#!/usr/bin/env python
# -*- coding: utf-8 -*-
import telebot
from telebot import types
import time
import os
import telegram
import picamera
import RPi.GPIO as GPIO
TOKEN = "493789599:AAFm0Z-AB7C3rI9YWbEEQAAeEjHAvtjicUk" # SUSTITUIR
userStep = {}
knownUsers = []
commands = {
'start': 'Arranca el bot',
'ayuda': 'Comandos disponibles',
'exec': 'Ejecuta un comando'
menu = types.ReplyKeyboardMarkup()
menu.add("RPinfo", "Camara")
cam_menu = types.ReplyKeyboardMarkup()
cam_menu.add("Foto", "Abrepuertas")
cam_menu.add("Atras")
info_menu = types.ReplyKeyboardMarkup()
info_menu.add("TEMP", "HD")
info_menu.add("CPU")
info_menu.add("Atras")
# COLOR TEXTO
class color:
RED = '\033[91m'
BLUE = '\033[94m'
GREEN = '\033[32m'
ENDC = '\033[0m'
BOLD = '\033[1m'
UNDERLINE = '\033[4m'
# USER STEP
def get_user_step(uid):
if uid in userStep:
return userStep[uid]
else:
knownUsers.append(uid)
userStep[uid] = 0
print(color.RED + " [¡] ¡¡NUEVO USUARIO!!" + color.ENDC)
# LISTENER
def listener(messages):
for m in messages:
if m.content_type == 'text':
print("[" + str(m.chat.id) + "] " + str(m.chat.first_name) + ": " + m.text)
bot = telebot.TeleBot(TOKEN)
bot.set_update_listener(listener)
# START
@bot.message_handler(commands=['start'])
def command_start(m):
cid = m.chat.id
userStep[cid] = 0
bot.send_message(cid, "Hola " + str(m.chat.first_name) + "...")
time.sleep(1)
bot.send_message(cid, "Bienvenido al menu principal")
time.sleep(1)
bot.send_message(cid, "¿En que puedo ayudarte?", reply_markup=menu)
# AYUDA
@bot.message_handler(commands=['ayuda'])
def command_help(m):
cid = m.chat.id
help_text = "Grabar sesion: TermRecord -o /tmp/botlog.html\n"
help_text += "Comandos disponibles: \n"
for key in commands:
help_text += "/" + key + ": "
help_text += commands[key] + "\n"
bot.send_message(cid, help_text)
# EXEC COMANDO
@bot.message_handler(commands=['exec'])
def command_exec(m):
cid = m.chat.id
if cid == "186626418": # SUSTITUIR
bot.send_message(cid, "Ejecutando: " + m.text[len("/exec"):])
bot.send_chat_action(cid, 'typing')
time.sleep(2)
f = os.popen(m.text[len("/exec"):])
result = f.read()
bot.send_message(cid, "Resultado: " + result)
else:
bot.send_message(cid, " ¡¡PERMISO DENEGADO!!")
print(color.RED + " ¡¡PERMISO DENEGADO!! " + color.ENDC)
# MENU PRINCIPAL
@bot.message_handler(func=lambda message: get_user_step(message.chat.id) == 0)
def main_menu(m):
cid = m.chat.id
text = m.text
if text == "RPinfo": # RPINFO
bot.send_message(cid, "Informacion disponible:", reply_markup=info_menu)
userStep[cid] = 1
elif text == "Camara": # CAMARA
bot.send_message(cid, "Opciones de la camara:", reply_markup=cam_menu)
userStep[cid] = 2
elif text == "Atras": # ATRAS
userStep[cid] = 0
bot.send_message(cid, "Menu Principal:", reply_markup=menu)
else:
command_text(m)
# MENU INFO
@bot.message_handler(func=lambda message: get_user_step(message.chat.id) == 1)
def info_opt(m):
cid = m.chat.id
txt = m.text
if txt == "TEMP": # TEMP
bot.send_message(cid, "[+] TEMPERATURAS")
print(color.BLUE + "[+] TEMPERATURAS" + color.ENDC)
# cpu temp
tempFile = open( "/sys/class/thermal/thermal_zone0/temp" )
cpu_temp = tempFile.read()
tempFile.close()
cpu_temp = round(float(cpu_temp)/1000)
bot.send_message(cid, " [i] CPU: %s" % cpu_temp)
print(color.GREEN + " [i] CPU: %s" % cpu_temp + color.ENDC)
# gpu temp
gpu_temp = os.popen('/opt/vc/bin/vcgencmd measure_temp').read().split("=")[1][:-3]
bot.send_message(cid, " [i] GPU: %s" % gpu_temp)
print(color.GREEN + " [i] GPU: %s" % gpu_temp + color.ENDC)
elif txt == "HD": # HD
bot.send_message(cid, "[+] DISCO DURO")
print(color.BLUE + "[+] DISCO DURO" + color.ENDC)
bot.send_message(cid, " [i] Total: %s" % diskSpace()[0])
print(color.GREEN + " [i] Total: %s" % diskSpace()[0] + color.ENDC)
bot.send_message(cid, " [i] Usado: %s" % diskSpace()[1])
print(color.GREEN + " [i] Usado: %s" % diskSpace()[1] + color.ENDC)
bot.send_message(cid, " [i] Disponible: %s" % diskSpace()[2])
print(color.GREEN + " [i] Disponible: %s" % diskSpace()[2] + color.ENDC)
elif txt == "CPU": # CPU
bot.send_message(cid, "[+] CPU")
print(color.BLUE + "[+] CPU" + color.ENDC)
cpu = os.popen('mpstat | grep -A 5 "%idle" | tail -n 1 | awk -F " " \'{print 100 - $ 12}\'a').read()
bot.send_message(cid, " [i] Usado: %s" % cpu)
print(color.GREEN + " [i] Usado: %s" % cpu + color.ENDC)
elif txt == "Atras": # ATRAS
userStep[cid] = 0
else:
command_text(m)
# MENU CAMARA
@bot.message_handler(func=lambda message: get_user_step(message.chat.id) == 2)
def cam_opt(m):
cid = m.chat.id
text = m.text
if text == "Foto": # FOTO
bot.send_message(cid, "Tomando foto ...")
bot.send_chat_action(cid, 'upload_photo')
foto = "/home/pi/Pictures" + (time.strftime("%H%M%S-%d%m%y")) + ".jpg"
os.system('raspistill -w 1024 -h 768 -rot 180 -o %s' % foto)
bot.send_photo(cid, open(foto, 'rb'))
print(color.BLUE + " [i] Foto enviada!!" + color.ENDC)
elif text == "Abrepuertas": # ABREPUERTAS
bot.send_message(cid, "Abriendo la puerta")
GPIO.setmode(GPIO.BCM)
GPIO.setup(17,GPIO.OUT)
GPIO.output(17, True)
time.sleep (5)
GPIO.output (17, False)
GPIO.cleanup()
userStep[cid] = 0
else:
command_text(m)
# INFO HD
def diskSpace():
p = os.popen("df -h /")
i = 0
while 1:
i += 1
line = p.readline()
if i == 2:
return(line.split()[1:5])
# FILTRAR MENSAJES
@bot.message_handler(func=lambda message: True, content_types=['text'])
def command_text(m):
cid = m.chat.id
if (m.text.lower() in ['hola', 'hi', 'buenas', 'buenos dias']):
bot.send_message(cid, 'Muy buenas, ' + str(m.from_user.first_name) + '. Me alegra verte de nuevo.', parse_mode="Markdown")
elif (m.text.lower() in ['adios', 'aios', 'adeu', 'ciao']):
bot.send_message(cid, 'Hasta luego, ' + str(m.from_user.first_name) + '. Te echaré de menos.', parse_mode="Markdown")
print 'Corriendo...'
bot.polling(none_stop=True)Código: Seleccionar todo
import time
GPIO.setup(2, GPIO.IN)
GPIO.setup(17, GPIO.OUT)
GPIO.setwarnings(False)
while True:
if GPIO.input(2):
GPIO.output(17, GPIO.LOW)
else:
GPIO.output(17, GPIO.HIGH)
