Un saludo a tod@s los usuari@s del foro, solicito vuestra ayuda, ya que tengo un problema que no se como solucianarlo, hace tiempo que no puedo acceder a los contenidos de los addons, ni el Alfa y Adryanlist, es decir, accedo a los addons, pero un vez dentro de las "webs" de series o pelis, siempre me sale error, he reinstalado el osmc y siempre lo mismo, os adjunto el error que me da......
00:00:42.100 T:1958838272 NOTICE: special://profile/ is mapped to: special://masterprofile/
00:00:42.100 T:1958838272 NOTICE: -----------------------------------------------------------------------
00:00:42.100 T:1958838272 NOTICE: Starting Kodi (17.5). Platform: Linux ARM (Thumb) 32-bit
00:00:42.100 T:1958838272 NOTICE: Using Release Kodi x32 build (version for Raspberry Pi)
00:00:42.100 T:1958838272 NOTICE: Kodi compiled Oct 29 2017 by GCC 4.9.2 for Linux ARM (Thumb) 32-bit version 3.16.39 (200743)
00:00:42.100 T:1958838272 NOTICE: Running on Open Source Media Center 2017.10-1, kernel: Linux ARM 32-bit version 4.9.29-10-osmc
00:00:42.100 T:1958838272 NOTICE: FFmpeg version/source: ffmpeg-3.1-kodi
00:00:42.100 T:1958838272 NOTICE: Host CPU: ARMv7 Processor rev 4 (v7l), 4 cores available
00:00:42.100 T:1958838272 NOTICE: ARM Features: Neon disabled
00:00:42.100 T:1958838272 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
00:00:42.100 T:1958838272 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi
00:00:42.100 T:1958838272 NOTICE: special://xbmcbinaddons/ is mapped to: /usr/lib/kodi/addons
00:00:42.100 T:1958838272 NOTICE: special://masterprofile/ is mapped to: /home/osmc/.kodi/userdata
00:00:42.100 T:1958838272 NOTICE: special://envhome/ is mapped to: /home/osmc
00:00:42.101 T:1958838272 NOTICE: special://home/ is mapped to: /home/osmc/.kodi
00:00:42.101 T:1958838272 NOTICE: special://temp/ is mapped to: /home/osmc/.kodi/temp
00:00:42.101 T:1958838272 NOTICE: special://logpath/ is mapped to: /home/osmc/.kodi/temp
00:00:42.101 T:1958838272 NOTICE: The executable running is: /usr/lib/kodi/kodi.bin
00:00:42.101 T:1958838272 NOTICE: Local hostname: osmc
00:00:42.101 T:1958838272 NOTICE: Log File is located: /home/osmc/.kodi/temp//kodi.log
00:00:42.101 T:1958838272 NOTICE: -----------------------------------------------------------------------
00:00:42.866 T:1958838272 ERROR: DBus: Error org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
00:00:42.878 T:1958838272 NOTICE: load settings...
18:42:56.487 T:1958838272 NOTICE: Found 2 Lists of Devices
18:42:56.487 T:1958838272 NOTICE: Enumerated PI devices:
18:42:56.488 T:1958838272 NOTICE: Device 1
18:42:56.488 T:1958838272 NOTICE: m_deviceName : HDMI
18:42:56.488 T:1958838272 NOTICE: m_displayName : HDMI
18:42:56.488 T:1958838272 NOTICE: m_displayNameExtra:
18:42:56.488 T:1958838272 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
18:42:56.488 T:1958838272 NOTICE: m_channels : FL,FR
18:42:56.488 T:1958838272 NOTICE: m_sampleRates : 8000,11025,16000,22050,24000,32000,44100,48000,88200,96000,176400,192000
18:42:56.488 T:1958838272 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP,AE_FMT_RAW
18:42:56.488 T:1958838272 NOTICE: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_EAC3,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_512
18:42:56.488 T:1958838272 NOTICE: Device 2
18:42:56.488 T:1958838272 NOTICE: m_deviceName : Analogue
18:42:56.488 T:1958838272 NOTICE: m_displayName : Analogue
18:42:56.488 T:1958838272 NOTICE: m_deviceType : AE_DEVTYPE_PCM
18:42:56.488 T:1958838272 NOTICE: m_sampleRates : 48000
18:42:56.488 T:1958838272 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP
18:42:56.488 T:1958838272 NOTICE: m_streamTypes : No passthrough capabilities
18:42:56.488 T:1958838272 NOTICE: Device 3
18:42:56.488 T:1958838272 NOTICE: m_deviceName : Both
18:42:56.488 T:1958838272 NOTICE: m_displayName : HDMI and Analogue
18:42:56.489 T:1958838272 NOTICE: Enumerated ALSA devices:
18:42:56.489 T:1958838272 NOTICE: Device 1
18:42:56.489 T:1958838272 NOTICE: m_deviceName : @
18:42:56.489 T:1958838272 NOTICE: m_displayName : Default (bcm2835 ALSA bcm2835 ALSA)
18:42:56.489 T:1958838272 NOTICE: m_displayNameExtra:
18:42:56.489 T:1958838272 NOTICE: m_deviceType : AE_DEVTYPE_PCM
18:42:56.489 T:1958838272 NOTICE: m_channels : FL,FR
18:42:56.489 T:1958838272 NOTICE: m_sampleRates : 8000,11025,16000,22050,32000,44100,48000
18:42:56.489 T:1958838272 NOTICE: m_dataFormats : AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_U8
18:42:56.489 T:1958838272 NOTICE: m_streamTypes : No passthrough capabilities
18:42:56.491 T:1958838272 ERROR: CSettings: unable to load settings from special://masterprofile/guisettings.xml, creating new default settings
18:42:56.573 T:1958838272 NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml
18:42:56.573 T:1958838272 NOTICE: Contents of special://xbmc/system/advancedsettings.xml are...
<?xml version="1.0" encoding="UTF-8" ?>
<!-- Do not modify! These are OSMC Optimised Settings for your device !-->
<!-- If you wish to override any of these values, then create a file in /home/osmc/.kodi/userdata/advancedsettings.xml !-->
<!-- It will override these settings, and your settings will be preserved across OSMC updates !-->
<advancedsettings>
<imageres>540</imageres>
<fanartres>720</fanartres>
<splash>false</splash>
<handlemounting>0</handlemounting>
<samba>
<clienttimeout>30</clienttimeout>
</samba>
</advancedsettings>
18:42:56.575 T:1958838272 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
18:42:56.575 T:1958838272 NOTICE: Default Video Player: VideoPlayer
18:42:56.575 T:1958838272 NOTICE: Default Audio Player: paplayer
18:42:56.575 T:1958838272 NOTICE: Disabled debug logging due to GUI setting. Level 0.
18:42:56.575 T:1958838272 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
18:42:56.575 T:1958838272 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
18:42:56.802 T:1958838272 NOTICE: Loaded playercorefactory configuration
18:42:56.803 T:1958838272 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
18:42:56.803 T:1958838272 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
18:43:32.900 T:1958838272 NOTICE: ADDONS: Using repository repository.xbmc.org
18:43:33.188 T:1958838272 NOTICE: Raspberry PI firmware version: Sep 22 2017 21:36:43
Copyright (c) 2012 Broadcom
version f5217b8887607d0dd890a434de9c73d9aa9a7c0f (clean) (release)
18:43:33.188 T:1958838272 NOTICE: ARM mem: 768MB GPU mem: 256MB MPG2:0 WVC1:0
18:43:33.188 T:1958838272 NOTICE: cache.memorysize: 20MB libass.cache: 0MB
18:43:33.189 T:1958838272 NOTICE: Config:
arm_freq=1200
audio_pwm_mode=1
config_hdmi_boost=5
core_freq=400
desired_osc_freq=0x36ee80
disable_commandline_tags=2
disable_l2cache=1
disable_splash=1
force_eeprom_read=1
force_pwm_open=1
framebuffer_ignore_alpha=1
framebuffer_swap=1
gpu_freq=300
hdmi_channel_map=8
hdmi_force_cec_address=65535
hdmi_ignore_cec_init=1
init_uart_clock=0x2dc6c00
lcd_framerate=60
over_voltage_avs=0x124f8
over_voltage_avs_boost=0x124f8
pause_burst_frames=1
program_serial_random=1
sdram_freq=450
temp_limit=85
device_tree=-
18:43:33.199 T:1958838272 NOTICE: InitWindowSystem: Using EGL Implementation: raspberrypi
18:43:33.201 T:1958838272 NOTICE: Found resolution 640 x 480 for display 0 with 640 x 480 @ 60.000000 Hz
18:43:33.201 T:1958838272 NOTICE: Found resolution 640 x 480 for display 0 with 640 x 480 @ 59.940063 Hz
18:43:33.201 T:1958838272 NOTICE: Found resolution 800 x 600 for display 0 with 800 x 600 @ 60.000000 Hz
18:43:33.201 T:1958838272 NOTICE: Found resolution 800 x 600 for display 0 with 800 x 600 @ 59.940063 Hz
18:43:33.201 T:1958838272 NOTICE: Found resolution 1024 x 768 for display 0 with 1024 x 768 @ 60.000000 Hz
18:43:33.201 T:1958838272 NOTICE: Found resolution 1024 x 768 for display 0 with 1024 x 768 @ 59.940063 Hz
18:43:33.201 T:1958838272 NOTICE: Found resolution 1152 x 864 for display 0 with 1152 x 864 @ 75.000000 Hz
18:43:33.201 T:1958838272 NOTICE: Found resolution 1280 x 1024 for display 0 with 1280 x 1024 @ 60.000000 Hz
18:43:33.201 T:1958838272 NOTICE: Found resolution 1280 x 1024 for display 0 with 1280 x 1024 @ 59.940063 Hz
18:43:33.201 T:1958838272 NOTICE: Found resolution 1680 x 1050 for display 0 with 1680 x 1050 @ 60.000000 Hz
18:43:33.201 T:1958838272 NOTICE: Found resolution 1680 x 1050 for display 0 with 1680 x 1050 @ 59.940063 Hz
18:43:33.201 T:1958838272 NOTICE: Found resolution 1600 x 900 for display 0 with 1600 x 900 @ 60.000000 Hz
18:43:33.201 T:1958838272 NOTICE: Found resolution 1600 x 900 for display 0 with 1600 x 900 @ 59.940063 Hz
18:43:33.201 T:1958838272 NOTICE: Found resolution 720 x 480 for display 0 with 720 x 480 @ 60.000000 Hz
18:43:33.201 T:1958838272 NOTICE: Found resolution 720 x 480 for display 0 with 720 x 480 @ 59.940063 Hz
18:43:33.201 T:1958838272 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 60.000000 Hz
18:43:33.201 T:1958838272 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 59.940063 Hz
18:43:33.201 T:1958838272 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 60.000000 Hz
18:43:33.201 T:1958838272 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 59.940063 Hz
18:43:33.201 T:1958838272 NOTICE: Found resolution 720 x 576 for display 0 with 720 x 576 @ 50.000000 Hz
18:43:33.201 T:1958838272 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 50.000000 Hz
18:43:33.201 T:1958838272 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 50.000000 Hz
18:43:33.201 T:1958838272 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 24.000000 Hz
18:43:33.201 T:1958838272 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 23.976025 Hz
18:43:33.201 T:1958838272 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 30.000000 Hz
18:43:33.201 T:1958838272 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 29.970032 Hz
18:43:33.201 T:1958838272 NOTICE: Found (1920x1080@60.000000) at 33, setting to RES_DESKTOP at 16
18:43:33.202 T:1958838272 NOTICE: Checking resolution 16
18:43:33.536 T:1958838272 NOTICE: GL_VENDOR = Broadcom
18:43:33.536 T:1958838272 NOTICE: GL_RENDERER = VideoCore IV HW
18:43:33.536 T:1958838272 NOTICE: GL_VERSION = OpenGL ES 2.0
18:43:33.536 T:1958838272 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
18:43:33.536 T:1958838272 NOTICE: GL_EXTENSIONS = GL_OES_compressed_ETC1_RGB8_texture GL_OES_compressed_paletted_texture GL_OES_texture_npot GL_OES_depth24 GL_OES_vertex_half_float GL_OES_EGL_image GL_OES_EGL_image_external GL_EXT_discard_framebuffer GL_OES_rgb8_rgba8 GL_OES_depth32 GL_OES_mapbuffer GL_EXT_texture_format_BGRA8888 GL_APPLE_rgb_422 GL_EXT_debug_marker
18:43:48.262 T:1830810608 NOTICE: Register - new cec device registered on cec->RPI: CEC Adapter (2708:1001)
18:43:48.272 T:1938813936 NOTICE: Running database version Addons27
18:44:15.748 T:1958838272 NOTICE: start dvd mediatype detection
18:44:15.826 T:1958838272 WARNING: CSkinInfo: failed to load skin settings
18:44:17.006 T:1958838272 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
18:44:18.606 T:1958838272 NOTICE: initialize done
18:44:18.606 T:1958838272 NOTICE: Running the application...
18:44:18.612 T:1958838272 NOTICE: starting zeroconf publishing
18:44:18.613 T:1958838272 NOTICE: CWebServer[80]: Started
18:44:18.613 T:1958838272 NOTICE: starting upnp client
18:44:18.636 T:1659892720 NOTICE: ES: Starting UDP Event server on port 9777
18:44:18.640 T:1659892720 NOTICE: UDP: Listening on port 9777 (ipv6 : false)
18:44:20.847 T:1764156400 ERROR: DoWork - Direct texture file loading failed for resource://resource.images.weathericons.default/.png
18:44:31.666 T:1745875952 WARNING: CSkinInfo: failed to load skin settings
18:44:33.607 T:1958838272 WARNING: Previous line repeats 1 times.
18:44:33.607 T:1958838272 ERROR: Control 20010 in window 13001 has been asked to focus, but it can't
19:08:27.046 T:1958838272 WARNING: CLangInfo: unable to load language "Spanish". Trying to determine matching language addon...
19:08:28.000 T:1745875952 WARNING: CSkinInfo: failed to load skin settings
19:08:28.282 T:1958838272 ERROR: Control 20010 in window 13002 has been asked to focus, but it can't
19:10:07.122 T:1958838272 WARNING: COMXImageFile::GetCodingType progressive images not supported by decoder
19:10:07.122 T:1958838272 NOTICE: LoadJpeg: unable to load /usr/share/kodi/addons/service.osmc.settings/resources/skins/Default/media/osmc_preview.jpg
19:10:10.223 T:1958838272 WARNING: COMXImageFile::GetCodingType progressive images not supported by decoder
19:10:10.223 T:1958838272 NOTICE: LoadJpeg: unable to load /usr/share/kodi/addons/service.osmc.settings/resources/skins/Default/media/conf_preview.jpg
20:10:18.685 T:1958838272 WARNING: CLangInfo: unable to load language "Spanish". Trying to determine matching language addon...
20:10:19.786 T:1958838272 WARNING: CSkinInfo: failed to load skin settings
20:10:24.267 T:1958838272 WARNING: Cleanup: Having to cleanup texture back_FX.png
20:10:24.267 T:1958838272 WARNING: Cleanup: Having to cleanup texture fwrd_FX.png
20:10:24.267 T:1958838272 WARNING: Cleanup: Having to cleanup texture white.png
20:10:24.267 T:1958838272 WARNING: Cleanup: Having to cleanup texture Curve.png
20:10:25.247 T:1958838272 WARNING: ReleaseTexture: Unable to release texture back_FX.png
20:10:25.400 T:1958838272 WARNING: ReleaseTexture: Unable to release texture fwrd_FX.png
20:10:26.787 T:1745875952 WARNING: CSkinInfo: failed to load skin settings
20:12:03.195 T:1532109808 ERROR: GetDirectory - Error getting
20:12:05.156 T:1532109808 ERROR: Previous line repeats 2 times.
20:12:05.157 T:1532109808 WARNING: COMXImageFile::GetCodingType progressive images not supported by decoder
20:12:05.157 T:1532109808 WARNING: Previous line repeats 1 times.
20:12:05.157 T:1532109808 NOTICE: LoadJpeg: unable to load /usr/share/kodi/addons/service.osmc.settings/fanart.jpg
20:14:16.054 T:1764156400 ERROR: ######## ERROR #########
20:14:16.055 T:1764156400 ERROR: [alfa.core.filetools.read] ERROR al leer el archivo: /home/osmc/.kodi/addons/skin.estuary/addon.xml
20:14:16.057 T:1764156400 ERROR: ######## ERROR #########
20:14:16.057 T:1764156400 ERROR: [alfa.core.filetools.read] Traceback (most recent call last):
File "/home/osmc/.kodi/addons/plugin.video.alfa/core/filetools.py", line 113, in read
f = open(path, "rb")
IOError: [Errno 2] No such file or directory: '/home/osmc/.kodi/addons/skin.estuary/addon.xml'
20:14:16.059 T:1764156400 ERROR: ######## ERROR #########
20:14:16.059 T:1764156400 ERROR: [alfa.core.config.verify_directories_created] Al comprobar o crear la carpeta de resolución
20:14:16.064 T:1764156400 ERROR: ######## ERROR #########
20:14:16.064 T:1764156400 ERROR: [alfa.core.config.verify_directories_created] Traceback (most recent call last):
File "/home/osmc/.kodi/addons/plugin.video.alfa/core/config.py", line 435, in verify_directories_created
res = scrapertools.find_multiple_matches(data, '(<res .*?>)')
File "/home/osmc/.kodi/addons/plugin.video.alfa/core/scrapertools.py", line 102, in find_multiple_matches
return re.findall(pattern, text, re.DOTALL)
File "/usr/lib/python2.7/re.py", line 181, in findall
return _compile(pattern, flags).findall(string)
TypeError: expected string or buffer
20:14:16.204 T:1728312304 ERROR: ######## ERROR #########
20:14:16.204 T:1728312304 ERROR: [alfa.core.filetools.read] ERROR al leer el archivo: /home/osmc/.kodi/addons/skin.estuary/addon.xml
20:14:16.206 T:1728312304 ERROR: ######## ERROR #########
20:14:16.206 T:1728312304 ERROR: [alfa.core.filetools.read] Traceback (most recent call last):
20:14:16.207 T:1728312304 ERROR: ######## ERROR #########
20:14:16.207 T:1728312304 ERROR: [alfa.core.config.verify_directories_created] Al comprobar o crear la carpeta de resolución
20:14:16.209 T:1728312304 ERROR: ######## ERROR #########
20:14:16.209 T:1728312304 ERROR: [alfa.core.config.verify_directories_created] Traceback (most recent call last):
20:14:17.808 T:1958838272 WARNING: ReleaseTexture: Unable to release texture Curve.png
20:14:17.809 T:1958838272 WARNING: ReleaseTexture: Unable to release texture white.png
20:14:39.491 T:1643115504 WARNING: COMXImageFile::GetCodingType progressive images not supported by decoder
20:14:39.504 T:1643115504 WARNING: Previous line repeats 1 times.
20:14:39.504 T:1643115504 NOTICE: LoadJpeg: unable to load /home/osmc/.kodi/addons/plugin.video.alfa/fanart.jpg
20:15:00.701 T:1481778160 ERROR: GetDirectory - Error getting
20:15:02.575 T:1510994928 ERROR: Previous line repeats 6 times.
20:15:02.575 T:1510994928 ERROR: ######## ERROR #########
20:15:02.575 T:1510994928 ERROR: [alfa.core.filetools.read] ERROR al leer el archivo: /home/osmc/.kodi/addons/skin.estuary/addon.xml
20:15:02.576 T:1510994928 ERROR: ######## ERROR #########
20:15:02.576 T:1510994928 ERROR: [alfa.core.filetools.read] Traceback (most recent call last):
20:15:02.577 T:1510994928 ERROR: ######## ERROR #########
20:15:02.577 T:1510994928 ERROR: [alfa.core.config.verify_directories_created] Al comprobar o crear la carpeta de resolución
20:15:02.579 T:1510994928 ERROR: ######## ERROR #########
20:15:02.579 T:1510994928 ERROR: [alfa.core.config.verify_directories_created] Traceback (most recent call last):
20:15:41.531 T:1634726896 WARNING: COMXImageFile::GetCodingType progressive images not supported by decoder
20:15:41.694 T:1634726896 WARNING: Previous line repeats 1 times.
20:15:41.710 T:1634726896 NOTICE: LoadJpeg: unable to load http://s6.postimg.org/9u8m1ep8x/bricocine.jpg
20:16:16.735 T:1498555376 ERROR: ######## ERROR #########
20:16:16.735 T:1498555376 ERROR: [alfa.core.filetools.read] ERROR al leer el archivo: /home/osmc/.kodi/addons/plugin.video.alfa/channels/setting.json
20:16:16.737 T:1498555376 ERROR: ######## ERROR #########
20:16:16.737 T:1498555376 ERROR: [alfa.core.filetools.read] Traceback (most recent call last):
IOError: [Errno 2] No such file or directory: '/home/osmc/.kodi/addons/plugin.video.alfa/channels/setting.json'
20:16:16.737 T:1498555376 ERROR: [alfa.core.jsontools.load] **NO** se ha podido cargar el JSON
20:16:16.739 T:1498555376 ERROR: ######## ERROR #########
20:16:16.739 T:1498555376 ERROR: [alfa.core.jsontools.load] Traceback (most recent call last):
File "/home/osmc/.kodi/addons/plugin.video.alfa/core/jsontools.py", line 38, in load
value = json.loads(*args, **kwargs)
File "/usr/lib/python2.7/json/__init__.py", line 351, in loads
return cls(encoding=encoding, **kw).decode(s)
File "/usr/lib/python2.7/json/decoder.py", line 366, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
20:16:16.740 T:1498555376 ERROR: ######## ERROR #########
20:16:16.740 T:1498555376 ERROR: [alfa.core.channeltools.get_channel_parameters] setting.json error
20:16:27.588 T:1634726896 ERROR: CCurlFile::Stat - Failed: Timeout was reached(28) for https://d12.usercdn.com/i/02278/u875vjx9c0xs.png
20:16:32.338 T:1498555376 WARNING: CSkinInfo: failed to load skin settings
20:16:38.890 T:1498555376 ERROR: EXCEPTION: Non-Existent Control 0
20:19:40.504 T:1532109808 ERROR: ######## ERROR #########
20:19:40.504 T:1532109808 ERROR: [alfa.platformcode.launcher.run] Traceback (most recent call last):
File "/home/osmc/.kodi/addons/plugin.video.alfa/platformcode/launcher.py", line 196, in run
itemlist = getattr(channel, item.action)(item)
File "/home/osmc/.kodi/addons/plugin.video.alfa/channels/plusdede.py", line 663, in findvideos
idioma_0 = idiomas[0]
IndexError: list index out of range
20:19:43.224 T:1958838272 ERROR: GetDirectory - Error getting plugin://plugin.video.alfa/?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
20:19:43.225 T:1958838272 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.alfa/?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) failed
20:19:59.379 T:1532109808 ERROR: ######## ERROR #########
20:19:59.380 T:1532109808 ERROR: [alfa.core.filetools.read] ERROR al leer el archivo: /home/osmc/.kodi/addons/plugin.video.alfa/channels/setting.json
20:19:59.381 T:1532109808 ERROR: ######## ERROR #########
20:19:59.381 T:1532109808 ERROR: [alfa.core.filetools.read] Traceback (most recent call last):
20:19:59.381 T:1532109808 ERROR: [alfa.core.jsontools.load] **NO** se ha podido cargar el JSON
20:19:59.383 T:1532109808 ERROR: ######## ERROR #########
20:19:59.383 T:1532109808 ERROR: [alfa.core.jsontools.load] Traceback (most recent call last):
20:19:59.383 T:1532109808 ERROR: [alfa.core.channeltools.get_channel_parameters] setting.json error
20:20:26.383 T:1481778160 WARNING: CSkinInfo: failed to load skin settings
20:20:26.640 T:1481778160 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
- NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS!
Error Type: <type 'exceptions.TypeError'>
Error Contents: an integer is required
File "/home/osmc/.kodi/addons/plugin.video.alfa/platformcode/xbmc_config_menu.py", line 557, in onInit
self.add_control_bool(c)
File "/home/osmc/.kodi/addons/plugin.video.alfa/platformcode/xbmc_config_menu.py", line 454, in add_control_bool
control.setSelected(self.values[c["id"]])
TypeError: an integer is required
-->End of Python script error report<--
20:20:46.569 T:1481778160 WARNING: CSkinInfo: failed to load skin settings
20:20:46.625 T:1481778160 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
20:22:03.977 T:1958838272 ERROR: Control 55 in window 10025 has been asked to focus, but it can't
20:23:03.725 T:1461711856 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.IOError'>
Error Contents: (2, 'No such file or directory', '/home/osmc/.kodi/userdata/addon_data/plugin.video.adryanlist//LSProdynamicCode.py')
File "/home/osmc/.kodi/addons/plugin.video.adryanlist/default.py", line 3023, in <module>
url,setresolved = getRegexParsed(regexs, url)
File "/home/osmc/.kodi/addons/plugin.video.adryanlist/default.py", line 1278, in getRegexParsed
val=doEvalFunction(m['expres'],link,cookieJar,m)
File "/home/osmc/.kodi/addons/plugin.video.adryanlist/default.py", line 1919, in doEvalFunction
f=open(functions_dir+"/LSProdynamicCode.py","w")
IOError: (2, 'No such file or directory', '/home/osmc/.kodi/userdata/addon_data/plugin.video.adryanlist//LSProdynamicCode.py')
20:23:03.884 T:1958838272 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.adryanlist/?url=%24doregex%5Bid3%5D&mode=17®exs=%7Bu%27nombre2%27%3A%20%7B%27expres%27%3A%20u%27%24pyFunction%3A%5C%27%24doregex%5Bnombre%5D%5C%27.replace%28%22%20%22%2C%20%22%2B%22%29%27%2C%20%27name%27%3A%20u%27nombre2%27%2C%20%27page%27%3A%20None%7D%2C%20u%27nombre%27%3A%20%7B%27expres%27%3A%20u%27Kidnap%27%2C%20%27name%27%3A%20u%27nombre%27%2C%20%27page%27%3A%20None%7D%2C%20u%27id3%27%3A%20%7B%27expres%27%3A%20u%22%23%24pyFunction%5Cndef%20GetLSProData%28page_data%2CCookie_Jar%2Cm%29%3A%5Cn%20%20%20%20import%20urlresolver%5Cn%20%20%20%20url%20%3D%20%27https%3A//streamango.com/f/sscoqnkdrpasqrpf/Kidnap_2017_1080p-dual-cast_mp4%27%5Cn%20%20%20%20try%3A%5Cn%20%20%20%20%20%20%20%20u%20%3D%20urlresolver.resolve%28url%29%5Cn%20%20%20%20except%3A%5Cn%20%20%20%20%20%20%20%20u%20%3D%20%27http%3A//adryanlist.org/error.mp4%27%5Cn%20%20%20%20return%20u%5Cn%22%2C%20%27name%27%3A%20u%27id3%27%2C%20%27page%27%3A%20None%7D%2C%20u%27imagen%27%3A%20%7B%27expres%27%3A%20u%27poster_path%5C%5C%22%3A%5C%5C%22%5C%5C%5C%5C/%28.%2A%3F%29%5C%5C%22%27%2C%20%27name%27%3A%20u%27imagen%27%2C%20%27page%27%3A%20u%27https%3A//api.themoviedb.org/3/search/movie%3Fapi_key%3D3d8a2c67653e2f8fd7dd09959e835f02%26language%3Des%26query%3D%24doregex%5Bnombre2%5D%27%7D%7D]
20:23:15.729 T:1958838272 ERROR: Control 55 in window 10025 has been asked to focus, but it can't
20:23:17.411 T:1490166768 ERROR: ######## ERROR #########
20:23:17.411 T:1490166768 ERROR: [alfa.core.filetools.read] ERROR al leer el archivo: /home/osmc/.kodi/addons/skin.estuary/addon.xml
20:23:17.412 T:1490166768 ERROR: ######## ERROR #########
20:23:17.412 T:1490166768 ERROR: [alfa.core.filetools.read] Traceback (most recent call last):
20:23:17.413 T:1490166768 ERROR: ######## ERROR #########
20:23:17.413 T:1490166768 ERROR: [alfa.core.config.verify_directories_created] Al comprobar o crear la carpeta de resolución
20:23:17.416 T:1490166768 ERROR: ######## ERROR #########
20:23:17.416 T:1490166768 ERROR: [alfa.core.config.verify_directories_created] Traceback (most recent call last):
20:24:20.641 T:1490166768 ERROR: ######## ERROR #########
20:24:20.641 T:1490166768 ERROR: [alfa.platformcode.launcher.run] Traceback (most recent call last):
File "/home/osmc/.kodi/addons/plugin.video.alfa/platformcode/launcher.py", line 256, in run
File "/home/osmc/.kodi/addons/plugin.video.alfa/channels/zpeliculas.py", line 225, in peliculas
'<div class="shortmovies">(.*?)<div class="navigation ignore-select" align="center">')
File "/home/osmc/.kodi/addons/plugin.video.alfa/core/scrapertools.py", line 89, in get_match
return matches[index]
20:24:23.645 T:1958838272 ERROR: GetDirectory - Error getting plugin://plugin.video.alfa/?ewogICAgImFjdGlvbiI6ICJwZWxpY3VsYXMiLCAKICAgICJjYXRlZ29yeSI6ICJacGVsaWN1bGFzIiwgCiAgICAiY2hhbm5lbCI6ICJ6cGVsaWN1bGFzIiwgCiAgICAiZmFuYXJ0IjogImh0dHA6Ly93d3cuenBlbGljdWxhcy5jb20vdGVtcGxhdGVzL215dG9wVjIvaW1hZ2VzL2JhY2tncm91bmQucG5nIiwgCiAgICAiaW5mb0xhYmVscyI6IHt9LCAKICAgICJ0aHVtYm5haWwiOiAiIiwgCiAgICAidGl0bGUiOiAiw5psdGltYXMgcGVsaWN1bGFzIiwgCiAgICAidG90YWxJdGVtcyI6IDAsIAogICAgInVybCI6ICJodHRwOi8vd3d3LnpwZWxpY3VsYXMuY29tLyIsIAogICAgInZpZXdtb2RlIjogIm1vdmllIgp9
20:24:23.646 T:1958838272 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.alfa/?ewogICAgImFjdGlvbiI6ICJwZWxpY3VsYXMiLCAKICAgICJjYXRlZ29yeSI6ICJacGVsaWN1bGFzIiwgCiAgICAiY2hhbm5lbCI6ICJ6cGVsaWN1bGFzIiwgCiAgICAiZmFuYXJ0IjogImh0dHA6Ly93d3cuenBlbGljdWxhcy5jb20vdGVtcGxhdGVzL215dG9wVjIvaW1hZ2VzL2JhY2tncm91bmQucG5nIiwgCiAgICAiaW5mb0xhYmVscyI6IHt9LCAKICAgICJ0aHVtYm5haWwiOiAiIiwgCiAgICAidGl0bGUiOiAiw5psdGltYXMgcGVsaWN1bGFzIiwgCiAgICAidG90YWxJdGVtcyI6IDAsIAogICAgInVybCI6ICJodHRwOi8vd3d3LnpwZWxpY3VsYXMuY29tLyIsIAogICAgInZpZXdtb2RlIjogIm1vdmllIgp9) failed
20:25:01.175 T:1634726896 ERROR: ######## ERROR #########
20:25:01.176 T:1634726896 ERROR: [alfa.platformcode.launcher.run] Traceback (most recent call last):
20:25:27.096 T:1958838272 ERROR: GetDirectory - Error getting plugin://plugin.video.alfa/?ewogICAgImFjdGlvbiI6ICJwZWxpY3VsYXMiLCAKICAgICJjYXRlZ29yeSI6ICJacGVsaWN1bGFzIiwgCiAgICAiY2hhbm5lbCI6ICJ6cGVsaWN1bGFzIiwgCiAgICAiZmFuYXJ0IjogImh0dHA6Ly93d3cuenBlbGljdWxhcy5jb20vdGVtcGxhdGVzL215dG9wVjIvaW1hZ2VzL2JhY2tncm91bmQucG5nIiwgCiAgICAiaW5mb0xhYmVscyI6IHt9LCAKICAgICJ0aHVtYm5haWwiOiAiIiwgCiAgICAidGl0bGUiOiAiw5psdGltYXMgcGVsaWN1bGFzIiwgCiAgICAidG90YWxJdGVtcyI6IDAsIAogICAgInVybCI6ICJodHRwOi8vd3d3LnpwZWxpY3VsYXMuY29tLyIsIAogICAgInZpZXdtb2RlIjogIm1vdmllIgp9
20:25:27.097 T:1958838272 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.alfa/?ewogICAgImFjdGlvbiI6ICJwZWxpY3VsYXMiLCAKICAgICJjYXRlZ29yeSI6ICJacGVsaWN1bGFzIiwgCiAgICAiY2hhbm5lbCI6ICJ6cGVsaWN1bGFzIiwgCiAgICAiZmFuYXJ0IjogImh0dHA6Ly93d3cuenBlbGljdWxhcy5jb20vdGVtcGxhdGVzL215dG9wVjIvaW1hZ2VzL2JhY2tncm91bmQucG5nIiwgCiAgICAiaW5mb0xhYmVscyI6IHt9LCAKICAgICJ0aHVtYm5haWwiOiAiIiwgCiAgICAidGl0bGUiOiAiw5psdGltYXMgcGVsaWN1bGFzIiwgCiAgICAidG90YWxJdGVtcyI6IDAsIAogICAgInVybCI6ICJodHRwOi8vd3d3LnpwZWxpY3VsYXMuY29tLyIsIAogICAgInZpZXdtb2RlIjogIm1vdmllIgp9) failed
21:47:45.804 T:1805325296 ERROR: OnTvStandby - Unexpected [standby_pc_on_tv_standby] setting value
20:45:30.244 T:1958838272 ERROR: Previous line repeats 1 times.
20:45:30.244 T:1958838272 ERROR: Control 50 in window 10025 has been asked to focus, but it can't
20:46:05.561 T:1592783856 ERROR: ######## ERROR #########
20:46:05.561 T:1592783856 ERROR: [alfa.platformcode.launcher.run] Traceback (most recent call last):
Gracias por vuestra ayuda y un saludo a tod@s.
No conecta a los contenidos
- Agradecido: 8 veces
Por favor, para logs y similares usad Pastebin o similares, en lugar de pegar todo el log en el mensaje del foro.
Veo muchísimos errores de I/O, parece un problema con el sistema de ficheros o bien con la tarjeta.
¿Puede borrar y volver a instalar alguno de esos addons?
¿Tienes otra tarjeta con la que probar?
elmulo
Gracias, por tu respuesta, la proxima vez, no posteare todo el archivo, y lo hare con pasterbin, los addons, los he instalado diversas veces, lo de la tarjeta no, voy a ver si lo pruebo en otra tarjeta y comento haber que tal.
Muchas gracias y un saludo a tod@s
