imagen: atractModeKodiPlusPremium128gb
Pues estoy intentando configurar para subir y bajar volumen con select+joystick
select+joystick arriba= subir volumen
select+joystick abajo=bajar volumen
select+joystick izda= silenciar
el texto original que encontré ponía esto:
He encontrado ese apartado de codigo correspondiente abriendo retroarch.cfg y editandolo para aplicar la informacion encontrada y a quedado tal que asi:If I hold Select+Up the volume increases, Select+Down it decreases, and Select+Left will mute. I have my physical speakers set at around 75% inside my arcade and I never actually change that. The hotkey combinations are defined in retroarch.cfg and mine looks something like this:
input_enable_hotkey_btn = 7 #Select
input_volume_up_axis = -1 #Up on Joystick
input_volume_down_axis = +1 #Down on Joystick
input_audio_mute_axis = +0 #Left on Joystick
You could utilize the extra hole to install a new button and have this be a dedicate hotkey, instead of re-purposing the Select button like I do. I don't have a good link for you, but if you google Retropie hotkeys you'll probably find a lot of other very useful commands that can be triggered in addition to volume control.
retroarch.cfg
input_audio_mute = "f9"
input_audio_mute_btn = "nul"
input_select_btn = "7"
input_audio_mute_axis = "-0" #silenciar volumen joystick izquierda
input_osk_toggle = "f12"
input_osk_toggle_btn = "nul"
input_osk_toggle_axis = "nul"
input_netplay_flip_players = "i"
input_netplay_flip_players_btn = "nul"
input_netplay_flip_players_axis = "nul"
input_slowmotion = "e"
input_slowmotion_btn = "nul"
input_slowmotion_axis = "nul"
input_enable_hotkey_btn = "7" #select
input_enable_hotkey_axis = "nul"
input_volume_up = "add"
input_volume_up_btn = "nul"
input_volume_up_axis = "-1" #subir volumen joystick arriba
input_volume_down = "subtract"
input_volume_down_btn = "nul"
input_volume_down_axis = "+1" #bajar volumen joystick abajo
He de decir que lo he configurado segun mi configuracion de botones, aqui teneis mi configuracion de botones del panel de mandos de mi bartop arcade, para que veais, que los botones los he puesto bien en retroarch.cfg
THT1ParcadecontrollerTHT1Parcadecontroller.cfg
input_device = "THT 1P arcade controller THT 1P arcade controller"
input_driver = "udev"
input_l_btn = "5"
input_load_state_btn = "5"
input_start_btn = "6"
input_exit_emulator_btn = "6"
input_up_axis = "-1"
input_a_btn = "1"
input_b_btn = "0"
input_reset_btn = "0"
input_down_axis = "+1"
input_r_btn = "4"
input_save_state_btn = "4"
input_right_axis = "+0"
input_state_slot_increase_axis = "+0"
input_x_btn = "3"
input_menu_toggle_btn = "3"
input_y_btn = "2"
input_left_axis = "-0"
input_state_slot_decrease_axis = "-0"
