Problema con pantalla 3.5 pulgadas
Miliko
Hola a todos
Tengo un problemilla al instalar una pantalla de 3.5 pulgadas en mi Raspberry PI 3. instalo según los comando del fabricante pero me aparece el siguiente error y solo se ve un cursor parpadeando en la pantalla después de reiniciar, agradezco de antemano vuestra ayuda:
# sudo rm -rf LCD-show
# git clone https://github.com/lcdgogo/LCD-show.git
Cloning into 'LCD-show'...
remote: Enumerating objects: 250, done.
remote: Counting objects: 100% (42/42), done.
remote: Compressing objects: 100% (42/42), done.
remote: Total 250 (delta 26), reused 0 (delta 0), pack-reused 208 (from 1)
Receiving objects: 100% (250/250), 2.08 MiB | 531.00 KiB/s, done.
Resolving deltas: 100% (128/128), done.
Updating files: 100% (212/212), done.
# chmod -R 755 LCD-show
# cd LCD-show/
# sudo ./MHS35-show
(Reading database ... 131629 files and directories currently installed.)
Removing xserver-xorg-input-evdev (1:2.10.6-2+b1) ...
Processing triggers for man-db (2.11.2-2) ...
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
git is already the newest version (1:2.39.5-0+deb12u1).
cmake is already the newest version (3.25.1-1).
0 upgraded, 0 newly installed, 0 to remove and 10 not upgraded.
Cloning into 'rpi-fbcp'...
remote: Enumerating objects: 61, done.
remote: Total 61 (delta 0), reused 0 (delta 0), pack-reused 61 (from 1)
Receiving objects: 100% (61/61), 18.26 KiB | 434.00 KiB/s, done.
Resolving deltas: 100% (20/20), done.
CMake Warning (dev) in CMakeLists.txt:
No project() command is present. The top-level CMakeLists.txt file must
contain a literal, direct call to the project() command. Add a line of
code such as
project(ProjectName)
near the top of the file, but after cmake_minimum_required().
CMake is pretending there is a "project(Project)" command on the first
line.
This warning is for project developers. Use -Wno-dev to suppress it.
-- The C compiler identification is GNU 12.2.0
-- The CXX compiler identification is GNU 12.2.0
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: /usr/bin/cc - skipped
-- Detecting C compile features
-- Detecting C compile features - done
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/c++ - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
CMake Deprecation Warning at CMakeLists.txt:1 (cmake_minimum_required):
Compatibility with CMake < 2.8.12 will be removed from a future version of
CMake.
Update the VERSION argument <min> value or use a ...<max> suffix to tell
CMake that the project does not need compatibility with older versions.
-- Configuring done
-- Generating done
-- Build files have been written to: /home/ea4co/LCD-show/rpi-fbcp/build
[ 50%] Building C object CMakeFiles/fbcp.dir/main.c.o
[100%] Linking C executable fbcp
[100%] Built target fbcp
(2024-05-29)
./MHS35-show: line 71: test: (2024-05-29): integer expression expected
need to update touch configuration
Selecting previously unselected package xserver-xorg-input-evdev:armhf.
(Reading database ... 131619 files and directories currently installed.)
Preparing to unpack .../xserver-xorg-input-evdev_1%3a2.10.6-1+b1_armhf.deb ...
Unpacking xserver-xorg-input-evdev:armhf (1:2.10.6-1+b1) ...
dpkg: dependency problems prevent configuration of xserver-xorg-input-evdev:armhf:
xserver-xorg-input-evdev:armhf depends on libc6 (>= 2.7).
xserver-xorg-input-evdev:armhf depends on libevdev2 (>= 1.2.2+dfsg-1~).
xserver-xorg-input-evdev:armhf depends on libmtdev1 (>= 1.1.0).
xserver-xorg-input-evdev:armhf depends on libudev1 (>= 183).
xserver-xorg-input-evdev:armhf depends on xorg-input-abi-24.
xserver-xorg-input-evdev:armhf depends on xserver-xorg-core (>= 2:1.18.99.901).
dpkg: error processing package xserver-xorg-input-evdev:armhf (--install):
dependency problems - leaving unconfigured
Errors were encountered while processing:
reboot now
Broadcast message from root@Raspberry on pts/2 (Tue 2024-10-01 11:22:18 CEST):
The system will reboot now!
¿Qué versión de debian/raspiOS tienes exactamente?
cat /etc/debian_version
