Hasta aquí lo que he hecho:
Instalación de Vinagre
sudo apt-get install vinagreCódigo: Seleccionar todo
#!/bin/bash
"/opt/retropie/supplementary/runcommand/runcommand.sh" 0 _PORT_ "vinagre" ""Dentro de la carpeta /opt/retropie/configs/ports/vinagre creamos el archivo emulators.cfg con el siguiente contenido:
vinagre = "xinit /opt/retropie/ports/vinagre/vinagre.sh"
default = "vinagre"Código: Seleccionar todo
#!/bin/bash
xset -dpms s off s noblank
matchbox-window-manager -use_titlebar no &
/usr/bin/vinagreParameters: Executing: SDL_VIDEO_EGL_DRIVER=/opt/vc/lib/libEGL.so SDL_VIDEO_GL_DRIVER=/opt/vc/lib/libGLESv2.so xinit /opt/retropie/ports/vinagre/vinagre.sh -- vt1 -keeptty X.Org X Server 1.18.4 Release Date: 2016-07-19 X Protocol Version 11, Revision 0 Build Operating System: Linux 4.4.26-v7+ armv7l Raspbian Current Operating System: Linux retropie 4.9.35-v7+ #1014 SMP Fri Jun 30 14:47:43 BST 2017 armv7l Kernel command line: bcm2708_fb.fbwidth=1824 bcm2708_fb.fbheight=984 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p10 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet loglevel=3 consoleblank=0 plymouth.enable=0 quiet Build Date: 11 November 2016 11:59:59AM xorg-server 2:1.18.4-2+rpi1 (https://www.debian.org/support) Current version of pixman: 0.33.3 Before reporting problems, check http://wiki.x.org to make sure that you have the latest version. Markers: (--) probed, (**) from config file, (==) default setting, (++) from command line, (!!) notice, (II) informational, (WW) warning, (EE) error, (NI) not implemented, (??) unknown. (==) Log file: "/home/pi/.local/share/xorg/Xorg.0.log", Time: Sat Dec 9 11:56:57 2017 (==) Using system config directory "/usr/share/X11/xorg.conf.d" modprobe: FATAL: Module g2d_23 not found. The XKEYBOARD keymap compiler (xkbcomp) reports: > Warning: Type "ONE_LEVEL" has 1 levels, but <RALT> has 2 symbols > Ignoring extra symbols Errors from xkbcomp are not fatal to the X server ** tp-glib:ERROR:base-client.c:1303:tp_base_client_constructed: assertion failed: (self->priv->dbus != NULL) /opt/retropie/ports/vinagre/vinagre.sh: línea 4: 942 Abortado /usr/bin/vinagre xinit: connection to X server lost waiting for X server to shut down wm_set_cursor_visibility: visible using XCreateFontCursor (II) Server terminated successfully (0). Closing log file.
