Hola intento instalar el zoneminder en el cacharrillo y no salgo de un error , a ver si me echais una mano.
La distro que tengo es raspbian-jessie.
Lo intento instalar segun la wiki del programa y me quedo en cuando voy a hacer apt-get install zoneminder.
Este es el error que me da, a ver si alguien me saca de el:
Setting up zoneminder (1.26.5-3.1+rpi1+b12) ...
● zoneminder.service - LSB: Control ZoneMinder as a Service
Loaded: loaded (/etc/init.d/zoneminder)
Active: failed (Result: exit-code) since Tue 2017-02-28 17:49:16 UTC; 29min ago
Feb 28 17:49:12 raspberrypi zmpkg[14669]: INF [Command: start]
Feb 28 17:49:13 raspberrypi sudo[14711]: root : TTY=unknown ; PWD=/usr/share...e
Feb 28 17:49:13 raspberrypi sudo[14711]: pam_unix(sudo:session): session ope...)
Feb 28 17:49:13 raspberrypi sudo[14711]: pam_unix(sudo:session): session clo...a
Feb 28 17:49:13 raspberrypi sudo[14719]: root : TTY=unknown ; PWD=/usr/share...k
Feb 28 17:49:13 raspberrypi sudo[14719]: pam_unix(sudo:session): session ope...)
Feb 28 17:49:16 raspberrypi sudo[14719]: pam_unix(sudo:session): session clo...a
Feb 28 17:49:16 raspberrypi zoneminder[14666]: Starting ZoneMinder: failure
Feb 28 17:49:16 raspberrypi systemd[1]: zoneminder.service: control process ...1
Feb 28 17:49:16 raspberrypi systemd[1]: Failed to start LSB: Control ZoneMin....
Feb 28 17:49:16 raspberrypi systemd[1]: Unit zoneminder.service entered fail....
Feb 28 18:01:49 raspberrypi systemd[1]: Stopped LSB: Control ZoneMinder as a....
Hint: Some lines were ellipsized, use -l to show in full.
invoke-rc.d: initscript zoneminder, action "status" failed.
Job for zoneminder.service failed. See 'systemctl status zoneminder.service' and 'journalctl -xn' for details.
invoke-rc.d: initscript zoneminder, action "start" failed.
dpkg: error processing package zoneminder (--configure):
subprocess installed post-installation script returned error exit status 1
Processing triggers for libc-bin (2.19-18+deb8u7) ...
Processing triggers for systemd (215-17+deb8u6) ...
Errors were encountered while processing:
zoneminder
E: Sub-process /usr/bin/dpkg returned an error code (1)
