Marin270277 escribió:Buenos días me podríais pasar algún tuto para instalar dongle bluetoch en recalbox y mi rasberri pi3 gracias
Arranca el recalbox y accede a la terminal pulsando F4 y después ALT+F2.
Usuario: root
Pass: recalboxroot
Abre el archivo /recalbox/share/system/recalbox.conf y comprueba que tienes activado los mandos:
# -------------- D - Controllers ----------------- #
# Enable support for standard bluetooth controllers
controllers.bluetooth.enabled=1
## Please enable only one of these
# -------------- D1 - PS3 Controllers ------------ #
##Enable PS3 controllers support
controllers.ps3.enabled=1
## Choose an driver between official, shanwan and gasia if you have dualshock clones (official,shanwan,gasia)
controllers.ps3.driver=official
# ------------ D2 - XBOX Controllers ------------ #
## Xbox controllers are already supported, but xboxdrv can solve some compatibility issues
## Enable xboxdrv driver, disable this if you enabled ps3 controllers (0,1)
controllers.xboxdrv.enabled=0
## Set the amount of controllers to use with xboxdrv (0..4)
controllers.xboxdrv.nbcontrols=2
# ------------ D3 - GPIO Controllers ------------ #
## GPIO Controllers
## enable controllers on GPIO with mk_arcarde_joystick_rpi (0,1)
controllers.gpio.enabled=0
## mk_gpio arguments, map=1 for one controller, map=1,2 for 2 (map=1,map=1,2)
controllers.gpio.args=map=1,2
## DB9 Controllers
## Enable DB9 drivers for atari, megadrive, amiga controllers (0,1)
controllers.db9.enabled=0
## db9 arguments
controllers.db9.args=map=1
## Gamecon controllers
## Enable gamecon controllers, for nes, snes psx (0,1)
controllers.gamecon.enabled=0
## gamecon_args
controllers.gamecon.args=map=1
## XGaming's XArcade Tankstik and other compatible devices
controllers.xarcade.enabled=1
Comprueba si tu mando es compatible con recalbox
https://github.com/recalbox/recalbox-os ... y-%28EN%29
Por lo que leo, los de 8bitdo funcionan muy bien, ademas de los de XBOX, PS3 y WiiU
