pues eso...yevo casi una semana liado y nada....no hay manera....
he seguido al pie de la letra un tutorial para conectar dicha camara la cual es la gc2035
estoy ya un poquillo arto de que no funcione...he metido todo lo que dice el tutorial al pie de la letra y nada.... no da imagen...
este es el log que me da...
[0] [NTC] [ALL] [Jun 27 20:38:39] motion_startup: Using log type (ALL) log level (NTC)
[0] [NTC] [ALL] [Jun 27 20:38:39] become_daemon: Motion going to daemon mode
[0] [NTC] [ALL] [Jun 27 20:38:39] become_daemon: Created process id file /var/run/motion/motion.pid. Process ID is 562
[0] [NTC] [ALL] [Jun 27 20:38:39] motion_startup: Motion running as daemon process
[0] [NTC] [ENC] [Jun 27 20:38:39] ffmpeg_init: ffmpeg LIBAVCODEC_BUILD 3670272 LIBAVFORMAT_BUILD 3670272
[0] [NTC] [ALL] [Jun 27 20:38:39] main: Thread 1 is from /etc/motion/motion.conf
[0] [NTC] [ALL] [Jun 27 20:38:39] main: Thread 1 is device: /dev/video0 input 0
[0] [NTC] [ALL] [Jun 27 20:38:39] main: Stream port 8081
[0] [ERR] [ALL] [Jun 27 20:38:39] start_motion_thread: Stream port number 8081 for thread 1 conflicts with the control port
[0] [WRN] [ALL] [Jun 27 20:38:39] start_motion_thread: Stream feature for thread 1 is disabled.
[0] [NTC] [ALL] [Jun 27 20:38:39] main: Waiting for threads to finish, pid: 562
[1] [NTC] [ALL] [Jun 27 20:38:39] motion_init: Thread 1 started , motion detection Enabled
[1] [NTC] [VID] [Jun 27 20:38:39] vid_v4lx_start: Using videodevice /dev/video0 and input 0
[1] [ALR] [VID] [Jun 27 20:38:39] vid_v4lx_start: Failed to open video device /dev/video0:
[1] [WRN] [ALL] [Jun 27 20:38:39] motion_init: Could not fetch initial image from camera Motion continues using width and height from config file(s)
[1] [NTC] [ALL] [Jun 27 20:38:39] image_ring_resize: Resizing pre_capture buffer to 1 items
[0] [NTC] [STR] [Jun 27 20:38:39] httpd_run: motion-httpd testing : IPV4 addr: 127.0.0.1 port: 8081
[0] [NTC] [STR] [Jun 27 20:38:39] httpd_run: motion-httpd Bound : IPV4 addr: 127.0.0.1 port: 8081
[0] [NTC] [STR] [Jun 27 20:38:39] httpd_run: motion-httpd/3.2.12+git20140228 running, accepting connections
[0] [NTC] [STR] [Jun 27 20:38:39] httpd_run: motion-httpd: waiting for data on 127.0.0.1 port TCP 8081
[1] [WRN] [ALL] [Jun 27 20:38:40] motion_loop: Retrying until successful connection with camera
[1] [NTC] [VID] [Jun 27 20:38:40] vid_v4lx_start: Using videodevice /dev/video0 and input 0
[1] [ALR] [VID] [Jun 27 20:38:40] vid_v4lx_start: Failed to open video device /dev/video0:
[1] [WRN] [ALL] [Jun 27 20:38:50] motion_loop: Retrying until successful connection with camera
[1] [NTC] [VID] [Jun 27 20:38:50] vid_v4lx_start: Using videodevice /dev/video0 and input 0
[1] [ALR] [VID] [Jun 27 20:38:50] vid_v4lx_start: Failed to open video device /dev/video0:
[1] [NTC] [ALL] [Jun 27 21:17:06] motion_loop: Video signal lost - Adding grey image
[1] [WRN] [ALL] [Jun 27 21:17:10] motion_loop: Retrying until successful connection with camera
[1] [NTC] [VID] [Jun 27 21:17:10] vid_v4lx_start: Using videodevice /dev/video0 and input 0
[1] [ALR] [VID] [Jun 27 21:17:10] vid_v4lx_start: Failed to open video device /dev/video0:
[1] [WRN] [ALL] [Jun 27 21:17:20] motion_loop: Retrying until successful connection with camera
[1] [NTC] [VID] [Jun 27 21:17:20] vid_v4lx_start: Using videodevice /dev/video0 and input 0
[1] [ALR] [VID] [Jun 27 21:17:20] vid_v4lx_start: Failed to open video device /dev/video0:
[1] [WRN] [ALL] [Jun 27 21:17:30] motion_loop: Retrying until successful connection with camera
[1] [NTC] [VID] [Jun 27 21:17:30] vid_v4lx_start: Using videodevice /dev/video0 and input 0
[1] [ALR] [VID] [Jun 27 21:17:30] vid_v4lx_start: Failed to open video device /dev/video0:
[1] [WRN] [ALL] [Jun 27 21:17:40] motion_loop: Retrying until successful connection with camera
[1] [NTC] [VID] [Jun 27 21:17:40] vid_v4lx_start: Using videodevice /dev/video0 and input 0
[1] [ALR] [VID] [Jun 27 21:17:40] vid_v4lx_start: Failed to open video device /dev/video0:
haber si alguien que entienda mas que yo sabe donde esta el fallo porque por mas que busco no encuentro nada
no funciona el modulo de camara original en la orange pi one..
- Agradecido: 8 veces
Bueno, no nos dices nada del software que usas, ni la versión, ni el driver, ni los comandos empleados, lo que ya has probado, etc.
Es difícil analizar el problema con tan pocos datos. Por favor, invierte algo más de tiempo en describir *detalladamente* la incidencia.
Aun así, veo el mensaje
Eso es un problema con el driver de la cámara. No sé siquiera si lo has instalado, así que...Failed to open video device /dev/video0
yeyo_gato
perdon por no haber completado la informacion antes...
la version que uso es esta: Armbian_5.30_Orangepione_Debian_jessie_default_3.4.113.
los drivers tengo estos :
sudo modprobe gc2035
sudo modprobe vfe_v4l2
y para los comandos dejo enlace de donde esta todo lo que he hecho.
https://diyprojects.io/camera-2mp-orang ... VOLXYTyjcf
lo de ese tutorial esta hecho identico....sin variar nada.
el problema es que segun parece la camara la reconoce pero no da video...en el test de imagen da ok en el putty pero imagen nada....si entro por la ip de la camara entra pero no se ve video solo un letrero arriba donde pone unable video device y abajo se ve la fecha y el tiempo transcurrido del video....pero incrementandose como si estuviera funcionando pero sin dar imagen... lo demas es lo que marca el log...
si necesitas algun dato mas no dudes en preguntar...
Insisto en el mensaje:
Haz una cosa: después de ejecutar el "sudo modprobe gc2035" escribe dmesg
A ver si vemos algún error a la hora de cargar el driver.
O el driver no es correcto o algo está pasando.Failed to open video device /dev/video0
Bien, ya tenemos algo :-)
Ejecuta el siguiente comando después de haber ejecutado el modprobe, para tener más info
Paralelamente, te comento que conozco dos casos similares relacionados con el cable:
- en el primero habían conectado el cable cinta al revés
- en el segundo, el cable cinta estaba "flojo" de un extremo y no hacía contacto.
Por favor, revisa que el cable cinta esté bien anclado y prueba a darle la vuelta por si lo tienes al revés.
Parece que el módulo de kernel no es el adecuado para el chip de esa cámara.chip found is not an target chip
sudo modinfo gc2035- en el primero habían conectado el cable cinta al revés
yeyo_gato
filename: /lib/modules/3.4.113-sun8i/kernel/drivers/media/video/sunxi-vfe/ device/gc2035.ko
license: GPL
description: A low-level driver for GalaxyCore gc2035 sensors
author: @lex
author: leonardo lontra
author: raymonxiu
alias: i2c:gc2035
depends: cci,vfe_subdev
intree: Y
vermagic: 3.4.113-sun8i SMP preempt mod_unload modversions ARMv7 p2v8
parm: hres:hres=0 (640x480|1280x720|1600x1200 - 15 FPS), hres=1 (800x6 00|1600x1200 - 10 FPS), hres=2 (320x240|640x480|800x600 - 20 FPS), hres=3 (320x2 40|352x288|640x480 - 15 FPS) (default=0) (uint)
parm: mclk:mclk override (default=0) (uint)
parm: frate:frate override (default=0) (uint)
esto me dice con el sudo modinfo gc2035
license: GPL
author: @lex
author: raymonxiu
alias: i2c:gc2035
intree: Y
ok, ¿y qué pasa con el cable?
En mi respuesta te indicaba que probases a darle la vuelta al cable cinta. Tienes cuatro combinaciones para probar, pero con lo que me respondes no sé si has hecho alguna prueba, sólo me has dicho que está apretado.
Por favor, si pides ayuda, sigue las indicaciones que te damos y respóndenos con toda la información que puedas, si no es imposible saber qué has probado y qué no.
yeyo_gato
Cuanfo he comentado en su sitio es por que lo he comprobado todo tanto que este en la forma correcta como bien apretado... Lo soltado tanto de la placa de la camara como de la board i cluso la misma camara....cambiadas las posiciones y una vez colocado comprobado con multimetro continuidad. Y dejado colocada con la cual existe continuidad.perdon por mi corta respuesta....xo despues de lo arto que estoy de esa placa lo compruebo todo aunke sea lo mas absurdo...creeme que lo que me digan sea lo que sea lo voy a comprobar
