No consigo configurar este mando para jugar juegos de Dreamcast, siguiendo los pasos del compañero javi1964 me atasco ya que no se donde colocar las lineas de comandos, la configuración del mando que me sale es la siguiente:
Espero podais ayudarme, muchas gracias.-
Input driver version is 1.0.1
Input device ID: bus 0x3 vendor 0x79 product 0x181c version 0x111
Input device name: " MAYFLASH Arcade Fightstick F300"
Supported events:
Event type 0 (EV_SYN)
Event type 1 (EV_KEY)
Event code 304 (BTN_SOUTH)
Event code 305 (BTN_EAST)
Event code 306 (BTN_C)
Event code 307 (BTN_NORTH)
Event code 308 (BTN_WEST)
Event code 309 (BTN_Z)
Event code 310 (BTN_TL)
Event code 311 (BTN_TR)
Event code 312 (BTN_TL2)
Event code 313 (BTN_TR2)
Event code 314 (BTN_SELECT)
Event code 315 (BTN_START)
Event code 316 (BTN_MODE)
Event code 317 (BTN_THUMBL)
Event code 318 (BTN_THUMBR)
Event type 3 (EV_ABS)
Event code 0 (ABS_X)
Value 128
Min 0
Max 255
Flat 15
Event code 1 (ABS_Y)
Value 128
Min 0
Max 255
Flat 15
Event code 2 (ABS_Z)
Value 128
Min 0
Max 255
Flat 15
Event code 5 (ABS_RZ)
Value 128
Min 0
Max 255
Flat 15
Event code 9 (ABS_GAS)
Value 0
Min 0
Max 255
Flat 15
Event code 10 (ABS_BRAKE)
Value 0
Min 0
Max 255
Flat 15
Event code 16 (ABS_HAT0X)
Value 0
Min -1
Max 1
Event code 17 (ABS_HAT0Y)
Value 0
Min -1
Max 1
Event type 4 (EV_MSC)
Event code 4 (MSC_SCAN)
Properties:
Testing ... (interrupt to exit)
Value 128
Min 0
Max 255
Flat 15
Value 128
Min 0
Max 255
Flat 15
Value 128
Min 0
Max 255
Flat 15
Value 128
Min 0
Max 255
Flat 15
Value 0
Min 0
Max 255
Flat 15
Value 0
Min 0
Max 255
Flat 15
Value 0
Min -1
Max 1
Value 0
Min -1
Max 1
Value 128
Min 0
Max 255
Flat 15
Value 128
Min 0
Max 255
Flat 15
Value 128
Min 0
Max 255
Flat 15
Value 128
Min 0
Max 255
Flat 15
Value 0
Min 0
Max 255
Flat 15
Value 0
Min 0
Max 255
Flat 15
Value 0
Min -1
Max 1
Value 0
Min -1
Max 1
Event: time 1483477003.230931, type 4 (EV_MSC), code 4 (MSC_SCAN), value 9000d
Event: time 1483477003.230931, type 1 (EV_KEY), code 316 (BTN_MODE), value 1
Event: time 1483477003.230931, -------------- EV_SYN ------------
Event: time 1483477003.326946, type 4 (EV_MSC), code 4 (MSC_SCAN), value 9000d
Event: time 1483477003.326946, type 1 (EV_KEY), code 316 (BTN_MODE), value 0
Event: time 1483477003.326946, -------------- EV_SYN ------------
