RaspAnd ANDROID Nougat 7.1.1 para Raspberry Pi 3 y Pi 2 – Build 170127 – con GAPPS y Kodi 17.0-RC4
Hola a todos , hoy os traigo una imagen para Raspberry 2 y 3 que se trata de Android 7.1.1 Nougat junto a Kodi 17.0-RC4.
La imagen está valorada en 9$
Ver imágenes:
Texto y Changelog Original:
RaspAnd Nougat 7.1.1 Build 170127 is an Android 7.1.1 Nougat system which can run on Raspberry Pi 3 and Pi 2. I have included the following apps.
1) GAPPS (latest by 170125)
2) Kodi 17.0-RC4 (with YouTube enabled and working!)
3) Firefox 51.0
4) Spotify 1.0.0
5) Rotation Control Pro 1.1.9
6) AIDA64 1.44
7) Aptoide App Store 8.0.1.2
8) YouTube 1.3.11 (sound, but no video. If you, however, use SnapTube you can download videos/movies from YouTube and replay them in Windows or Linux with perfect video quality)
9) ES File Explorer Pro 1.0.8
10) Gmail 7.1.1
11) Google Play Services 10.2.91
12) Google App 6.10.37.21
13) Google Play Store 7.4.12.L-all (not working, but since Google Play Services work very well you can install many new GAPPS using Aptoide App Store).
14) SnapTube 4.11.0.8.8655
ABOUT KODI
Kodi (an award-winning free and open source (GPL) software media center for playing videos, music, pictures, games, and more) works very well in RaspAnd. You can enable a lot of Add-ons. Most important is that the YouTube Add-on is enabled by default and that it works very well. I.e. both the sound and the video performance in Kodi is satisfying.
What is Raspberry Pi?
The Raspberry Pi is a low cost, credit-card sized computer that plugs into a computer monitor or TV, and uses a standard keyboard and mouse. It is a capable little device that enables people of all ages to explore computing, and to learn how to program in languages like Scratch and Python. It’s capable of doing everything you’d expect a desktop computer to do, from browsing the internet and playing high-definition video, to making spreadsheets, word-processing, and playing games.
Read more about Raspberry Pi…
Kernel
Kernel 4.4.35-exton-v7+ is used in RaspAnd Nougat Build 170127.
KNOWN ISSUES
1. The screen can flicker sometimes on certain monitors. Fix: Click on the screen or wait a moment.
2. Google Play Store won't run. Nothing to do about it (right now). Aptoide is a good replacement since you can install most Google apps using Aptoide.
3. You can't watch videos/movies using the YouTube app. The sound is very good though. Nothing to do about it (right now). Please note that you can run YouTube in Kodi with good video and sound quality.
4. Not all apps will run in RaspAnd Nougat. You can for example run the popular (?) Clash of Clans, but not Angry Birds. Many many apps will run without problems though.
5. You may have to reconnect to your Wifi Network after every reboot of RaspAnd. Sort of a “bug”.
Descargar Imagen:
http://descargas.fororaspberry.es/image ... 170127.zip
Datos para Descargar: Usuario: FORORASPBERRY.ES
Contraseña: ForoRaspberry.es
fatfredycat
Agradecido: 2 veces
Graciaaaas !! A probar!!! :roll:
@Kike como se quema la imagen?Dentro del rar hay la carpeta boot y la .img...
tatxen
Muchas gracias, ya tenia ganas de ver un android decente en la Raspi.
tatxen
fatfredycat escribió:Graciaaaas !! A probar!!! :roll:
Tienes que crear cuatro particiones en la tarjeta:
1 particion Boot en fat32 de 512Mb (y hacerla arrancable)
1 particion /system de 1024Mb (da igual el formato, luego lo vas a reescribir)
1 particion /cache de 512Mb en ext4
1 particion /data con el espacio restante en ext4
los ficheros de la carpeta boot se copian a pelo en la partición boot
La imagen del sistema se copia con dd a la segunda partición de la tarjeta (/system):
sudo dd if=system.img of=/dev/mmcblk0p2 (ojo, esa es la ruta en mi sistema, cámbiala para que coincida con la segunda partición de la tarjeta en tu sistema, puede ser /dev/sdd2 o algo así).
Y listo.
Tiene que quedar tal que asi:
fatfredycat
Agradecido: 2 veces
graciaaaaas!!! Voy a por ello!
tatxen
Pues vaya decepción, menuda castaña. Hay que tener muchos huevos para cobrar por esa mierda.
Dahm83
No tiene mala pinta.
Intentaré probarla a ver que tal, aunque la instalación es un pelin compleja.
josan_
Alguien la ha probado a ver que tal funciona por si merece la pena instalar??????? :relax1
Alfonshow
Gracias por el aporte!
En cuanto pueda la pruebo, sabe alguien que tal rendimiento da? tema de firefox, spotify...etc
carritoman
Una duda, como hago la particion Boot en fat32 arrancable? ( la primera de 512 megas), solo debo copiar los archivos o hacer algo mas .
NOTA: soy usuario de windows, teniendo como linux una distro live cd de ubuntu.
Gracias por la probable ayuda.
Kronic79
gracias colega :roll:
oking
como se monta la imagen?? win32 o hace falta linux?
LaCuota
Como va? solo hay un comentario y no es bueno :enserio?
CapitanSupositorio
Bajando no se como se graba en windows. Pero bueno esperare que contesten
skywalky
Gracias, voy a probarlo a ver que tal va.
herrrerito
Descargando, a ver como funciona, tengo ganas de probarla y a ver si soy capaz de poner el yomvi también
yesusito
como se graba en windows ,no doy con la tecla .
gracias de antemano
sharinghan82
ha salido nueva version, alguien la tiene? :roll:
AMATE
Alguien tiene la imagen en una ISO para quemar directamente?
ivanxo
Tengo la nueva imagen por si alguien le interesa.
En prinicpio esta version puede quemarse en la SD utilizando win32 disk imager
