Estoy ahora con un proyecto de meter una Raspberry Pi 4 con retropie en una PS1 Fat. Y quiero que se pueda jugar tanto a través de los cables RCA como del HDMI.
Ahora mismo consigo sacar la imagen a través del RCA a una resolución de 240p. Pero no consigo que me muestre la imagen por el HDMI.
¿Alguien podría ayudarme?
Os paso mi archivo config.txt
NOTA
# For more options and information see # http://rpf.io/configtxt # Some settings may impact device functionality. See link above for details # uncomment if you get no picture on HDMI for a default "safe" mode #hdmi_safe=1 # uncomment this if your display has a black border of unused pixels visible # and your display can output without overscan disable_overscan=1 # uncomment the following to adjust overscan. Use positive numbers if console # goes off screen, and negative if there is too much border overscan_left=16 overscan_right=16 overscan_top=16 overscan_bottom=16 # uncomment to force a console size. By default it will be display's size minus # overscan. framebuffer_width=352 framebuffer_height=240 # uncomment if hdmi display is not detected and composite is being output hdmi_force_hotplug=1 # uncomment to force a specific HDMI mode (this will force VGA) #hdmi_group=2 #hdmi_mode=4 # uncomment to force a HDMI mode rather than DVI. This can make audio work in # DMT (computer monitor) modes #hdmi_drive=2 # uncomment to increase signal to HDMI, if you have interference, blanking, or # no display config_hdmi_boost=4 # uncomment for composite PAL enable_tvout=1 #sdtv_mode=0 sdtv_aspect=1 sdtv_mode=2 #uncomment to overclock the arm. 700 MHz is the default. #arm_freq=800 # Uncomment some or all of these to enable the optional hardware interfaces #dtparam=i2c_arm=on #dtparam=i2s=on #dtparam=spi=on # Uncomment this to enable infrared communication. #dtoverlay=gpio-ir,gpio_pin=17 #dtoverlay=gpio-ir-tx,gpio_pin=18 # Additional overlays and parameters are documented /boot/overlays/README # Enable audio (loads snd_bcm2835) dtparam=audio=on [pi4] # Enable DRM VC4 V3D driver on top of the dispmanx display stack dtoverlay=vc4-fkms-v3d max_framebuffers=2 [all] #dtoverlay=vc4-fkms-v3d overscan_scale=1
Muchas gracias y espero ansioso vuestras respuestas
