional eMMC module (up to 128GB) and microSD slot for booting. The board is equipped with a PCIe x4 open ended slot, 1x USB 3.0 type C Host with DP 1.2, 1x USB 3.0 type A Host, 2x USB 2.0 Host, Gigabit Ethernet, PI-2 GPIO Bus, MiPi DSI interface, eDP interface, touch Panel interface, stereo MiPi CSI interface, as well as many other peripheral device interface such as UART, SPI, I2C, for makers to integrate with sensors and other peripherals.
Procesador de 6 Cores.
2 o 4 GB depende de la versión que se compre.
Lan a GB
Mali T680
Se le puede poner una eMMC.
1 USB 3.0
2 USB 2.0
Puerto PCI Express
A parte venden controladora SATA II para el puerto PCI Express por 10 $
¿Nueva? Rock64 Pro
- lopz_
No no, si yo no digo de comprarla, solo que ha salido, ajaja, a ver, si la usas solo a modo texto... puede ir genial.... el problema pasará como con todas. driver gráfico KK. mismo problema que OrangePi. Odroid, etc....
