kodi (RPI3) se reinicia
kakitoraspi
hola
tengo kodi 17 en una rpi3 y cada vez que lo intento iniciar, al poco tiempo, cuando carga la info de los canales del addon de movistartv se cierra sin más; he probado a reiniciar y nada, sigue haciendo lo mismo. alguna idea de que puede pasar?
adjunto el último log que tengo.
############## Kodi CRASH LOG ###############
################ SYSTEM INFO ################
Date: mié oct 11 10:21:37 CEST 2017
Kodi Options:
Arch: armv7l
Kernel: Linux 4.4.50-v7+ #970 SMP Mon Feb 20 19:18:29 GMT 2017
Release: Raspbian GNU/Linux 8 (jessie)
############## END SYSTEM INFO ##############
############### STACK TRACE #################
=====> Core file: /home/pi/core (2017-10-11 10:21:08.076647500 +0200)
[New LWP 2864]
[New LWP 2774]
[New LWP 2773]
[New LWP 2772]
[New LWP 2786]
[New LWP 2764]
[New LWP 2782]
[New LWP 2785]
[New LWP 2787]
[New LWP 2768]
[New LWP 2771]
[New LWP 2792]
[New LWP 2795]
[New LWP 2770]
[New LWP 2860]
[New LWP 2796]
[New LWP 2876]
[New LWP 2769]
[New LWP 2859]
[New LWP 2814]
[New LWP 2778]
[New LWP 2875]
[New LWP 2858]
[New LWP 2777]
[New LWP 2857]
[New LWP 2776]
[New LWP 2872]
[New LWP 2856]
[New LWP 2781]
[New LWP 2831]
[New LWP 2855]
[New LWP 2788]
[New LWP 2871]
[New LWP 2874]
[New LWP 2854]
[New LWP 2870]
[New LWP 2843]
[New LWP 2878]
[New LWP 2853]
[New LWP 2869]
[New LWP 2841]
[New LWP 2879]
[New LWP 2852]
[New LWP 2868]
[New LWP 2851]
[New LWP 2840]
[New LWP 2880]
[New LWP 2867]
[New LWP 2850]
[New LWP 2838]
[New LWP 2866]
[New LWP 2849]
[New LWP 2818]
[New LWP 2865]
[New LWP 2848]
[New LWP 2809]
[New LWP 2863]
[New LWP 2846]
[New LWP 2765]
[New LWP 2862]
[New LWP 2861]
[New LWP 2839]
[New LWP 2832]
[New LWP 2847]
[New LWP 2813]
[New LWP 2844]
[New LWP 2808]
[New LWP 2842]
[New LWP 2835]
[New LWP 2807]
[New LWP 2836]
[New LWP 2803]
[New LWP 2799]
[New LWP 2797]
[New LWP 2806]
[New LWP 2789]
[New LWP 2805]
[New LWP 2784]
[New LWP 2775]
[New LWP 2804]
[New LWP 2798]
[New LWP 2802]
[New LWP 2763]
[New LWP 2801]
[New LWP 2800]
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/arm-linux-gnueabihf/libthread_db.so.1".
Core was generated by `/usr/lib/arm-linux-gnueabihf/kodi/kodi_v7.bin --lircdev /var/run/lirc/lircd'.
Program terminated with signal SIGABRT, Aborted.
#0 0x7565df70 in __GI_raise (sig=sig@entry=6) at ../nptl/sysdeps/unix/sysv/linux/raise.c:56
Thread 85 (Thread 0x644ff3b0 (LWP 2800)):
#0 0x756f7b80 in poll () at ../sysdeps/unix/syscall-template.S:81
#1 0x760366e8 in ?? () from /usr/lib/arm-linux-gnueabihf/libavahi-common.so.3
Backtrace stopped: previous frame identical to this frame (corrupt stack?)
Thread 84 (Thread 0x63cff3b0 (LWP 2801)):
#0 0x756fa964 in select () at ../sysdeps/unix/syscall-template.S:81
#1 0x76848344 in ?? () from /usr/lib/arm-linux-gnueabihf/libmicrohttpd.so.10
Thread 83 (Thread 0x73fe62a0 (LWP 2763)):
#0 0x76f6a3d4 in memcmp () from /usr/lib/arm-linux-gnueabihf/libarmmem.so
#1 0x00000000 in ?? ()
Thread 82 (Thread 0x634ff3b0 (LWP 2802)):
Thread 81 (Thread 0x654ff3b0 (LWP 2798)):
#0 0x76f38780 in __lll_lock_wait (futex=futex@entry=0x3b60ddc, private=<optimized out>) at ../ports/sysdeps/unix/sysv/linux/arm/nptl/lowlevellock.c:46
#1 0x76f333c4 in __GI___pthread_mutex_lock (mutex=0x3b60ddc) at pthread_mutex_lock.c:114
#2 0x0099e128 in CGUIWindowManager::IsWindowActive(int, bool) const ()
#3 0x00eab8f8 in XBMCAddon::xbmcaddon::Addon::setSetting(char const*, std::string const&) ()
#4 0x01103dc8 in ?? ()
Thread 80 (Thread 0x624ff3b0 (LWP 2804)):
#1 0x004fe97c in NPT_BsdSocketFd::WaitForCondition(bool, bool, bool, int) ()
#2 0x00502538 in NPT_BsdTcpServerSocket::WaitForNewClient(NPT_Socket*&, int, unsigned int) ()
#3 0x0047a104 in PLT_HttpListenTask::DoRun() ()
#4 0x004994e8 in PLT_ThreadTask::Run() ()
#5 0x005180d0 in NPT_PosixThread::EntryPoint(void*) ()
#6 0x76f30e90 in start_thread (arg=0x624ff3b0) at pthread_create.c:311
#7 0x75701598 in ?? () at ../ports/sysdeps/unix/sysv/linux/arm/nptl/../clone.S:92 from /lib/arm-linux-gnueabihf/libc.so.6
Thread 79 (Thread 0x6f7ff3b0 (LWP 2775)):
#0 0x76f357a4 in __pthread_cond_wait (cond=cond@entry=0x723025d8, mutex=mutex@entry=0x723025bc) at pthread_cond_wait.c:187
#1 0x75c1eda8 in _timer_thread (arg=0x723025b8) at /home/dc4/projects/staging/userland/interface/vcos/pthreads/vcos_pthreads.c:722
#2 0x76f30e90 in start_thread (arg=0x6f7ff3b0) at pthread_create.c:311
#3 0x75701598 in ?? () at ../ports/sysdeps/unix/sysv/linux/arm/nptl/../clone.S:92 from /lib/arm-linux-gnueabihf/libc.so.6
Thread 78 (Thread 0x6b39d3b0 (LWP 2784)):
#0 0x76f35b30 in __pthread_cond_timedwait (cond=0x3e0be00, mutex=0x3e0be38, abstime=0x6b39cd28) at pthread_cond_timedwait.c:199
#1 0x00d78ed4 in PERIPHERALS::CPeripheralBus::Process() ()
#2 0x00856410 in CThread::Action() ()
#3 0x008566ac in CThread::staticThread(void*) ()
#4 0x76f30e90 in start_thread (arg=0x6b39d3b0) at pthread_create.c:311
#5 0x75701598 in ?? () at ../ports/sysdeps/unix/sysv/linux/arm/nptl/../clone.S:92 from /lib/arm-linux-gnueabihf/libc.so.6
Thread 77 (Thread 0x61cff3b0 (LWP 2805)):
#0 0x76f35b30 in __pthread_cond_timedwait (cond=0x45e2760, mutex=0x45e2748, abstime=0x61cfed08) at pthread_cond_timedwait.c:199
#1 0x00517b60 in NPT_PosixSharedVariable::WaitUntilEquals(int, int) ()
#2 0x00457d54 in PLT_CtrlPointHouseKeepingTask::DoRun() ()
#3 0x004994e8 in PLT_ThreadTask::Run() ()
#4 0x005180d0 in NPT_PosixThread::EntryPoint(void*) ()
#5 0x76f30e90 in start_thread (arg=0x61cff3b0) at pthread_create.c:311
#6 0x75701598 in ?? () at ../ports/sysdeps/unix/sysv/linux/arm/nptl/../clone.S:92 from /lib/arm-linux-gnueabihf/libc.so.6
Thread 76 (Thread 0x692863b0 (LWP 2789)):
#0 0x76f35b30 in __pthread_cond_timedwait (cond=0x69285d10, mutex=0x69285d40, abstime=0x69285cf8) at pthread_cond_timedwait.c:199
#1 0x6ec5d440 in CEC::CCECStandbyProtection::Process() () from /usr/lib/arm-linux-gnueabihf/libcec.so.4
#2 0x6ec5a4a0 in P8PLATFORM::CThread::ThreadHandler(void*) () from /usr/lib/arm-linux-gnueabihf/libcec.so.4
#3 0x76f30e90 in start_thread (arg=0x692863b0, arg@entry=<error reading variable: Cannot access memory at address 0x78>) at pthread_create.c:311
#4 0x75701598 in ?? () at ../ports/sysdeps/unix/sysv/linux/arm/nptl/../clone.S:92 from /lib/arm-linux-gnueabihf/libc.so.6
/home/pi/dev/gdb-7.7.1+dfsg/gdb/frame.c:472: internal-error: get_frame_id: Assertion `fi->this_id.p' failed.
A problem internal to GDB has been detected,
further debugging may prove unreliable.
Quit this debugging session? (y or n) [answered Y; input not from terminal]
Create a core file of GDB? (y or n) [answered Y; input not from terminal]
############# END STACK TRACE ###############
################# LOG FILE ##################
10:20:59.747 T:1946051232 NOTICE: special://profile/ is mapped to: special://masterprofile/
10:20:59.747 T:1946051232 NOTICE: -----------------------------------------------------------------------
10:20:59.747 T:1946051232 NOTICE: Starting Kodi (17.1 Git:20170401-7804a92-dirty). Platform: Linux ARM 32-bit
10:20:59.747 T:1946051232 NOTICE: Using Release Kodi x32 build (version for Raspberry Pi)
10:20:59.747 T:1946051232 NOTICE: Kodi compiled Apr 2 2017 by GCC 4.9.2 for Linux ARM 32-bit version 3.16.7 (200711)
10:20:59.747 T:1946051232 NOTICE: Running on Raspbian GNU/Linux 8 (jessie), kernel: Linux ARM 32-bit version 4.4.50-v7+
10:20:59.747 T:1946051232 NOTICE: FFmpeg version/source: ffmpeg-3.1-kodi
10:20:59.748 T:1946051232 NOTICE: Host CPU: ARMv7 Processor rev 4 (v7l), 4 cores available
10:20:59.748 T:1946051232 NOTICE: ARM Features: Neon enabled
10:20:59.748 T:1946051232 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
10:20:59.748 T:1946051232 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/arm-linux-gnueabihf/kodi
10:20:59.748 T:1946051232 NOTICE: special://xbmcbinaddons/ is mapped to: /usr/lib/arm-linux-gnueabihf/kodi/addons
10:20:59.748 T:1946051232 NOTICE: special://masterprofile/ is mapped to: /home/pi/.kodi/userdata
10:20:59.748 T:1946051232 NOTICE: special://envhome/ is mapped to: /home/pi
10:20:59.748 T:1946051232 NOTICE: special://home/ is mapped to: /home/pi/.kodi
10:20:59.748 T:1946051232 NOTICE: special://temp/ is mapped to: /home/pi/.kodi/temp
10:20:59.748 T:1946051232 NOTICE: special://logpath/ is mapped to: /home/pi/.kodi/temp
10:20:59.748 T:1946051232 NOTICE: The executable running is: /usr/lib/arm-linux-gnueabihf/kodi/kodi_v7.bin
10:20:59.748 T:1946051232 NOTICE: Local hostname: raspberrypi
10:20:59.748 T:1946051232 NOTICE: Log File is located: /home/pi/.kodi/temp//kodi.log
10:20:59.748 T:1946051232 NOTICE: -----------------------------------------------------------------------
10:20:59.755 T:1946051232 ERROR: DBus: Error org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
10:20:59.783 T:1946051232 NOTICE: load settings...
10:20:59.902 T:1946051232 NOTICE: Found 2 Lists of Devices
10:20:59.902 T:1946051232 NOTICE: Enumerated PI devices:
10:20:59.902 T:1946051232 NOTICE: Device 1
10:20:59.903 T:1946051232 NOTICE: m_deviceName : HDMI
10:20:59.903 T:1946051232 NOTICE: m_displayName : HDMI
10:20:59.903 T:1946051232 NOTICE: m_displayNameExtra:
10:20:59.903 T:1946051232 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
10:20:59.903 T:1946051232 NOTICE: m_channels : FL,FR
10:20:59.903 T:1946051232 NOTICE: m_sampleRates : 8000,11025,16000,22050,24000,32000,44100,48000,88200,96000,176400,192000
10:20:59.903 T:1946051232 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP,AE_FMT_RAW
10:20:59.903 T:1946051232 NOTICE: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_EAC3,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_512
10:20:59.903 T:1946051232 NOTICE: Device 2
10:20:59.903 T:1946051232 NOTICE: m_deviceName : Analogue
10:20:59.903 T:1946051232 NOTICE: m_displayName : Analogue
10:20:59.903 T:1946051232 NOTICE: m_deviceType : AE_DEVTYPE_PCM
10:20:59.903 T:1946051232 NOTICE: m_sampleRates : 48000
10:20:59.903 T:1946051232 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP
10:20:59.903 T:1946051232 NOTICE: m_streamTypes : No passthrough capabilities
10:20:59.903 T:1946051232 NOTICE: Device 3
10:20:59.903 T:1946051232 NOTICE: m_deviceName : Both
10:20:59.903 T:1946051232 NOTICE: m_displayName : HDMI and Analogue
10:20:59.904 T:1946051232 NOTICE: m_channels : FL,FR
10:20:59.904 T:1946051232 NOTICE: m_sampleRates : 48000
10:20:59.904 T:1946051232 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP
10:20:59.904 T:1946051232 NOTICE: m_streamTypes : No passthrough capabilities
10:20:59.904 T:1946051232 NOTICE: Enumerated ALSA devices:
10:20:59.904 T:1946051232 NOTICE: Device 1
10:20:59.904 T:1946051232 NOTICE: m_deviceName : default
10:20:59.904 T:1946051232 NOTICE: m_displayName : Playback/recording through the PulseAudio sound server
10:20:59.904 T:1946051232 NOTICE: m_displayNameExtra:
10:20:59.904 T:1946051232 NOTICE: m_deviceType : AE_DEVTYPE_PCM
10:20:59.904 T:1946051232 NOTICE: m_channels : FL,FR,BL,BR,FC,LFE,SL,SR,UNKNOWN1,UNKNOWN2,UNKNOWN3,UNKNOWN4,UNKNOWN5,UNKNOWN6,UNKNOWN7,UNKNOWN8
10:20:59.904 T:1946051232 NOTICE: m_sampleRates : 5512,8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000
10:20:59.904 T:1946051232 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE,AE_FMT_U8
10:20:59.904 T:1946051232 NOTICE: Device 2
10:20:59.904 T:1946051232 NOTICE: m_deviceName : pulse
10:20:59.904 T:1946051232 NOTICE: m_displayName : PulseAudio Sound Server
10:20:59.917 T:1946051232 NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml
10:20:59.917 T:1946051232 NOTICE: Contents of special://xbmc/system/advancedsettings.xml are...
<?xml version="1.0" encoding="UTF-8" ?>
<advancedsettings>
<fanartres>720</fanartres>
<imageres>540</imageres>
<video>
<busydialogdelayms>750</busydialogdelayms>
</video>
<samba>
<clienttimeout>30</clienttimeout>
</samba>
<cache>
<memorysize>31457280</memorysize>
</cache>
</advancedsettings>
10:20:59.919 T:1946051232 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
10:20:59.919 T:1946051232 NOTICE: Default Video Player: VideoPlayer
10:20:59.919 T:1946051232 NOTICE: Default Audio Player: paplayer
10:20:59.919 T:1946051232 NOTICE: Disabled debug logging due to GUI setting. Level 0.
10:20:59.919 T:1946051232 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
10:20:59.919 T:1946051232 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
10:20:59.920 T:1946051232 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
10:20:59.921 T:1946051232 NOTICE: Loaded playercorefactory configuration
10:20:59.921 T:1946051232 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
10:20:59.921 T:1946051232 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
10:20:59.948 T:1946051232 NOTICE: Running database version Addons27
10:21:00.048 T:1946051232 NOTICE: ADDONS: Using repository repository.xbmc.org
10:21:00.048 T:1946051232 NOTICE: ADDONS: Using repository superrepo.kodi.krypton.all
10:21:00.048 T:1946051232 NOTICE: ADDONS: Using repository repository.popcornmix
10:21:00.118 T:1946051232 NOTICE: Raspberry PI firmware version: Apr 5 2017 11:49:52
Copyright (c) 2012 Broadcom
version 3ca4cf4a663c5351eaec08b29d50d6e8324981b4 (clean) (release)
10:21:00.118 T:1946051232 NOTICE: ARM mem: 752MB GPU mem: 256MB MPG2:0 WVC1:0
10:21:00.118 T:1946051232 NOTICE: cache.memorysize: 30MB libass.cache: 0MB
10:21:00.118 T:1946051232 NOTICE: Config:
arm_freq=1200
audio_pwm_mode=1
config_hdmi_boost=5
core_freq=400
desired_osc_freq=0x36ee80
disable_commandline_tags=2
disable_l2cache=1
disable_splash=1
force_eeprom_read=1
force_pwm_open=1
framebuffer_ignore_alpha=1
framebuffer_swap=1
gpu_freq=300
hdmi_channel_map=8
hdmi_force_cec_address=65535
hdmi_force_hotplug=1
init_uart_clock=0x2dc6c00
lcd_framerate=60
over_voltage_avs=37500
over_voltage_avs_boost=37500
overscan_scale=1
pause_burst_frames=1
program_serial_random=1
sdram_freq=450
second_boot=1
temp_limit=85
device_tree=-
10:21:00.118 T:1946051232 NOTICE: InitWindowSystem: Using EGL Implementation: raspberrypi
10:21:00.120 T:1946051232 NOTICE: Found resolution 640 x 480 for display 0 with 640 x 480 @ 60.000000 Hz
10:21:00.120 T:1946051232 NOTICE: Found resolution 640 x 480 for display 0 with 640 x 480 @ 59.940063 Hz
10:21:00.120 T:1946051232 NOTICE: Found resolution 800 x 600 for display 0 with 800 x 600 @ 60.000000 Hz
10:21:00.120 T:1946051232 NOTICE: Found resolution 800 x 600 for display 0 with 800 x 600 @ 59.940063 Hz
10:21:00.120 T:1946051232 NOTICE: Found resolution 1024 x 768 for display 0 with 1024 x 768 @ 60.000000 Hz
10:21:00.120 T:1946051232 NOTICE: Found resolution 1024 x 768 for display 0 with 1024 x 768 @ 59.940063 Hz
10:21:00.120 T:1946051232 NOTICE: Found resolution 1360 x 768 for display 0 with 1360 x 768 @ 60.000000 Hz
10:21:00.120 T:1946051232 NOTICE: Found resolution 1360 x 768 for display 0 with 1360 x 768 @ 59.940063 Hz
10:21:00.120 T:1946051232 NOTICE: Found resolution 720 x 480 for display 0 with 720 x 480 @ 60.000000 Hz
10:21:00.120 T:1946051232 NOTICE: Found resolution 720 x 480 for display 0 with 720 x 480 @ 59.940063 Hz
10:21:00.120 T:1946051232 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 60.000000 Hz
10:21:00.120 T:1946051232 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 59.940063 Hz
10:21:00.120 T:1946051232 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 60.000000 Hz
10:21:00.120 T:1946051232 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 59.940063 Hz
10:21:00.121 T:1946051232 NOTICE: Found resolution 720 x 576 for display 0 with 720 x 576 @ 50.000000 Hz
10:21:00.121 T:1946051232 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 50.000000 Hz
10:21:00.121 T:1946051232 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 50.000000 Hz
10:21:00.121 T:1946051232 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 24.000000 Hz
10:21:00.121 T:1946051232 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 23.976025 Hz
10:21:00.121 T:1946051232 NOTICE: Found (1920x1080@60.000000) at 28, setting to RES_DESKTOP at 16
10:21:00.121 T:1946051232 NOTICE: Checking resolution 16
10:21:00.411 T:1946051232 NOTICE: GL_VENDOR = Broadcom
10:21:00.411 T:1946051232 NOTICE: GL_RENDERER = VideoCore IV HW
10:21:00.411 T:1946051232 NOTICE: GL_VERSION = OpenGL ES 2.0
10:21:00.411 T:1946051232 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
10:21:00.411 T:1946051232 NOTICE: GL_EXTENSIONS = GL_OES_compressed_ETC1_RGB8_texture GL_OES_compressed_paletted_texture GL_OES_texture_npot GL_OES_depth24 GL_OES_vertex_half_float GL_OES_EGL_image GL_OES_EGL_image_external GL_EXT_discard_framebuffer GL_OES_rgb8_rgba8 GL_OES_depth32 GL_OES_mapbuffer GL_EXT_texture_format_BGRA8888 GL_APPLE_rgb_422 GL_EXT_debug_marker
10:21:01.235 T:1807340464 NOTICE: Register - new cec device registered on cec->RPI: CEC Adapter (2708:1001)
10:21:01.262 T:1858069424 NOTICE: Running database version Addons27
10:21:01.263 T:1858069424 NOTICE: Running database version ViewModes6
10:21:01.265 T:1858069424 NOTICE: Running database version Textures13
10:21:01.271 T:1858069424 NOTICE: Running database version MyMusic60
10:21:01.281 T:1858069424 NOTICE: Running database version MyVideos107
10:21:01.283 T:1858069424 NOTICE: Running database version TV29
10:21:01.285 T:1858069424 NOTICE: Running database version Epg11
10:21:01.287 T:1946051232 NOTICE: start dvd mediatype detection
10:21:01.764 T:1946051232 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
10:21:02.486 T:1946051232 NOTICE: initialize done
10:21:02.486 T:1946051232 NOTICE: Running the application...
10:21:02.495 T:1946051232 NOTICE: starting zeroconf publishing
10:21:02.496 T:1946051232 NOTICE: CWebServer[8080]: Started
10:21:02.496 T:1946051232 NOTICE: starting upnp client
10:21:02.501 T:1624241072 NOTICE: ES: Starting UDP Event server on port 9777
10:21:02.502 T:1624241072 NOTICE: UDP: Listening on port 9777 (ipv6 : false)
10:21:04.618 T:1728738224 ERROR: Create - Error creating
10:21:04.618 T:1728738224 ERROR: Create - Error creating /storage
10:21:04.618 T:1728738224 ERROR: Create - Error creating /storage/recordings
10:21:04.655 T:1728738224 NOTICE: PVRManager - stopping
10:21:04.967 T:1858069424 NOTICE: Start - EPG thread started
############### END LOG FILE ################
############ END Kodi CRASH LOG #############
K
shadowdancer2
Tienes puesto un USB en NTFS para buffer?
Si lo tienes y te hace esto, creo que hay mucha mas gente como tu.
A mi me paso con una iso algo parecido, se reiniciaba a los X segundos e incluso, habia veces que solo hacia el amago de entrar.
Yo lo que hice fue lo siguiente.
1º Pen drive en NTFS para buffer
2º Cambiar la localizacion, leguaje y reloj de la RS
3º Iniciar un juego antes de entrar a Kodi
4º Una vez que veas que es estable (o que no se caiga) dejalo que se actualice si tocar nada (OJO, que tarda un ratillo)
kakitoraspi
hola
no es mi caso, lo he conseguido "arreglar" desinstalando el addon de movistar (en realidad renombre el perfil del usuario que lanza kodi en la RPI y he creado otro), todo funciona bien ahora.
GRACIAS!
