Pues lo dicho.. Conecto mi disco duro en NTFS.
pongo esto :
sudo mkdir /media/DescargaTorrent
sudo mount /dev/sda1 /media/DescargaTorrent
Mount is denied because the NTFS volume is already exclusively opened.
The volume may be already mounted, or another software may use it which
could be identified for example by the help of the 'fuser' command.
Lo único que hago con el disco duro es lo siguiente:
sudo apt-get install ntfs-3g -y
Cuando pongo:
sudo fdisk -l
Que estoy haciendo mal?
