Probleas al configurar raspberry para utilizar tor proxy
Carmesi
Buenas nohces
tengo un gran problema y no se como solucionarlo , al istalar los servicios "isc-dhcp-server" utilizando el comando
sudo apt-get install isc-dhcp-server
me da el siguiente error:
isc-dhcp-server.service - LSB: DHCP server
Loaded: loaded (/etc/init.d/isc-dhcp-server; generated; vendor preset: enabled)
Active: failed (Result: exit-code) since Sat 2018-06-02 23:19:22 UTC; 63ms ago
Docs: man:systemd-sysv-generator(8)
Process: 2072 ExecStart=/etc/init.d/isc-dhcp-server start (code=exited, status=1/FAILURE)
Jun 02 23:19:20 raspberrypi systemd[1]: Starting LSB: DHCP server...
Jun 02 23:19:20 raspberrypi isc-dhcp-server[2072]: Launching both IPv4 and IP…).
Jun 02 23:19:20 raspberrypi dhcpd[2084]: Wrote 0 leases to leases file.
Jun 02 23:19:22 raspberrypi isc-dhcp-server[2072]: Starting ISC DHCPv4 server…d!
Jun 02 23:19:22 raspberrypi isc-dhcp-server[2072]: failed!
Jun 02 23:19:22 raspberrypi systemd[1]: isc-dhcp-server.service: Control pro…s=1
Jun 02 23:19:22 raspberrypi systemd[1]: Failed to start LSB: DHCP server.
Jun 02 23:19:22 raspberrypi systemd[1]: isc-dhcp-server.service: Unit entere…te.
Jun 02 23:19:22 raspberrypi systemd[1]: isc-dhcp-server.service: Failed with…e'.
Hint: Some lines were ellipsized, use -l to show in full.
Processing triggers for libc-bin (2.24-11+deb9u3) ...
Processing triggers for systemd (232-25+deb9u2) ...
alguien seria tan amable de ayudarme
