No se pueden resolver DNS
Edu2008
Hola:
Pues nada, de nuevo con problemas.
Resulta que iba a actualizar e instalar syncthing (ya que el uso que le quiero dar a la RPi es de una pequeña nube que me tenga todos los ficheros de mi directorio de trabajo replicados en otro disco duro) haciendo:
sudo apt-get update
sudo apt-get install syncthing
cuando me sale el error de:
Get:1 file:/var/cache/openmediavault/archives InRelease
Err:2 http://deb.debian.org/debian bullseye InRelease
Could not resolve 'deb.debian.org'
Ign:1 file:/var/cache/openmediavault/archives InRelease
Get:3 file:/var/cache/openmediavault/archives Release
Ign:3 file:/var/cache/openmediavault/archives Release
Get:4 file:/var/cache/openmediavault/archives Packages
Ign:4 file:/var/cache/openmediavault/archives Packages
Err:5 http://deb.debian.org/debian bullseye-updates InRelease
Err:6 http://archive.raspberrypi.org/debian bullseye InRelease
Could not resolve 'archive.raspberrypi.org'
Get:7 file:/var/cache/openmediavault/archives Translation-en
Ign:7 file:/var/cache/openmediavault/archives Translation-en
Err:8 http://packages.openmediavault.org/public shaitan InRelease
Could not resolve 'packages.openmediavault.org'
Err:9 https://apt.syncthing.net syncthing InRelease
Could not resolve 'apt.syncthing.net'
Err:10 https://download.docker.com/linux/debian bullseye InRelease
Could not resolve 'download.docker.com'
Err:11 https://openmediavault-plugin-developer ... ges/debian shaitan InRelease
Could not resolve 'openmediavault-plugin-developers.github.io'
Err:12 https://openmediavault.github.io/packages shaitan InRelease
Could not resolve 'openmediavault.github.io'
Err:13 http://httpredir.debian.org/debian bullseye-backports InRelease
Could not resolve 'httpredir.debian.org'
Reading package lists... Done
W: Failed to fetch http://deb.debian.org/debian/dists/bullseye/InRelease Could not resolve 'deb.debian.org'
W: Failed to fetch http://deb.debian.org/debian/dists/bull ... /InRelease Could not resolve 'deb.debian.org'
W: Failed to fetch https://openmediavault-plugin-developer ... /InRelease Could not resolve 'openmediavault-plugin-developers.github.io'
W: Failed to fetch https://download.docker.com/linux/debia ... /InRelease Could not resolve 'download.docker.com'
W: Failed to fetch http://httpredir.debian.org/debian/dist ... /InRelease Could not resolve 'httpredir.debian.org'
W: Failed to fetch http://packages.openmediavault.org/publ ... /InRelease Could not resolve 'packages.openmediavault.org'
W: Failed to fetch https://openmediavault.github.io/packag ... /InRelease Could not resolve 'openmediavault.github.io'
W: Failed to fetch http://archive.raspberrypi.org/debian/d ... /InRelease Could not resolve 'archive.raspberrypi.org'
W: Failed to fetch https://apt.syncthing.net/dists/syncthing/InRelease Could not resolve 'apt.syncthing.net'
W: Some index files failed to download. They have been ignored, or old ones used instead.
Googleando un poco, parece que hacer un ping a un servidor de nombres, como el de Google, puede dar una pista, y este es mi resultado:
ping 8.8.8.8
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
From 192.168.1.169 icmp_seq=1 Destination Host Unreachable
From 192.168.1.169 icmp_seq=2 Destination Host Unreachable
En muchos sitios hablan de modificar archivos como resolv.conf o interfaces, pero todos ellos son generados, y dicen que no se editen a mano.
En fin, de nuevo pido ayuda. Saludos y gracias!
¿Qué tienes en /etc/resolv.conf?
¿Y puedes hacer ping a algún sitio (IP) de internet?
Ejemplo: 193.101.111.20
Edu2008
Edu2008
egrueda escribió: 16 Abr 2022, 12:36 ¿Qué tienes en /etc/resolv.conf?
Hola:
Pues los ping solo me funcionan a otro ordenador de la red.
Por ejemplo, si hago ping al ordenador desde el que estoy (192.168.1.140), pues sí que funciona.
Si hago ping al router (no sé si estoy diciendo una burrada), en fin, si hago ping a 192.168.1.0 no funciona. (Destination Host Unreachable)
Y a cualquier otra dirección de fuera, igual.
Respecto al contenido del archivo resolv.conf:
# This file is managed by man:systemd-resolved(8). Do not edit.
# This is a dynamic resolv.conf file for connecting local clients directly to
# all known uplink DNS servers. This file lists all configured search domains.
# Third party programs should typically not access this file directly, but only
# through the symlink at /etc/resolv.conf. To manage man:resolv.conf(5) in a
# different way, replace this symlink by a static file or a different symlink.
# See man:systemd-resolved.service(8) for details about the supported modes of
# operation for /etc/resolv.conf.
nameserver 46.6.113.34
search RASPBERRY
(He de aclarar que la línea de nameserver 46.6.113.34 la he añadido yo a mano y es el DNS primario que me sale en el router, y que juraría que la siguiente línea de search RASPBERRY no la he escrito yo, aunque no me sonaba de haberla visto antes...también es verdad que uno se pone ya a copiar y pegar "remedios" vistos en google sin criterio y ya pierdo el norte).
Saludos y gracias de nuevo.
Tu router no es 192.168.1.0, será el 192.168.1.1
¿Es posible que hayas metido mal la puerta de enlace?
Edu2008
Edu2008
egrueda escribió: 16 Abr 2022, 14:16 Tu router no es 192.168.1.0, será el 192.168.1.1
¡Era eso! Qué mendrugo soy.
El caso es que el dato lo saqué haciendo netstat -nr
En fin, ¡muchas gracias de nuevo! Ya se conecta y he podido instalar synchthing :guiño2
