Mi nuevo Juguetito , HP ProLiant MicroServer G8 + 25 TB
fizban escribió:Pues la verdad, inicialmente me he pillado la Raspberry por el Kodi (aunque con lo poco que ya he visto, la utilizaré para más cosas). La idea es montar maquinas virtuales, entre ellas una FreeNAS con Transmission para los Torrents, (pero el Celeron que tiene se pone al 100% y no da mas de si el pobrecito) y reproducir las series/pelis con el Kodi.
El micro lo he comprado por eBay y ya utilizado. (nuevos tienen unos precios prohibitivos)
Bien hecho ,ya irás descubriendo todo lo que ofrece el mundo de Raspberry Pi , que no es poco :silbido
Yo también he estado indagando un poco pero no me acaba de convencer el tema de segunda mano, aparte que los vendedores son todos de China 8-) ya me contarás que tal te ha llegado!
fizban
y logicamente cuidado al ponerla en modo RAID o ACHI porque se pierden todos los datos. Esto es lo que preguntaba un forero de la controladora.
I'm a brand new owner of a Gen 8 server (some good deals out there!) and have been reading through these great forums for the last few days to get up to speed and decide the best install for me. I've attempted to summarise my learning about the B120i controller and pros and cons. Hopefully any errors can be corrected by more experience members to form a useful first post that gives something back to the forum.
The B120i can operate in 2 modes, RAID and AHCI compatible.
When operating in RAID mode the drive temperatures can be read and the system fan is adjusted appropriately. This results in a system fan speed of around 6% at idle which is quiet.
When operating in AHCI mode the drive temps are not read and the system fan speed is set at a higher minimum, around 10%, this is noisier. Some reports of higher fan speed of 15%.
There is no hardware acceleration as all the clever stuff is done by the driver which uses the main CPU.
The B120i controller has no cache and needs to use system memory if a cache required.
There are no performance differences when operating in RAID or AHCI mode.
When operating in AHCI mode the drives can spin down during idle but in RAID mode they cannot.
If an SSD is used in place of the DVD drive (ODD port) then it can be booted when in RAID mode but not in AHCI mode (work around using SD/USB for windows presumably something could also be done using grub for Linux but not seen any example)
Drives formatted under RAID mode can be moved to other servers running an HP RAID controller. Those formatted AHCI can be moved to other servers also using a standard AHCI controller. Moving drives between either will require a full format.
MALOW
¿No te has planteado instalar mejor DSM 6 de Synology (XPEnology)?
fizban
Llevo utiliazando freenas desde hace unos cuantos años, y ya poco queda de aquel concepto de NAS a secas, ademas prefiero el filesystem zfs
drayton
bufff yo cambie hace 1 año aproximadamente de un synology a un proliant g8 y no puedo estar mas contento, le meti 4 discos duros de 4 teras en raid 5 y un ssd Toshiba, y perfecto, le monte openmediavault, y genial, superestable.
galactico
Buenas noches
yo tengo el mismo Juguete
le he montado:
-4 discos WD red nas edition de 3tb en las 4 bahias frontales
-1 ssd samsung pro en la bahia del cd
-Actualizacion Microprocesador (i3 3220 3.3 ghz)
-16 gb ram
-gt 610 1 gb (bajo consumo)
una verdadera bestia!! buena compra :relax1
4dr1
Como irá este cacharrin como servidor de plex?
4dr1 escribió:Como irá este cacharrin como servidor de plex?
Va muy bien , lo que con dos transcodificaciones simultaneas se queda un poco corta la CPU, siempre puedes cambiarla! Actualmente tengo 100 personas en Plex y sin problemas( alguno siempre puntual ) [emoji4]
4dr1
100 personas tirando al mismo tiempo? Como haces para que no coincida transcodificando mas de 2? jaja
A la vez no jajaja como mucho se conectan 15-20 simultáneos . En las opciones de Plex puedes limitar el número de trascodificaciones [emoji12]
4dr1
Kike escribió:
4dr1 escribió:
Kike escribió: Va muy bien , lo que con dos transcodificaciones simultaneas se queda un poco corta la CPU, siempre puedes cambiarla! Actualmente tengo 100 personas en Plex y sin problemas( alguno siempre puntual ) [emoji4]
Cuanto tienes de subida?
Estoy planteandome muy mucho pillar uno de estos. Con AppleTV4 va en reproduccion directa verdad?
janomontano
Que bárbaro!!!
Enviado desde mi Redmi 3 mediante Tapatalk
vulkano
una maravillaaaaa
koseialex
Que pasote yo de momento me conformo con un synology
Dawn
Kike escribió:Hola a todos! Adjunto unas fotos de la nueva máquina que me acaba de llegar :avergonzado :victoria
Un saludo!!
Kike, me he calentado al ver tu nuevo juguete y estoy planteandome renovar el mio. ¿Me puedes asesorar? He abierto un hilo al respecto: viewtopic.php?f=11&t=2916&p=24539#p24539
listaseu
Que bestiaaaa!! moooola !! muuuchooo
Dawn
He estado jugando con ProxMox y con VMware. Me gustan ambos. Porque decantarse por uno u otro?
Entiendo que poneis los discos en AHCI i despues montais el Raid por soft desde el S.O. no?
Nayin
Que buena pinta tiene.
whisler
Perdón por el tremendo reflote.
Hay que hacer algo especial para que el HP GEN 8 detecte discos de 8TB ??
No se supone que soporta hasta discos de 4TB por bahia ??
muchas gracias
Kike escribió: 05 Sep 2016, 16:13 Hola a todos! Adjunto unas fotos de la nueva máquina que me acaba de llegar :avergonzado :victoria
Ya os ire contando a medida de me vayan llegando las nuevas piezas, asi como lo que tengo pensado montar, S.O que utilizaré , impresiones en el rendimiento, ruido etc :)
ACTUALIZADO 17 / 09 / 16
Despues de estar unos dias dandole caña, he llegado a la conclusión que es una de las mejores compras que se pueden hacer si quieres montarte tu propio proyecto, actualmente tengo instados estos 2 discos duros en su interior:
1 Disco Duro 8TB WD RED (sata 3)
Su rendiento es asombroso, ya que tengo en su interior un SSD Samsung EVO 850 utilizando el sistema operativo
Lo he complementado con un módulo extra de RAM: Kingston DDR3 8GB ( En total 12GB ).
A nivel sonoro, no se oye practicamente nada el ventilador , lo tengo en un despacho muy pequeño y no molesta para nada. El único momento que puede llegar a hacer ruido es al arrancar, ya que hace un chequeo del sistema y pone los ventiladores al máximo.
A nivel de calidad de compontentes, tanto en el interior como en el exterior descata mucho por su robustez
El software de HP integrado para manejar discos es muy intuitivo y facil de utilizar, para hacer pequeños retoques en la BIOS no tuve ningun problema.
La unica pega que le veo es que tarda unos 3 minutos en arrancar, pero nada importante :victoria .
Conclusión: Por muy poco dinero ( unos 185€ ) puedes montar un buen proyecto con este microservidor para una pequeña / mediana empresa o particular (por ejemplo un NAS)y darle un uso intensivo , que te aguantará todo lo que le pidas :D
Un saludo!!
whisler escribió: 08 Abr 2019, 18:29 Hola,
muchas gracias
Hola buenas tardes, actualmente tengo 3 HDD de 8TB ( 2 WD RED & 1 SEAGATE IRONWOLF PRO ) aparte de varios externos por USB.
No hay que tocar ni configurar absolutamente nada, los detecta sin problemas,lo estoy utilizando a través de Proxmox y la verdad es que va de maravilla.
Un saludo!
