Oct 25 10:39:41 raspberrypi kernel: [ 3.109382] Initializing XFRM netlink socket
Oct 25 10:39:41 raspberrypi kernel: [ 3.111986] NET: Registered protocol family 17
Oct 25 10:39:41 raspberrypi kernel: [ 3.114632] Key type dns_resolver registered
Oct 25 10:39:41 raspberrypi kernel: [ 3.117635] Registering SWP/SWPB emulation handler
Oct 25 10:39:41 raspberrypi kernel: [ 3.120124] registered taskstats version 1
Oct 25 10:39:41 raspberrypi kernel: [ 3.122458] Loading compiled-in X.509 certificates
Oct 25 10:39:41 raspberrypi kernel: [ 3.125687] Key type ._fscrypt registered
Oct 25 10:39:41 raspberrypi kernel: [ 3.128007] Key type .fscrypt registered
Oct 25 10:39:41 raspberrypi kernel: [ 3.130322] Key type fscrypt-provisioning registered
Oct 25 10:39:41 raspberrypi kernel: [ 3.144122] uart-pl011 3f201000.serial: there is not valid maps for state default
Oct 25 10:39:41 raspberrypi kernel: [ 3.149014] uart-pl011 3f201000.serial: cts_event_workaround enabled
Oct 25 10:39:41 raspberrypi kernel: [ 3.151514] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 114, base_baud = 0) is a PL011 rev2
Oct 25 10:39:41 raspberrypi kernel: [ 4.233715] printk: console [ttyAMA0] enabled
Oct 25 10:39:41 raspberrypi kernel: [ 4.241024] Indeed it is in host mode hprt0 = 00021501
Oct 25 10:39:41 raspberrypi kernel: [ 4.310583] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
Oct 25 10:39:41 raspberrypi kernel: [ 4.321985] mmc-bcm2835 3f300000.mmcnr: mmc_debug:0 mmc_debug2:0
Oct 25 10:39:41 raspberrypi kernel: [ 4.330466] mmc-bcm2835 3f300000.mmcnr: DMA channel allocated
Oct 25 10:39:41 raspberrypi kernel: [ 4.365476] sdhost: log_buf @ (ptrval) (f4107000)
Oct 25 10:39:41 raspberrypi kernel: [ 4.409890] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
Oct 25 10:39:41 raspberrypi kernel: [ 4.419525] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
Oct 25 10:39:41 raspberrypi kernel: [ 4.427450] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
Oct 25 10:39:41 raspberrypi kernel: [ 4.438385] of_cfs_init
Oct 25 10:39:41 raspberrypi kernel: [ 4.443336] of_cfs_init: OK
Oct 25 10:39:41 raspberrypi kernel: [ 4.449741] Waiting for root device PARTUUID=0f0cf00c-02...
Oct 25 10:39:41 raspberrypi kernel: [ 4.456978] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
Oct 25 10:39:41 raspberrypi kernel: [ 4.468633] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
Oct 25 10:39:41 raspberrypi kernel: [ 4.484497] usb 1-1: new high-speed USB device number 2 using dwc_otg
Oct 25 10:39:41 raspberrypi kernel: [ 4.493879] Indeed it is in host mode hprt0 = 00001101
Oct 25 10:39:41 raspberrypi kernel: [ 4.614797] mmc0: host does not support reading read-only switch, assuming write-enable
Oct 25 10:39:41 raspberrypi kernel: [ 4.633603] mmc0: new high speed SDHC card at address aaaa
Oct 25 10:39:41 raspberrypi kernel: [ 4.642774] mmcblk0: mmc0:aaaa SB16G 14.8 GiB
Oct 25 10:39:41 raspberrypi kernel: [ 4.655339] mmcblk0: p1 p2
Oct 25 10:39:41 raspberrypi kernel: [ 4.679124] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
Oct 25 10:39:41 raspberrypi kernel: [ 4.692038] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
Oct 25 10:39:41 raspberrypi kernel: [ 4.694050] mmc1: new high speed SDIO card at address 0001
Oct 25 10:39:41 raspberrypi kernel: [ 4.711219] devtmpfs: mounted
Oct 25 10:39:41 raspberrypi kernel: [ 4.723648] Freeing unused kernel memory: 1024K
Oct 25 10:39:41 raspberrypi kernel: [ 4.734836] usb 1-1: New USB device found, idVendor=0424, idProduct=9514, bcdDevice= 2.00
Oct 25 10:39:41 raspberrypi kernel: [ 4.748126] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Oct 25 10:39:41 raspberrypi kernel: [ 4.758755] hub 1-1:1.0: USB hub found
Oct 25 10:39:41 raspberrypi kernel: [ 4.765412] hub 1-1:1.0: 5 ports detected
Oct 25 10:39:41 raspberrypi kernel: [ 4.774978] Run /sbin/init as init process
Oct 25 10:39:41 raspberrypi kernel: [ 4.781717] with arguments:
Oct 25 10:39:41 raspberrypi kernel: [ 4.781728] /sbin/init
Oct 25 10:39:41 raspberrypi kernel: [ 4.781739] with environment:
Oct 25 10:39:41 raspberrypi kernel: [ 4.781750] HOME=/
Oct 25 10:39:41 raspberrypi kernel: [ 4.781761] TERM=linux
Oct 25 10:39:41 raspberrypi kernel: [ 5.084517] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
Oct 25 10:39:41 raspberrypi kernel: [ 5.214894] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00, bcdDevice= 2.00
Oct 25 10:39:41 raspberrypi kernel: [ 5.228906] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Oct 25 10:39:41 raspberrypi kernel: [ 5.242144] smsc95xx v2.0.0
Oct 25 10:39:41 raspberrypi kernel: [ 5.473200] libphy: smsc95xx-mdiobus: probed
Oct 25 10:39:41 raspberrypi kernel: [ 5.481415] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:d5:83:a9
Oct 25 10:39:41 raspberrypi kernel: [ 5.557562] NET: Registered protocol family 10
Oct 25 10:39:41 raspberrypi kernel: [ 5.566560] Segment Routing with IPv6
Oct 25 10:39:41 raspberrypi rngd[411]: rngd 2-unofficial-mt.14 starting up...
Oct 25 10:39:41 raspberrypi systemd[1]: Condition check resulted in Configure Bluetooth Modems connected by UART being skipped.
Oct 25 10:39:41 raspberrypi rng-tools[394]: Starting Hardware RNG entropy gatherer daemon: rngd.
Oct 25 10:39:41 raspberrypi kernel: [ 5.794551] usb 1-1.3: new high-speed USB device number 4 using dwc_otg
Oct 25 10:39:41 raspberrypi kernel: [ 5.935775] usb 1-1.3: New USB device found, idVendor=0781, idProduct=5591, bcdDevice= 1.00
Oct 25 10:39:41 raspberrypi systemd[1]: Started PiJuice status service.
Oct 25 10:39:41 raspberrypi kernel: [ 5.950130] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Oct 25 10:39:41 raspberrypi kernel: [ 5.960952] usb 1-1.3: Product: SanDisk 3.2Gen1
Oct 25 10:39:41 raspberrypi kernel: [ 5.968664] usb 1-1.3: Manufacturer: USB
Oct 25 10:39:41 raspberrypi kernel: [ 5.975802] usb 1-1.3: SerialNumber: 01016a07c919d4884424d42e1af4c5f764dd74221ff5797c428f1753a3715ab1667400000000000000000000e431d0f1ff932d0091558107532b6bb5
Oct 25 10:39:41 raspberrypi kernel: [ 6.005301] usb-storage 1-1.3:1.0: USB Mass Storage device detected
Oct 25 10:39:41 raspberrypi kernel: [ 6.027285] scsi host0: usb-storage 1-1.3:1.0
Oct 25 10:39:41 raspberrypi systemd[1]: Condition check resulted in Turn on SSH if /boot/ssh is present being skipped.
Oct 25 10:39:41 raspberrypi kernel: [ 6.042402] uart-pl011 3f201000.serial: no DMA platform data
Oct 25 10:39:41 raspberrypi kernel: [ 6.134525] usb 1-1.5: new high-speed USB device number 5 using dwc_otg
Oct 25 10:39:41 raspberrypi kernel: [ 6.303463] usb 1-1.5: New USB device found, idVendor=6366, idProduct=3370, bcdDevice= 1.00
Oct 25 10:39:41 raspberrypi kernel: [ 6.317586] usb 1-1.5: New USB device strings: Mfr=2, Product=1, SerialNumber=3
Oct 25 10:39:41 raspberrypi kernel: [ 6.327856] usb 1-1.5: Product: USB 2.0 Camera
Oct 25 10:39:41 raspberrypi kernel: [ 6.335137] usb 1-1.5: Manufacturer: Sonix Technology Co., Ltd.
Oct 25 10:39:41 raspberrypi kernel: [ 6.343907] usb 1-1.5: SerialNumber: SN0001
Oct 25 10:39:41 raspberrypi kernel: [ 6.732908] random: systemd: uninitialized urandom read (16 bytes read)
Oct 25 10:39:41 raspberrypi kernel: [ 6.759274] random: systemd: uninitialized urandom read (16 bytes read)
Oct 25 10:39:41 raspberrypi kernel: [ 6.781890] random: systemd: uninitialized urandom read (16 bytes read)
Oct 25 10:39:41 raspberrypi kernel: [ 7.036324] scsi 0:0:0:0: Direct-Access USB SanDisk 3.2Gen1 1.00 PQ: 0 ANSI: 6
Oct 25 10:39:41 raspberrypi kernel: [ 7.051550] sd 0:0:0:0: [sda] 240353280 512-byte logical blocks: (123 GB/115 GiB)
Oct 25 10:39:41 raspberrypi kernel: [ 7.065166] sd 0:0:0:0: [sda] Write Protect is off
Oct 25 10:39:41 raspberrypi kernel: [ 7.072586] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
Oct 25 10:39:41 raspberrypi kernel: [ 7.073252] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
Oct 25 10:39:41 raspberrypi kernel: [ 7.122255] i2c /dev entries driver
Oct 25 10:39:41 raspberrypi kernel: [ 7.167299] sda: sda1
Oct 25 10:39:41 raspberrypi kernel: [ 7.178056] sd 0:0:0:0: [sda] Attached SCSI removable disk
Oct 25 10:39:41 raspberrypi kernel: [ 7.830486] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
Oct 25 10:39:41 raspberrypi kernel: [ 8.377742] sd 0:0:0:0: Attached scsi generic sg0 type 0
Oct 25 10:39:41 raspberrypi kernel: [ 8.833176] mc: Linux media interface: v0.10
Oct 25 10:39:41 raspberrypi kernel: [ 8.833486] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
Oct 25 10:39:41 raspberrypi kernel: [ 8.836998] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
Oct 25 10:39:41 raspberrypi kernel: [ 8.837044] [vc_sm_connected_init]: start
Oct 25 10:39:41 raspberrypi kernel: [ 8.848956] [vc_sm_connected_init]: installed successfully
Oct 25 10:39:41 raspberrypi kernel: [ 8.884232] videodev: Linux video capture interface: v2.00
Oct 25 10:39:41 raspberrypi kernel: [ 8.922363] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
Oct 25 10:39:41 raspberrypi kernel: [ 8.924911] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
Oct 25 10:39:41 raspberrypi kernel: [ 8.927770] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
Oct 25 10:39:41 raspberrypi kernel: [ 8.949621] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
Oct 25 10:39:41 raspberrypi kernel: [ 8.952873] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
Oct 25 10:39:41 raspberrypi kernel: [ 8.978319] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
Oct 25 10:39:41 raspberrypi kernel: [ 9.213934] cfg80211: Loading compiled-in X.509 certificates for regulatory database
Oct 25 10:39:41 raspberrypi kernel: [ 9.325051] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
Oct 25 10:39:41 raspberrypi kernel: [ 9.400385] brcmfmac: F1 signature read @0x18000000=0x1541a9a6
Oct 25 10:39:41 raspberrypi kernel: [ 9.431209] usbcore: registered new interface driver uas
Oct 25 10:39:41 raspberrypi kernel: [ 9.432656] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
Oct 25 10:39:41 raspberrypi kernel: [ 9.434044] usbcore: registered new interface driver brcmfmac
Oct 25 10:39:41 raspberrypi kernel: [ 9.453050] uvcvideo: Found UVC 1.00 device USB 2.0 Camera (6366:3370)
Oct 25 10:39:41 raspberrypi kernel: [ 9.488970] input: USB 2.0 Camera: USB Camera as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5:1.0/input/input0
Oct 25 10:39:41 raspberrypi kernel: [ 9.489534] usbcore: registered new interface driver uvcvideo
Oct 25 10:39:41 raspberrypi kernel: [ 9.489550] USB Video Class driver (1.1.1)
Oct 25 10:39:41 raspberrypi kernel: [ 9.594189] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
Oct 25 10:39:41 raspberrypi kernel: [ 9.594381] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
Oct 25 10:39:41 raspberrypi kernel: [ 9.595662] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
Oct 25 10:39:41 raspberrypi kernel: [ 9.597616] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
Oct 25 10:39:41 raspberrypi kernel: [ 9.598966] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
Oct 25 10:39:41 raspberrypi kernel: [ 9.599880] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
Oct 25 10:39:41 raspberrypi kernel: [ 9.599914] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
Oct 25 10:39:41 raspberrypi kernel: [ 9.599939] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
Oct 25 10:39:41 raspberrypi kernel: [ 9.599961] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
Oct 25 10:39:41 raspberrypi kernel: [ 9.599982] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
Oct 25 10:39:41 raspberrypi kernel: [ 9.600199] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
Oct 25 10:39:41 raspberrypi kernel: [ 9.609940] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
Oct 25 10:39:41 raspberrypi kernel: [ 9.610012] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
Oct 25 10:39:41 raspberrypi kernel: [ 9.620322] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
Oct 25 10:39:41 raspberrypi kernel: [ 9.620377] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
Oct 25 10:39:41 raspberrypi kernel: [ 9.636165] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
Oct 25 10:39:41 raspberrypi kernel: [ 9.636221] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
Oct 25 10:39:41 raspberrypi kernel: [ 9.677164] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
Oct 25 10:39:41 raspberrypi kernel: [ 9.677317] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
Oct 25 10:39:41 raspberrypi kernel: [ 9.677410] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-2), device may have limited channels available
Oct 25 10:39:41 raspberrypi kernel: [ 9.678621] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM43430/1 wl0: Oct 22 2019 01:59:28 version 7.45.98.94 (r723000 CY) FWID 01-3b33decd
Oct 25 10:39:41 raspberrypi kernel: [ 9.723238] usb 1-1.5: 3:1: cannot get freq at ep 0x84
Oct 25 10:39:41 raspberrypi kernel: [ 9.868389] usbcore: registered new interface driver snd-usb-audio
Oct 25 10:39:41 raspberrypi kernel: [ 10.426370] rtc-ds1307 1-0068: Unsupported ohm value 0 in dt
Oct 25 10:39:41 raspberrypi kernel: [ 10.430265] rtc-ds1307 1-0068: 'wakeup-source' is set, request for an IRQ is disabled!
Oct 25 10:39:41 raspberrypi kernel: [ 10.438338] random: crng init done
Oct 25 10:39:41 raspberrypi kernel: [ 10.438364] random: 7 urandom warning(s) missed due to ratelimiting
Oct 25 10:39:41 raspberrypi kernel: [ 10.439573] rtc-ds1307 1-0068: registered as rtc0
Oct 25 10:39:41 raspberrypi kernel: [ 10.441370] rtc-ds1307 1-0068: setting system clock to 2021-10-25T10:39:39 UTC (1635158379)
Oct 25 10:39:41 raspberrypi kernel: [ 10.507912] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
Oct 25 10:39:41 raspberrypi systemd[1]: Starting Check for Raspberry Pi EEPROM updates...
Oct 25 10:39:41 raspberrypi rngd[411]: entropy feed to the kernel ready
Oct 25 10:39:41 raspberrypi systemd[1]: Started Regular background program processing daemon.
Oct 25 10:39:41 raspberrypi cron[427]: (CRON) INFO (pidfile fd = 3)
Oct 25 10:39:41 raspberrypi avahi-daemon[409]: Found user 'avahi' (UID 108) and group 'avahi' (GID 113).
Oct 25 10:39:41 raspberrypi systemd[1]: Starting WPA supplicant...
Oct 25 10:39:41 raspberrypi avahi-daemon[409]: Successfully dropped root privileges.
Oct 25 10:39:41 raspberrypi systemd[1]: Starting LSB: Switch to ondemand cpu governor (unless shift key is pressed)...
Oct 25 10:39:41 raspberrypi avahi-daemon[409]: avahi-daemon 0.7 starting up.
Oct 25 10:39:41 raspberrypi cron[427]: (CRON) INFO (Running @reboot jobs)
Oct 25 10:39:41 raspberrypi avahi-daemon[409]: Successfully called chroot().
Oct 25 10:39:41 raspberrypi avahi-daemon[409]: Successfully dropped remaining capabilities.
Oct 25 10:39:41 raspberrypi avahi-daemon[409]: No service file found in /etc/avahi/services.
Oct 25 10:39:41 raspberrypi systemd[1]: Starting triggerhappy global hotkey daemon...
Oct 25 10:39:41 raspberrypi avahi-daemon[409]: Network interface enumeration completed.
Oct 25 10:39:41 raspberrypi avahi-daemon[409]: Server startup complete. Host name is raspberrypi.local. Local service cookie is 1789475733.
Oct 25 10:39:41 raspberrypi systemd[1]: Condition check resulted in getty on tty2-tty6 if dbus and logind are not available being skipped.
Oct 25 10:39:41 raspberrypi systemd[1]: Started Daily man-db regeneration.
Oct 25 10:39:41 raspberrypi systemd[1]: Reached target Timers.
Oct 25 10:39:41 raspberrypi rpi-eeprom-update[422]: This tool only works with a Raspberry Pi 4
Oct 25 10:39:41 raspberrypi systemd[1]: Starting Restore /etc/resolv.conf if the system crashed before the ppp link was shut down...
Oct 25 10:39:41 raspberrypi thd[447]: Found socket passed from systemd
Oct 25 10:39:41 raspberrypi systemd[1]: Starting dhcpcd on all interfaces...
Oct 25 10:39:41 raspberrypi systemd[1]: Started System Logging Service.
Oct 25 10:39:41 raspberrypi systemd[1]: Started triggerhappy global hotkey daemon.
Oct 25 10:39:41 raspberrypi systemd[1]: Started Raise network interfaces.
Oct 25 10:39:41 raspberrypi systemd[1]: Started Save/Restore Sound Card State.
Oct 25 10:39:41 raspberrypi systemd[1]: Started Load ip6tables save file.
Oct 25 10:39:41 raspberrypi systemd[1]: Started rng-tools.service.
Oct 25 10:39:41 raspberrypi dphys-swapfile[402]: want /var/swap=10000MByte, restricting to config limit: 2048MBytes, checking existing: keeping it
Oct 25 10:39:41 raspberrypi systemd[1]: Started Check for Raspberry Pi EEPROM updates.
Oct 25 10:39:41 raspberrypi systemd[1]: pppd-dns.service: Succeeded.
Oct 25 10:39:41 raspberrypi systemd[1]: Started Restore /etc/resolv.conf if the system crashed before the ppp link was shut down.
Oct 25 10:39:41 raspberrypi CRON[468]: (root) CMD (/home/chve/scripts/Reconexion_Modem/ReconectaModem.sh #Reconexion Modem)
Oct 25 10:39:41 raspberrypi dhcpcd[458]: dev: loaded udev
Oct 25 10:39:41 raspberrypi dbus-daemon[377]: [system] Successfully activated service 'org.freedesktop.systemd1'
Oct 25 10:39:41 raspberrypi wpa_supplicant[430]: Successfully initialized wpa_supplicant
Oct 25 10:39:41 raspberrypi kernel: [ 12.882878] 8021q: 802.1Q VLAN Support v1.8
Oct 25 10:39:41 raspberrypi kernel: [ 12.894726] Adding 2097148k swap on /var/swap. Priority:-2 extents:18 across:2424828k FS
Oct 25 10:39:41 raspberrypi systemd[1]: Started dphys-swapfile - set up, mount/unmount, and delete a swap file.
Oct 25 10:39:42 raspberrypi motion[388]: Starting motion detection daemon: motion.
Oct 25 10:39:42 raspberrypi systemd[1]: Started LSB: Start Motion detection.
Oct 25 10:39:42 raspberrypi systemd[1]: Started WPA supplicant.
Oct 25 10:39:42 raspberrypi systemd[1]: Reached target Sound Card.
Oct 25 10:39:42 raspberrypi systemd[1]: Started Avahi mDNS/DNS-SD Stack.
Oct 25 10:39:42 raspberrypi systemd[1]: Started Login Service.
Oct 25 10:39:42 raspberrypi dhcpcd[458]: wlan0: connected to Access Point `'
Oct 25 10:39:42 raspberrypi dhcpcd[458]: eth0: waiting for carrier
Oct 25 10:39:42 raspberrypi kernel: [ 13.317400] SMSC LAN8700 usb-001:003:01: attached PHY driver [SMSC LAN8700] (mii_bus:phy_addr=usb-001:003:01, irq=POLL)
Oct 25 10:39:42 raspberrypi kernel: [ 13.317962] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
Oct 25 10:39:42 raspberrypi kernel: [ 13.325952] smsc95xx 1-1.1:1.0 eth0: Link is Down
Oct 25 10:39:42 raspberrypi kernel: [ 13.361715] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
Oct 25 10:39:42 raspberrypi dhcpcd[458]: wlan0: waiting for carrier
Oct 25 10:39:43 raspberrypi raspi-config[438]: Checking if shift key is held down: No. Switching to ondemand scaling governor.
Oct 25 10:39:43 raspberrypi systemd[1]: Started LSB: Switch to ondemand cpu governor (unless shift key is pressed).
Oct 25 10:39:43 raspberrypi weewx[498] INFO __main__: Initializing weewx version 4.5.1
Oct 25 10:39:43 raspberrypi weewx[498] INFO __main__: Using Python 3.7.3 (default, Jan 22 2021, 20:04:44) #012[GCC 8.3.0]
Oct 25 10:39:43 raspberrypi weewx[498] INFO __main__: Platform Linux-5.10.63-v7+-armv7l-with-debian-10.11
Oct 25 10:39:43 raspberrypi weewx[498] INFO __main__: Locale is 'es_ES.UTF-8'
Oct 25 10:39:43 raspberrypi weewx[498] INFO __main__: PID file is /var/run/weewx.pid
Oct 25 10:39:43 raspberrypi weewx[372]: Starting weewx weather system: weewx.
Oct 25 10:39:43 raspberrypi systemd[1]: Started LSB: weewx weather system.
Oct 25 10:39:43 raspberrypi weewx[507] INFO __main__: Using configuration file /etc/weewx/weewx.conf
Oct 25 10:39:43 raspberrypi weewx[507] INFO __main__: Debug is 0
Oct 25 10:39:43 raspberrypi weewx[507] INFO weewx.engine: Loading station type Interceptor (user.interceptor)
Oct 25 10:39:44 raspberrypi weewx[507] INFO user.interceptor: driver version is 0.53
Oct 25 10:39:44 raspberrypi weewx[507] INFO user.interceptor: device type: observer
Oct 25 10:39:44 raspberrypi weewx[507] INFO user.interceptor: mode is listen
Oct 25 10:39:44 raspberrypi weewx[507] INFO user.interceptor: listen on :8001
Oct 25 10:39:44 raspberrypi weewx[507] INFO user.interceptor: sensor map: {'pressure': 'pressure', 'barometer': 'barometer', 'outHumidity': 'humidity_out', 'inHumidity': 'humidity_in', 'outTemp': 'temperature_out', 'inTemp': 'temperature_in', 'windSpeed': 'wind_speed', 'windGust': 'wind_gust', 'windDir': 'wind_dir', 'windGustDir': 'wind_gust_dir', 'radiation': 'solar_radiation', 'dewpoint': 'dewpoint', 'windchill': 'windchill', 'rain': 'rain', 'rainRate': 'rain_rate', 'UV': 'uv', 'txBatteryStatus': 'battery', 'extraTemp1': 'temperature_1', 'extraTemp2': 'temperature_2', 'extraTemp3': 'temperature_3', 'extraHumid1': 'humidity_1', 'extraHumid2': 'humidity_2', 'soilTemp1': 'soil_temperature_1', 'soilTemp2': 'soil_temperature_2', 'soilMoist1': 'soil_moisture_1', 'soilMoist2': 'soil_moisture_2', 'soilMoist3': 'soil_moisture_3', 'soilMoist4': 'soil_moisture_4', 'leafWet1': 'leafwetness_1', 'leafWet2': 'leafwetness_2', 'pm2_5': 'pm2_5', 'extraTemp4': 'temperature_4', 'extraTemp5': 'temperature_5', 'extraTemp6': 'temperature_6', 'extraTemp7': 'temperature_7', 'extraTemp8': 'temperature_8', 'extraHumid3': 'humidity_3', 'extraHumid4': 'humidity_4', 'extraHumid5': 'humidity_5', 'extraHumid6': 'humidity_6', 'extraHumid7': 'humidity_7', 'extraHumid8': 'humidity_8', 'soilTemp3': 'soil_temperature_3', 'soilTemp4': 'soil_temperature_4'}
Oct 25 10:39:44 raspberrypi weewx[507] INFO weewx.engine: StdConvert target unit is 0x1
Oct 25 10:39:44 raspberrypi weewx[507] INFO weewx.engine: Archive will use data binding wx_binding
Oct 25 10:39:44 raspberrypi weewx[507] INFO weewx.engine: Record generation will be attempted in 'hardware'
Oct 25 10:39:44 raspberrypi weewx[507] INFO weewx.engine: Using archive interval of 300 seconds (specified in weewx configuration)
Oct 25 10:39:44 raspberrypi weewx[507] INFO weewx.restx: StationRegistry: Registration not requested.
Oct 25 10:39:44 raspberrypi weewx[507] INFO weewx.restx: Wunderground: Posting not enabled.
Oct 25 10:39:44 raspberrypi weewx[507] INFO weewx.restx: PWSweather: Posting not enabled.
Oct 25 10:39:44 raspberrypi weewx[507] INFO weewx.restx: CWOP: Posting not enabled.
Oct 25 10:39:44 raspberrypi weewx[507] INFO weewx.restx: WOW: Posting not enabled.
Oct 25 10:39:44 raspberrypi weewx[507] INFO weewx.restx: AWEKAS: Posting not enabled.
Oct 25 10:39:44 raspberrypi weewx[507] INFO __main__: Starting up weewx version 4.5.1
Oct 25 10:39:44 raspberrypi weewx[507] INFO weewx.engine: Using binding 'wx_binding' to database 'weewx.sdb'
Oct 25 10:39:44 raspberrypi weewx[507] INFO weewx.manager: Starting backfill of daily summaries
Oct 25 10:39:44 raspberrypi weewx[507] INFO weewx.manager: Daily summaries up to date
Oct 25 10:39:44 raspberrypi weewx[507] INFO weewx.engine: Starting main packet loop.
Oct 25 10:39:44 raspberrypi systemd[1]: systemd-rfkill.service: Succeeded.
Oct 25 10:39:44 raspberrypi motion: [7833224:motion] [NTC] [ALL] conf_load: Processing thread 0 - config file /etc/motion/motion.conf
Oct 25 10:39:44 raspberrypi motion: [7833224:motion] [NTC] [ALL] motion_startup: Motion 4.1.1 Started
Oct 25 10:39:44 raspberrypi motion[489]: [7833224:motion] [NTC] [ALL] motion_startup: Logging to file (/var/log/motion/motion.log)
Oct 25 10:39:46 raspberrypi pijuice_sys.py[418]: RTC os-support OK
Oct 25 10:39:49 raspberrypi kernel: [ 20.894496] usb 1-1.2: new high-speed USB device number 6 using dwc_otg
Oct 25 10:39:50 raspberrypi kernel: [ 21.036505] usb 1-1.2: New USB device found, idVendor=19d2, idProduct=1421, bcdDevice=50.15
Oct 25 10:39:50 raspberrypi kernel: [ 21.036530] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Oct 25 10:39:50 raspberrypi kernel: [ 21.036546] usb 1-1.2: Product: ZTE Mobile Broadband
Oct 25 10:39:50 raspberrypi kernel: [ 21.036562] usb 1-1.2: Manufacturer: ZTE,Incorporated
Oct 25 10:39:50 raspberrypi kernel: [ 21.036576] usb 1-1.2: SerialNumber: 1234567890ABCDEF
Oct 25 10:39:50 raspberrypi kernel: [ 21.038757] usb-storage 1-1.2:1.0: USB Mass Storage device detected
Oct 25 10:39:50 raspberrypi kernel: [ 21.039670] scsi host1: usb-storage 1-1.2:1.0
Oct 25 10:39:50 raspberrypi mtp-probe: checking bus 1, device 6: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2"
Oct 25 10:39:50 raspberrypi mtp-probe: bus: 1, device: 6 was not an MTP device
Oct 25 10:39:51 raspberrypi kernel: [ 22.076758] scsi 1:0:0:0: CD-ROM ZTE USB SCSI CD-ROM 2.31 PQ: 0 ANSI: 2
Oct 25 10:39:51 raspberrypi kernel: [ 22.077563] scsi 1:0:0:0: Attached scsi generic sg1 type 5
Oct 25 10:39:51 raspberrypi kernel: [ 22.078791] scsi 1:0:0:1: Direct-Access ZTE MMC Storage 2.31 PQ: 0 ANSI: 2
Oct 25 10:39:51 raspberrypi kernel: [ 22.079475] sd 1:0:0:1: Attached scsi generic sg2 type 0
Oct 25 10:39:51 raspberrypi kernel: [ 22.081650] sd 1:0:0:1: Power-on or device reset occurred
Oct 25 10:39:51 raspberrypi kernel: [ 22.108533] sr 1:0:0:0: Power-on or device reset occurred
Oct 25 10:39:51 raspberrypi kernel: [ 22.115838] sr 1:0:0:0: [sr0] scsi-1 drive
Oct 25 10:39:51 raspberrypi kernel: [ 22.115860] cdrom: Uniform CD-ROM driver Revision: 3.20
Oct 25 10:39:51 raspberrypi kernel: [ 22.147600] sd 1:0:0:1: [sdb] Attached SCSI removable disk
Oct 25 10:39:51 raspberrypi kernel: [ 22.166645] sr 1:0:0:0: Attached scsi CD-ROM sr0
Oct 25 10:39:56 raspberrypi kernel: [ 27.260056] usb 1-1.2: USB disconnect, device number 6
Oct 25 10:39:56 raspberrypi kernel: [ 27.794494] usb 1-1.2: new high-speed USB device number 7 using dwc_otg
Oct 25 10:39:57 raspberrypi kernel: [ 27.936551] usb 1-1.2: New USB device found, idVendor=19d2, idProduct=1282, bcdDevice=50.15
Oct 25 10:39:57 raspberrypi kernel: [ 27.936580] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Oct 25 10:39:57 raspberrypi kernel: [ 27.936596] usb 1-1.2: Product: ZTE Mobile Broadband
Oct 25 10:39:57 raspberrypi kernel: [ 27.936611] usb 1-1.2: Manufacturer: ZTE,Incorporated
Oct 25 10:39:57 raspberrypi kernel: [ 27.936625] usb 1-1.2: SerialNumber: 1234567890ABCDEF
Oct 25 10:39:57 raspberrypi kernel: [ 27.944855] usb-storage 1-1.2:1.4: USB Mass Storage device detected
Oct 25 10:39:57 raspberrypi kernel: [ 27.946238] scsi host1: usb-storage 1-1.2:1.4
Oct 25 10:39:57 raspberrypi mtp-probe: checking bus 1, device 7: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2"
Oct 25 10:39:57 raspberrypi mtp-probe: bus: 1, device: 7 was not an MTP device
Oct 25 10:39:57 raspberrypi kernel: [ 28.026160] usbcore: registered new interface driver usbserial_generic
Oct 25 10:39:57 raspberrypi kernel: [ 28.026206] usbserial: USB Serial support registered for generic
Oct 25 10:39:57 raspberrypi kernel: [ 28.042670] usbcore: registered new interface driver option
Oct 25 10:39:57 raspberrypi kernel: [ 28.042720] usbserial: USB Serial support registered for GSM modem (1-port)
Oct 25 10:39:57 raspberrypi kernel: [ 28.043374] option 1-1.2:1.0: GSM modem (1-port) converter detected
Oct 25 10:39:57 raspberrypi kernel: [ 28.043685] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB0
Oct 25 10:39:57 raspberrypi kernel: [ 28.043983] option 1-1.2:1.1: GSM modem (1-port) converter detected
Oct 25 10:39:57 raspberrypi kernel: [ 28.044204] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB1
Oct 25 10:39:57 raspberrypi kernel: [ 28.046485] option 1-1.2:1.2: GSM modem (1-port) converter detected
Oct 25 10:39:57 raspberrypi kernel: [ 28.047028] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB2
Oct 25 10:39:57 raspberrypi kernel: [ 28.048000] option 1-1.2:1.3: GSM modem (1-port) converter detected
Oct 25 10:39:57 raspberrypi kernel: [ 28.048460] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB3
Oct 25 10:39:58 raspberrypi kernel: [ 28.956746] scsi 1:0:0:0: CD-ROM ZTE USB SCSI CD-ROM 2.31 PQ: 0 ANSI: 2
Oct 25 10:39:58 raspberrypi kernel: [ 28.964723] sr 1:0:0:0: [sr0] scsi-1 drive
Oct 25 10:39:58 raspberrypi kernel: [ 29.025375] sr 1:0:0:0: Attached scsi CD-ROM sr0
Oct 25 10:39:58 raspberrypi kernel: [ 29.025892] sr 1:0:0:0: Attached scsi generic sg1 type 5
Oct 25 10:39:58 raspberrypi kernel: [ 29.065792] scsi 1:0:0:1: Direct-Access ZTE MMC Storage 2.31 PQ: 0 ANSI: 2
Oct 25 10:39:58 raspberrypi kernel: [ 29.066360] sd 1:0:0:1: Attached scsi generic sg2 type 0
Oct 25 10:39:58 raspberrypi kernel: [ 29.069695] sd 1:0:0:1: Power-on or device reset occurred
Oct 25 10:39:58 raspberrypi kernel: [ 29.130368] sd 1:0:0:1: [sdb] Attached SCSI removable disk
Oct 25 10:40:02 raspberrypi pppd[577]: pppd 2.4.7 started by root, uid 0
Oct 25 10:40:02 raspberrypi kernel: [ 33.816780] PPP generic driver version 2.4.2
Oct 25 10:40:02 raspberrypi pppd[577]: Using interface ppp0
Oct 25 10:40:02 raspberrypi pppd[577]: Connect: ppp0 <--> /dev/ttyUSB1
Oct 25 10:40:02 raspberrypi pppd[577]: CHAP authentication succeeded
Oct 25 10:40:02 raspberrypi kernel: [ 33.871339] PPP BSD Compression module registered
Oct 25 10:40:02 raspberrypi kernel: [ 33.886065] PPP Deflate Compression module registered
Oct 25 10:40:02 raspberrypi pppd[577]: Could not determine remote IP address: defaulting to 10.64.64.64
Oct 25 10:40:02 raspberrypi pppd[577]: local IP address 10.162.172.112
Oct 25 10:40:02 raspberrypi pppd[577]: remote IP address 10.64.64.64
Oct 25 10:40:02 raspberrypi pppd[577]: primary DNS address 37.252.183.23
Oct 25 10:40:02 raspberrypi pppd[577]: secondary DNS address 94.143.75.14
Oct 25 10:40:10 raspberrypi systemd[1]: systemd-fsckd.service: Succeeded.
Oct 25 10:40:11 raspberrypi systemd-timesyncd[345]: Synchronized to time server for the first time 80.92.66.61:123 (2.debian.pool.ntp.org).
Oct 25 10:40:11 raspberrypi dhcpcd[458]: timed out
Oct 25 10:40:11 raspberrypi dhcpcd[458]: forked to background, child pid 650
Oct 25 10:40:11 raspberrypi systemd[1]: Started dhcpcd on all interfaces.
Oct 25 10:40:11 raspberrypi systemd[1]: Reached target Network.
Oct 25 10:40:11 raspberrypi systemd[1]: Reached target Network is Online.
Oct 25 10:40:11 raspberrypi systemd[1]: Starting LSB: web-based administration interface for Unix systems...
Oct 25 10:40:11 raspberrypi systemd[1]: Starting LSB: Update dynamic domain name service entries...
Oct 25 10:40:11 raspberrypi systemd[1]: Starting Permit User Sessions...
Oct 25 10:40:11 raspberrypi systemd[1]: Starting OpenBSD Secure Shell server...
Oct 25 10:40:11 raspberrypi systemd[1]: Starting dnsmasq - A lightweight DHCP and caching DNS server...
Oct 25 10:40:11 raspberrypi systemd[1]: Condition check resulted in fast remote file copy program daemon being skipped.
Oct 25 10:40:11 raspberrypi systemd[1]: Starting Advanced IEEE 802.11 AP and IEEE 802.1X/WPA/WPA2/EAP Authenticator...
Oct 25 10:40:11 raspberrypi systemd[1]: Starting /etc/rc.local Compatibility...
Oct 25 10:40:11 raspberrypi systemd[1]: Started Permit User Sessions.
Oct 25 10:40:11 raspberrypi systemd[1]: Started /etc/rc.local Compatibility.
Oct 25 10:40:11 raspberrypi systemd[1]: Started Serial Getty on ttyAMA0.
Oct 25 10:40:11 raspberrypi systemd[1]: Started Getty on tty1.
Oct 25 10:40:11 raspberrypi systemd[1]: Reached target Login Prompts.
Oct 25 10:40:11 raspberrypi dnsmasq[659]: dnsmasq: revisión de sintaxis OK.
Oct 25 10:40:11 raspberrypi hostapd[660]: Configuration file: /etc/hostapd/hostapd.conf
Oct 25 10:40:12 raspberrypi hostapd[660]: wlan0: interface state UNINITIALIZED->COUNTRY_UPDATE
Oct 25 10:40:12 raspberrypi systemd[1]: Started Advanced IEEE 802.11 AP and IEEE 802.1X/WPA/WPA2/EAP Authenticator.
Oct 25 10:40:12 raspberrypi systemd[1]: Started OpenBSD Secure Shell server.
Oct 25 10:40:12 raspberrypi dhcpcd[650]: wlan0: carrier acquired
Oct 25 10:40:12 raspberrypi kernel: [ 43.679396] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Oct 25 10:40:12 raspberrypi dnsmasq[677]: iniciado, versión 2.80 tamaño de caché 150
Oct 25 10:40:12 raspberrypi dnsmasq[677]: opciones de compilación: IPv6 GNU-getopt DBus i18n IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth DNSSEC loop-detect inotify dumpfile
Oct 25 10:40:12 raspberrypi dnsmasq[677]: advertencia: interfase wlan0 no existe actualmente
Oct 25 10:40:12 raspberrypi dnsmasq-dhcp[677]: DHCP, IP range 192.168.10.3 -- 192.168.10.7, tiempo de concesión1d
Oct 25 10:40:12 raspberrypi dnsmasq[677]: leyendo /run/dnsmasq/resolv.conf
Oct 25 10:40:12 raspberrypi dnsmasq[677]: usando nombre de servidor 37.252.183.23#53
Oct 25 10:40:12 raspberrypi dnsmasq[677]: usando nombre de servidor 94.143.75.14#53
Oct 25 10:40:12 raspberrypi dnsmasq[677]: direcciónes /etc/hosts - 5 leídas
Oct 25 10:40:12 raspberrypi dhcpcd[650]: DUID 00:01:00:01:27:5a:4b:69:b8:27:eb:d5:83:a9
Oct 25 10:40:12 raspberrypi dhcpcd[650]: wlan0: IAID eb:80:d6:fc
Oct 25 10:40:12 raspberrypi dhcpcd[650]: wlan0: adding address fe80::1dd7:174e:ddbc:cb12
Oct 25 10:40:12 raspberrypi dhcpcd[650]: wlan0: probing address 192.168.10.1/24
Oct 25 10:40:12 raspberrypi avahi-daemon[409]: Joining mDNS multicast group on interface wlan0.IPv6 with address fe80::1dd7:174e:ddbc:cb12.
Oct 25 10:40:12 raspberrypi avahi-daemon[409]: New relevant interface wlan0.IPv6 for mDNS.
Oct 25 10:40:12 raspberrypi avahi-daemon[409]: Registering new address record for fe80::1dd7:174e:ddbc:cb12 on wlan0.*.
Oct 25 10:40:12 raspberrypi dnsmasq[678]: Too few arguments.
Oct 25 10:40:12 raspberrypi systemd[1]: Started dnsmasq - A lightweight DHCP and caching DNS server.
Oct 25 10:40:12 raspberrypi systemd[1]: Reached target Host and Network Name Lookups.
Oct 25 10:40:12 raspberrypi systemd[1]: Starting WireGuard via wg-quick(8) for wg0...
Oct 25 10:40:12 raspberrypi systemd[1]: Started LSB: Update dynamic domain name service entries.
Oct 25 10:40:12 raspberrypi wg-quick[728]: [#] ip link add wg0 type wireguard
Oct 25 10:40:12 raspberrypi kernel: [ 44.051532] wireguard: WireGuard 1.0.0 loaded. See www.wireguard.com for information.
Oct 25 10:40:12 raspberrypi kernel: [ 44.051547] wireguard: Copyright (C) 2015-2019 Jason A. Donenfeld <Jason@zx2c4.com>. All Rights Reserved.
Oct 25 10:40:12 raspberrypi wg-quick[728]: [#] wg setconf wg0 /dev/fd/63
Oct 25 10:40:12 raspberrypi hostapd: wlan0: STA 40:f5:20:3a:fe:d4 IEEE 802.11: associated
Oct 25 10:40:12 raspberrypi hostapd: wlan0: STA 40:f5:20:3a:fe:d4 RADIUS: starting accounting session 3F55947B12DCBB0F
Oct 25 10:40:12 raspberrypi hostapd: wlan0: STA 40:f5:20:3a:fe:d4 WPA: pairwise key handshake completed (RSN)
Oct 25 10:40:12 raspberrypi dnsmasq-dhcp[677]: Paquete DHCP recibido en wlan0 que no tiene dirección
Oct 25 10:40:12 raspberrypi wg-quick[728]: [#] ip -4 address add 10.0.0.2 dev wg0
Oct 25 10:40:12 raspberrypi wg-quick[728]: [#] ip link set mtu 1420 up dev wg0
Oct 25 10:40:12 raspberrypi wg-quick[728]: [#] resolvconf -a wg0 -m 0 -x
Oct 25 10:40:12 raspberrypi dnsmasq[677]: usando nombre de servidor 1.1.1.1#53
Oct 25 10:40:12 raspberrypi wg-quick[728]: Too few arguments.
Oct 25 10:40:12 raspberrypi wg-quick[728]: [#] wg set wg0 fwmark 51820
Oct 25 10:40:12 raspberrypi wg-quick[728]: [#] ip -4 route add 0.0.0.0/0 dev wg0 table 51820
Oct 25 10:40:12 raspberrypi wg-quick[728]: [#] ip -4 rule add not fwmark 51820 table 51820
Oct 25 10:40:12 raspberrypi wg-quick[728]: [#] ip -4 rule add table main suppress_prefixlength 0
Oct 25 10:40:12 raspberrypi wg-quick[728]: [#] sysctl -q net.ipv4.conf.all.src_valid_mark=1
Oct 25 10:40:12 raspberrypi dhcpcd[650]: wlan0: soliciting an IPv6 router
Oct 25 10:40:12 raspberrypi wg-quick[728]: [#] iptables-restore -n
Oct 25 10:40:13 raspberrypi systemd[1]: Started WireGuard via wg-quick(8) for wg0.
Oct 25 10:40:14 raspberrypi dnsmasq-dhcp[677]: Paquete DHCP recibido en wlan0 que no tiene dirección
Oct 25 10:40:16 raspberrypi hostapd: wlan0: STA 0c:60:76:1a:31:e3 IEEE 802.11: associated
Oct 25 10:40:16 raspberrypi hostapd: wlan0: STA 0c:60:76:1a:31:e3 RADIUS: starting accounting session 946DF4D83DFCAC5A
Oct 25 10:40:16 raspberrypi hostapd: wlan0: STA 0c:60:76:1a:31:e3 WPA: pairwise key handshake completed (RSN)
Oct 25 10:40:17 raspberrypi systemd[1]: Started LSB: web-based administration interface for Unix systems.
Oct 25 10:40:17 raspberrypi systemd[1]: Reached target Multi-User System.
Oct 25 10:40:17 raspberrypi systemd[1]: Reached target Graphical Interface.
Oct 25 10:40:17 raspberrypi systemd[1]: Starting Update UTMP about System Runlevel Changes...
Oct 25 10:40:17 raspberrypi systemd[1]: systemd-update-utmp-runlevel.service: Succeeded.
Oct 25 10:40:17 raspberrypi systemd[1]: Started Update UTMP about System Runlevel Changes.
Oct 25 10:40:17 raspberrypi systemd[1]: Startup finished in 5.312s (kernel) + 43.287s (userspace) = 48.599s.
Oct 25 10:40:17 raspberrypi dhcpcd[650]: wlan0: using static address 192.168.10.1/24
Oct 25 10:40:17 raspberrypi avahi-daemon[409]: Joining mDNS multicast group on interface wlan0.IPv4 with address 192.168.10.1.
Oct 25 10:40:17 raspberrypi avahi-daemon[409]: New relevant interface wlan0.IPv4 for mDNS.
Oct 25 10:40:17 raspberrypi avahi-daemon[409]: Registering new address record for 192.168.10.1 on wlan0.IPv4.
Oct 25 10:40:17 raspberrypi dhcpcd[650]: wlan0: adding route to 192.168.10.0/24
Oct 25 10:40:18 raspberrypi dnsmasq-dhcp[677]: DHCPDISCOVER(wlan0) 40:f5:20:3a:fe:d4
Oct 25 10:40:18 raspberrypi dnsmasq-dhcp[677]: DHCPOFFER(wlan0) 192.168.10.7 40:f5:20:3a:fe:d4
Oct 25 10:40:18 raspberrypi dnsmasq-dhcp[677]: DHCPREQUEST(wlan0) 192.168.10.7 40:f5:20:3a:fe:d4
Oct 25 10:40:18 raspberrypi dnsmasq-dhcp[677]: DHCPACK(wlan0) 192.168.10.7 40:f5:20:3a:fe:d4 ESP-3AFED4
Oct 25 10:40:25 raspberrypi dhcpcd[650]: wlan0: no IPv6 Routers available
Oct 25 10:40:27 raspberrypi weewx[507] INFO user.interceptor: skipping rain measurement of 0.0: no last rain
Oct 25 10:40:32 raspberrypi weewx[507] INFO weewx.cheetahgenerator: Generated 8 files for report StandardReport in 4.51 seconds
Oct 25 10:40:34 raspberrypi weewx[507] INFO weewx.imagegenerator: Generated 12 images for report StandardReport in 2.14 seconds
Oct 25 10:40:34 raspberrypi weewx[507] INFO weewx.reportengine: Copied 1 files to /var/www/html/weewx
Oct 25 10:40:35 raspberrypi weewx[507] INFO paramiko.transport: Connected (version 2.0, client OpenSSH_7.9p1)
Oct 25 10:40:36 raspberrypi hostapd: wlan0: STA ac:07:5f:2a:7f:12 IEEE 802.11: associated
Oct 25 10:40:36 raspberrypi hostapd: wlan0: STA ac:07:5f:2a:7f:12 RADIUS: starting accounting session F82E88501AC145F2
Oct 25 10:40:36 raspberrypi hostapd: wlan0: STA ac:07:5f:2a:7f:12 WPA: pairwise key handshake completed (RSN)
Oct 25 10:40:36 raspberrypi weewx[507] INFO paramiko.transport: Authentication (password) successful!
Oct 25 10:40:36 raspberrypi dnsmasq-dhcp[677]: DHCPDISCOVER(wlan0) ac:07:5f:2a:7f:12
Oct 25 10:40:36 raspberrypi dnsmasq-dhcp[677]: DHCPOFFER(wlan0) 192.168.10.5 ac:07:5f:2a:7f:12
Oct 25 10:40:36 raspberrypi dnsmasq-dhcp[677]: DHCPREQUEST(wlan0) 192.168.10.5 ac:07:5f:2a:7f:12
Oct 25 10:40:36 raspberrypi dnsmasq-dhcp[677]: DHCPACK(wlan0) 192.168.10.5 ac:07:5f:2a:7f:12 HUAWEI_P20_Pro-4dd85a13c3
Oct 25 10:40:36 raspberrypi weewx[507] INFO paramiko.transport.sftp: [chan 0] Opened sftp connection (server version 3)
Oct 25 10:41:01 raspberrypi CRON[973]: (root) CMD (/home/chve/scripts/Copiar_Archivos/CopiarArchivos.sh #Copia CAM)
Oct 25 10:41:47 raspberrypi dnsmasq-dhcp[677]: DHCPRELEASE(wlan0) 192.168.10.6 0c:60:76:1a:31:e3
Oct 25 10:41:47 raspberrypi hostapd: wlan0: STA 0c:60:76:1a:31:e3 IEEE 802.11: disassociated
Oct 25 10:44:34 raspberrypi hostapd: wlan0: STA ac:07:5f:2a:7f:12 IEEE 802.11: disassociated
Aqui ya termino. Me lio con tanto mensaje.
