RetroPie 4.2 ya disponible
¡Hola a todos! Para todos los fanáticos del arcade, a partir del 20 de Marzo ya disponéis la nueva versión de RetroPie 4.2 con cambios bastante importantes, a continuación os dejo los cambios ( en inglés ):
EmulationStation Improvements
-Video Support
-White Screen of Death Fix
-Support for the ODroid-C2 (on top of the Ubuntu 16.04 minimal image).
-Kodi 17 now installable from optional packages.
-AdvanceMame has been updated and split into three separate packages – 0.94, 1.4 and v3.3.
-Updated to RetroArch v1.5.0
-To match upstream changes, lr-mupen64plus has been renamed to lr-parallel-n64, and lr-glupen64 has been renamed to -lr-mupen64plus.
-Fixed launching Pixel desktop and other X11 apps from Emulation Station.
-Fixed problems building Zdoom, ResidualVM and Mupen64Plus and PPSSPP.
-Doom ports will automatically add launch scripts if it finds doom1.wad, doom2.wad, tnt.wad, or plutonia.wad.
-lr-snes9x emulator added – a libretro port of the current snes9x codebase.
-Added Amiberry (an Amiga emulator), which is an updated fork of uae4arm, with more features.
-Multi disk zip support for Vice (C64 emulator), fs-uae, uae4arm and Amiberry (Amiga). You can now launch Amiga disk images directly from Emulation Station with uae4arm and Amiberry.
-Standalone version of Stella (Atari 2600 emulator) updated to v4.7.3.
-usbromservice – support mounting of usb stick over ~/RetroPie to keep roms on USB.
-Ability to set custom ES themes in configs/all/platforms.cfg (can override any setting in RetroPie-Setup/platforms.cfg).
-SDL2 updated to 2.0.5. Our patched SDL2 is now used on the PC version of RetroPie, which should resolve an issue with ps3 controller mapping.
-Sselph’s scraper updated to the latest version, and new options added. Scraper has been moved to optional packages and needs to be installed before it will show up in configuration / tools.
-Include PowerBlock and ControlBlock driver packages.
-Input configuration script for Daphne.
-RetroPie-Setup menus now works with all connected joysticks (mapping is still hardcoded).
-Updated RPI detection code to support BRANCH=next firmware/kernel.
-Overhaul of the runcommand launch script.
-Raspbian Wheezy support removed.
-Support Xbian on RPI, and Devuan, Elementary OS, and Neon on X86.
-Added emulationstation themes: fundamental, futura, and flat.
New packages added to experimental section:
-lr-mrboom (an 8 player bomberman clone).
-lr-mame2016 (Arcade emulator).
-lr-mess2016 (Multiple omputers/console emulator).
-DraStic (Nintendo DS Emulator – RPI only).
-lr-beetle-saturn (Sega Saturn emulator – x86_64 only).
-Minivmac (Macintosh Plus Emulator).
-Quasi88 (NEC PC-8801 emulator).
-np2pi (NEC PC-9801 emulator).
-Xm7 (FM-7 / Fujitsu Micro 7 emulator).
-Mehstation and Attract-Mode Frontends.
-launchingimages (a script from Meleu to generate system launch images based on installed Emulation Station themes).
Many other code changes and bugfixes.
Fuente Oficial:
https://retropie.org.uk/2017/03/retropie-4-2-released/
Para descargar RetroPie 4.2:
https://retropie.org.uk/download/
Ruben16v
Al final me vais a hacer pasarme a Retropie, mas vale que recalbox se ponga las pilas metiendo emuladores porque si no....
tiene una pinta muy buena la actualizacion
Tetoaku
En Semana Santa me meto con éste ya que Recalbox sí está probado.
Cemo
Una pregunta. Con darle a actualizar totos los cores pasara a la 4.2 o hay que reinstalar con la imagen?
Dawn
Kike escribió:¡Hola a todos! Para todos los fanáticos del arcade, a partir del 20 de Marzo ya disponéis la nueva versión de RetroPie 4.2 con cambios bastante importantes, a continuación os dejo los cambios ( en inglés ):
-Video Support
Fuente Oficial:
Kike, sabes algún truco para actualizar a 4.2 todos los paquetes excepto el del Kodi? Tengo una BBDD SQL y no me interesa actualizarlo.
jym
No pone nada de que den soporte al interface xin mo, o no lo e sabido ver.
De todas maneras hay que probarlo, gracias Kike
Turbini
¿Se pueden marcar favoritos en este?… para mi es en lo que ganaba Recalbox
Dawn
Dawn escribió: Kike, sabes algún truco para actualizar a 4.2 todos los paquetes excepto el del Kodi? Tengo una BBDD SQL y no me interesa actualizarlo.
Bueno @Kike, estoy actualizando primero los core y después el resto y creo que puedo actualizar todos menos el kodi de esta manera.
miguel.enriquez.
Entonces se puede actualizar desde nuestra imagen 4.1 o hay que empezar de zero?Si es así de zero me buscaré una SD nueva.
elarcadio
Yo lo he actualizado desde 4.1 sin problemas. Se han perdido algunas cosas de la configuración (que muestre los videos aleatorios en el inicio) pero nada que no se pueda arreglar en un momento.
Ruben16v
Puedes navegar por la SD sacar toda la configuracion que tengas puesta y meterla en la nueva imagen siempre que tengas la misma version de Kodi
Al menos en recalbox puedes hacerlo asi, te puede dar algun error de registro luego algun addon pero te vuelves a meter a la SD te lo cepillas entero lo vuelves a instalar y perfecto.
Supongo que en Retropie sera igual ya que Kodi es Kodi
pituabelardo
Turbini escribió:¿Se pueden marcar favoritos en este?… para mi es en lo que ganaba Recalbox
Me uno a tu pregunta.
Para mi, una de las pocas cosas que me gusta más de Recalbox respecto a Retropie es poder marcar los favoritos.
¿Se sabe si se pueden marcar en esta nueva versión?
jawler
He visto que en este nuevo retropie hay una lr-mame2016. Es una nueva versión? toca cambiar de romset?
eclipse6220
Se nota alguna mejoria en algun emulador concreto?
XeNoMoRPH
Voy a probar a actualizar ... a ver que sino implosiona la PI ... Bueno , pues después de actualizar por separado main & core packages pare que todo sigue funconando. :mrgreen:
CANONMASTA
De momento mis Roms de NeoGeo con el nuevo emulador PIFBA no reconocen el mando. A alguien le pasa lo mismo?
Cuando cambio al emulador LR-FBALPHA reconoce el mando pero me va a tirones!!!!!
No estoy muy contento con el 4.2, la verdad...
miguel.enriquez.
Yo de momento no actualizo,ya que estoy bien en 4.1
drewdty
yo pienso como miguel , hasta que no haya cambios mas sustanciosos no me muevo de 4.1
