[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 5.10.92-v7+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1514 SMP Mon Jan 17 17:36:39 GMT 2022
[ 0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 3 Model B Plus Rev 1.3
[ 0.000000] random: fast init done
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] Reserved memory: created CMA memory pool at 0x1ec00000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000000000-0x000000003b3fffff]
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x000000003b3fffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000003b3fffff]
[ 0.000000] On node 0 totalpages: 242688
[ 0.000000] DMA zone: 2133 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 242688 pages, LIFO batch:63
[ 0.000000] percpu: Embedded 20 pages/cpu s50828 r8192 d22900 u81920
[ 0.000000] pcpu-alloc: s50828 r8192 d22900 u81920 alloc=20*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 240555
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=c4599bae-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 681804K/970752K available (10240K kernel code, 1312K rwdata, 2952K rodata, 1024K init, 862K bss, 26804K reserved, 262144K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 32087 entries in 95 pages
[ 0.000000] ftrace: allocated 95 pages with 6 groups
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] random: get_random_bytes called from start_kernel+0x3ac/0x580 with crng_init=1
[ 0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000021] Switching to timer-based delay loop, resolution 52ns
[ 0.000322] Console: colour dummy device 80x30
[ 0.000395] printk: console [tty1] enabled
[ 0.000447] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ 0.000475] pid_max: default: 32768 minimum: 301
[ 0.000673] LSM: Security Framework initializing
[ 0.000913] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.000938] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.002397] cgroup: Disabling memory control group subsystem
[ 0.002664] CPU: Testing write buffer coherency: ok
[ 0.003162] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.004400] Setting up static identity map for 0x100000 - 0x10003c
[ 0.004587] rcu: Hierarchical SRCU implementation.
[ 0.005515] smp: Bringing up secondary CPUs ...
[ 0.006673] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.007957] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.009169] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.009325] smp: Brought up 1 node, 4 CPUs
[ 0.009348] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.009360] CPU: All CPU(s) started in HYP mode.
[ 0.009371] CPU: Virtualization extensions available.
[ 0.010465] devtmpfs: initialized
[ 0.028781] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[ 0.029030] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.029060] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.039686] pinctrl core: initialized pinctrl subsystem
[ 0.040923] NET: Registered protocol family 16
[ 0.045213] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.050990] audit: initializing netlink subsys (disabled)
[ 0.051862] thermal_sys: Registered thermal governor 'step_wise'
[ 0.052835] audit: type=2000 audit(0.050:1): state=initialized audit_enabled=0 res=1
[ 0.053022] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.053036] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.053330] Serial: AMBA PL011 UART driver
[ 0.077184] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.090150] raspberrypi-firmware soc:firmware: Attached to firmware from 2022-01-20T13:58:22, variant start
[ 0.100160] raspberrypi-firmware soc:firmware: Firmware hash is bd88f66f8952d34e4e0613a85c7a6d3da49e13e2
[ 0.144694] Kprobes globally optimized
[ 0.149858] bcm2835-dma 3f007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.152245] SCSI subsystem initialized
[ 0.152518] usbcore: registered new interface driver usbfs
[ 0.152596] usbcore: registered new interface driver hub
[ 0.152671] usbcore: registered new device driver usb
[ 0.154761] clocksource: Switched to clocksource arch_sys_counter
[ 1.876280] VFS: Disk quotas dquot_6.6.0
[ 1.876397] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.876604] FS-Cache: Loaded
[ 1.876849] CacheFiles: Loaded
[ 1.877699] simple-framebuffer 3eaa9000.framebuffer: framebuffer at 0x3eaa9000, 0x151800 bytes, mapped to 0x(ptrval)
[ 1.877719] simple-framebuffer 3eaa9000.framebuffer: format=a8r8g8b8, mode=720x480x32, linelength=2880
[ 1.878225] Console: switching to colour frame buffer device 90x30
[ 1.883915] simple-framebuffer 3eaa9000.framebuffer: fb0: simplefb registered!
[ 1.893757] NET: Registered protocol family 2
[ 1.894039] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 1.895994] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 1.896058] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 1.896189] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 1.896381] TCP: Hash tables configured (established 8192 bind 8192)
[ 1.896570] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 1.896627] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 1.896900] NET: Registered protocol family 1
[ 1.897678] RPC: Registered named UNIX socket transport module.
[ 1.897692] RPC: Registered udp transport module.
[ 1.897704] RPC: Registered tcp transport module.
[ 1.897717] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.899584] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[ 1.903464] Initialise system trusted keyrings
[ 1.903738] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[ 1.913337] zbud: loaded
[ 1.915502] FS-Cache: Netfs 'nfs' registered for caching
[ 1.916395] NFS: Registering the id_resolver key type
[ 1.916455] Key type id_resolver registered
[ 1.916468] Key type id_legacy registered
[ 1.916641] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.916655] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 1.917831] Key type asymmetric registered
[ 1.917845] Asymmetric key parser 'x509' registered
[ 1.917901] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 1.917916] io scheduler mq-deadline registered
[ 1.917930] io scheduler kyber registered
[ 1.928203] bcm2835-rng 3f104000.rng: hwrng registered
[ 1.928782] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 1.930000] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 1.942193] brd: module loaded
[ 1.954248] loop: module loaded
[ 1.956259] Loading iSCSI transport class v2.0-870.
[ 1.957843] libphy: Fixed MDIO Bus: probed
[ 1.958142] usbcore: registered new interface driver lan78xx
[ 1.958210] usbcore: registered new interface driver smsc95xx
[ 1.958234] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 2.687470] Core Release: 2.80a
[ 2.687487] Setting default values for core params
[ 2.687518] Finished setting default values for core params
[ 2.887891] Using Buffer DMA mode
[ 2.887905] Periodic Transfer Interrupt Enhancement - disabled
[ 2.887917] Multiprocessor Interrupt Enhancement - disabled
[ 2.887931] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 2.887959] Dedicated Tx FIFOs mode
[ 2.888958] WARN::dwc_otg_hcd_init:1074: FIQ DMA bounce buffers: virt = 9ed04000 dma = 0xded04000 len=9024
[ 2.888991] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[ 2.889005] dwc_otg: Microframe scheduler enabled
[ 2.889082] WARN::hcd_init_fiq:457: FIQ on core 1
[ 2.889099] WARN::hcd_init_fiq:458: FIQ ASM at 807cc05c length 36
[ 2.889116] WARN::hcd_init_fiq:497: MPHI regs_base at bb810000
[ 2.889138] dwc_otg 3f980000.usb: DWC OTG Controller
[ 2.889180] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 2.889243] dwc_otg 3f980000.usb: irq 89, io mem 0x00000000
[ 2.889297] Init: Port Power? op_state=1
[ 2.889309] Init: Power Port (0)
[ 2.889669] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 2.889687] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.889703] usb usb1: Product: DWC OTG Controller
[ 2.889718] usb usb1: Manufacturer: Linux 5.10.92-v7+ dwc_otg_hcd
[ 2.889733] usb usb1: SerialNumber: 3f980000.usb
[ 2.890526] hub 1-0:1.0: USB hub found
[ 2.890593] hub 1-0:1.0: 1 port detected
[ 2.891909] dwc_otg: FIQ enabled
[ 2.891922] dwc_otg: NAK holdoff enabled
[ 2.891934] dwc_otg: FIQ split-transaction FSM enabled
[ 2.891952] Module dwc_common_port init
[ 2.892290] usbcore: registered new interface driver usb-storage
[ 2.892510] mousedev: PS/2 mouse device common for all mice
[ 2.893853] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 2.896897] sdhci: Secure Digital Host Controller Interface driver
[ 2.896912] sdhci: Copyright(c) Pierre Ossman
[ 2.897578] mmc-bcm2835 3f300000.mmcnr: could not get clk, deferring probe
[ 2.898308] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
[ 2.898577] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.900692] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.901115] hid: raw HID events driver (C) Jiri Kosina
[ 2.901275] usbcore: registered new interface driver usbhid
[ 2.901288] usbhid: USB HID core driver
[ 2.906751] Initializing XFRM netlink socket
[ 2.906797] NET: Registered protocol family 17
[ 2.906963] Key type dns_resolver registered
[ 2.907691] Registering SWP/SWPB emulation handler
[ 2.907878] registered taskstats version 1
[ 2.907913] Loading compiled-in X.509 certificates
[ 2.908759] Key type ._fscrypt registered
[ 2.908773] Key type .fscrypt registered
[ 2.908786] Key type fscrypt-provisioning registered
[ 2.920644] uart-pl011 3f201000.serial: cts_event_workaround enabled
[ 2.920749] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 114, base_baud = 0) is a PL011 rev2
[ 2.923181] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 2.924960] mmc-bcm2835 3f300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 2.924977] mmc-bcm2835 3f300000.mmcnr: DMA channel allocated
[ 2.952999] sdhost: log_buf @ (ptrval) (ded03000)
[ 2.990226] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 2.991915] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.993587] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.996581] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 3.004055] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 3.027542] of_cfs_init
[ 3.027700] of_cfs_init: OK
[ 3.028315] Indeed it is in host mode hprt0 = 00021501
[ 3.065690] Waiting for root device PARTUUID=c4599bae-02...
[ 3.144519] mmc1: new high speed SDIO card at address 0001
[ 3.154852] mmc0: host does not support reading read-only switch, assuming write-enable
[ 3.159475] mmc0: new high speed SDXC card at address aaaa
[ 3.160437] mmcblk0: mmc0:aaaa SB64G 59.5 GiB
[ 3.163723] mmcblk0: p1 p2
[ 3.202836] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 3.202945] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 3.203863] devtmpfs: mounted
[ 3.212055] Freeing unused kernel memory: 1024K
[ 3.234843] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 3.235052] Indeed it is in host mode hprt0 = 00001101
[ 3.295598] Run /sbin/init as init process
[ 3.295610] with arguments:
[ 3.295622] /sbin/init
[ 3.295634] splash
[ 3.295644] with environment:
[ 3.295656] HOME=/
[ 3.295667] TERM=linux
[ 3.485185] usb 1-1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
[ 3.485210] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.486097] hub 1-1:1.0: USB hub found
[ 3.486202] hub 1-1:1.0: 4 ports detected
[ 3.796275] systemd[1]: System time before build time, advancing clock.
[ 3.804832] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 3.934545] NET: Registered protocol family 10
[ 3.936091] Segment Routing with IPv6
[ 3.945220] usb 1-1.1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
[ 3.945245] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.946187] hub 1-1.1:1.0: USB hub found
[ 3.946299] hub 1-1.1:1.0: 3 ports detected
[ 4.041544] systemd[1]: systemd 247.3-6+rpi1 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
[ 4.042732] systemd[1]: Detected architecture arm.
[ 4.044960] systemd[1]: Set hostname to <raspberrypi>.
[ 4.299223] dwc_otg_handle_wakeup_detected_intr lxstate = 2
[ 4.924824] usb 1-1.1.1: new high-speed USB device number 4 using dwc_otg
[ 5.002153] systemd[1]: /lib/systemd/system/plymouth-start.service:16: Unit configured to use KillMode=none. This is unsafe, as it disables systemd's process lifecycle management for the service. Please update your service to use a safer KillMode=, such as 'mixed' or 'control-group'. Support for KillMode=none is deprecated and will eventually be removed.
[ 5.075381] usb 1-1.1.1: New USB device found, idVendor=0424, idProduct=7800, bcdDevice= 3.00
[ 5.075407] usb 1-1.1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 5.294393] systemd[1]: Queued start job for default target Graphical Interface.
[ 5.296870] random: systemd: uninitialized urandom read (16 bytes read)
[ 5.300003] systemd[1]: Created slice system-getty.slice.
[ 5.300474] random: systemd: uninitialized urandom read (16 bytes read)
[ 5.301821] systemd[1]: Created slice system-modprobe.slice.
[ 5.301991] random: systemd: uninitialized urandom read (16 bytes read)
[ 5.303200] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 5.304200] systemd[1]: Created slice User and Session Slice.
[ 5.304930] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 5.306356] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 5.307585] systemd[1]: Reached target Slices.
[ 5.307904] systemd[1]: Reached target Swap.
[ 5.309365] systemd[1]: Listening on Syslog Socket.
[ 5.310228] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 5.310746] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 5.312224] systemd[1]: Listening on Journal Audit Socket.
[ 5.313066] systemd[1]: Listening on Journal Socket (/dev/log).
[ 5.314181] systemd[1]: Listening on Journal Socket.
[ 5.326639] systemd[1]: Listening on udev Control Socket.
[ 5.327729] systemd[1]: Listening on udev Kernel Socket.
[ 5.329091] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[ 5.334007] systemd[1]: Mounting POSIX Message Queue File System...
[ 5.339822] systemd[1]: Mounting RPC Pipe File System...
[ 5.346316] systemd[1]: Mounting Kernel Debug File System...
[ 5.351032] lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitialized): No External EEPROM. Setting MAC Speed
[ 5.353209] libphy: lan78xx-mdiobus: probed
[ 5.353216] systemd[1]: Mounting Kernel Trace File System...
[ 5.353846] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
[ 5.366894] systemd[1]: Starting Restore / save the current clock...
[ 5.377020] systemd[1]: Starting Set the console keyboard layout...
[ 5.380918] lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitialized): int urb period 64
[ 5.384166] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 5.392235] systemd[1]: Starting Load Kernel Module configfs...
[ 5.399546] systemd[1]: Starting Load Kernel Module drm...
[ 5.407322] systemd[1]: Starting Load Kernel Module fuse...
[ 5.429726] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 5.436654] systemd[1]: Starting File System Check on Root Device...
[ 5.455441] systemd[1]: Starting Journal Service...
[ 5.472075] systemd[1]: Starting Load Kernel Modules...
[ 5.479756] systemd[1]: Starting Coldplug All udev Devices...
[ 5.493538] systemd[1]: Mounted POSIX Message Queue File System.
[ 5.495209] systemd[1]: Mounted RPC Pipe File System.
[ 5.498235] systemd[1]: Mounted Kernel Debug File System.
[ 5.501008] systemd[1]: Mounted Kernel Trace File System.
[ 5.507745] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 5.511217] systemd[1]: modprobe@configfs.service: Succeeded.
[ 5.512552] systemd[1]: Finished Load Kernel Module configfs.
[ 5.519137] systemd[1]: Mounting Kernel Configuration File System...
[ 5.539427] fuse: init (API version 7.32)
[ 5.581699] systemd[1]: modprobe@drm.service: Succeeded.
[ 5.583259] systemd[1]: Finished Load Kernel Module drm.
[ 5.586391] systemd[1]: Finished Restore / save the current clock.
[ 5.591031] systemd[1]: modprobe@fuse.service: Succeeded.
[ 5.592679] systemd[1]: Finished Load Kernel Module fuse.
[ 5.593972] systemd[1]: Mounted Kernel Configuration File System.
[ 5.605556] systemd[1]: Mounting FUSE Control File System...
[ 5.611635] systemd[1]: Started File System Check Daemon to report status.
[ 5.640034] i2c /dev entries driver
[ 5.664082] systemd[1]: Finished Load Kernel Modules.
[ 5.665472] systemd[1]: Mounted FUSE Control File System.
[ 5.671548] systemd[1]: Starting Apply Kernel Variables...
[ 5.759400] systemd[1]: Finished Apply Kernel Variables.
[ 5.837333] systemd[1]: Started Journal Service.
[ 6.178651] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 6.254202] systemd-journald[124]: Received client request to flush runtime journal.
[ 6.272462] systemd-journald[124]: File /var/log/journal/316ae05cfd87495fa67a75f8ec533655/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 7.715889] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.718473] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 7.718504] [vc_sm_connected_init]: start
[ 7.724718] [vc_sm_connected_init]: installed successfully
[ 7.731160] mc: Linux media interface: v0.10
[ 7.794626] videodev: Linux video capture interface: v2.00
[ 7.813780] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.830364] bcm2835_audio bcm2835_audio: card created with 8 channels
[ 7.838723] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.884937] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.886144] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.893391] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.906798] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 7.906856] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 7.919019] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 7.919075] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 7.945642] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.949744] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.951388] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 7.951460] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 7.964981] random: crng init done
[ 7.965043] random: 7 urandom warning(s) missed due to ratelimiting
[ 7.995385] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
[ 7.995456] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
[ 8.101083] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 8.108892] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 8.119773] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 8.130202] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 8.130242] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 8.130267] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 8.130288] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 8.130309] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 8.138298] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
[ 8.138800] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
[ 8.139571] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
[ 8.142317] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
[ 8.142359] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 8.142385] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 8.142406] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 8.142427] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 8.143138] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 8.258494] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 8.457846] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 8.487324] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
[ 8.575140] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 8.629600] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 8.630672] usbcore: registered new interface driver brcmfmac
[ 8.769427] checking generic (3eaa9000 151800) vs hw (0 ffffffff)
[ 8.769452] fb0: switching to vc4drmfb from simple
[ 8.775734] Console: switching to colour dummy device 80x30
[ 8.797254] vc4-drm soc:gpu: bound 3f400000.hvs (ops vc4_hvs_ops [vc4])
[ 8.807806] Registered IR keymap rc-cec
[ 8.808096] rc rc0: vc4 as /devices/platform/soc/3f902000.hdmi/rc/rc0
[ 8.808371] input: vc4 as /devices/platform/soc/3f902000.hdmi/rc/rc0/input0
[ 8.970294] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 8.970514] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 9.027580] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Nov 1 2021 00:37:25 version 7.45.241 (1a2f2fa CY) FWID 01-703fd60
[ 9.787041] vc4-drm soc:gpu: bound 3f400000.hvs (ops vc4_hvs_ops [vc4])
[ 9.792123] Registered IR keymap rc-cec
[ 9.792411] rc rc0: vc4 as /devices/platform/soc/3f902000.hdmi/rc/rc0
[ 9.792683] input: vc4 as /devices/platform/soc/3f902000.hdmi/rc/rc0/input1
[ 9.810664] vc4-drm soc:gpu: bound 3f902000.hdmi (ops vc4_hdmi_ops [vc4])
[ 9.811154] vc4-drm soc:gpu: bound 3f004000.txp (ops vc4_txp_ops [vc4])
[ 9.811487] vc4-drm soc:gpu: bound 3f206000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 9.811824] vc4-drm soc:gpu: bound 3f207000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 9.812149] vc4-drm soc:gpu: bound 3f807000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 9.812413] vc4-drm soc:gpu: bound 3fc00000.v3d (ops vc4_v3d_ops [vc4])
[ 9.836661] [drm] Initialized vc4 0.0.0 20140616 for soc:gpu on minor 0
[ 9.836963] vc4-drm soc:gpu: [drm] Cannot find any crtc or sizes
[ 10.724370] 8021q: 802.1Q VLAN Support v1.8
[ 10.825952] uart-pl011 3f201000.serial: no DMA platform data
[ 10.974917] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 11.384138] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 11.719150] 8021q: adding VLAN 0 to HW filter on device eth0
[ 16.475982] hdmi-audio-codec hdmi-audio-codec.1.auto: ASoC: error at snd_soc_dai_startup on i2s-hifi: -19
[ 16.477904] hdmi-audio-codec hdmi-audio-codec.1.auto: ASoC: error at snd_soc_dai_startup on i2s-hifi: -19
[ 16.479591] hdmi-audio-codec hdmi-audio-codec.1.auto: ASoC: error at snd_soc_dai_startup on i2s-hifi: -19
[ 16.503464] hdmi-audio-codec hdmi-audio-codec.1.auto: ASoC: error at snd_soc_dai_startup on i2s-hifi: -19
[ 16.504510] hdmi-audio-codec hdmi-audio-codec.1.auto: ASoC: error at snd_soc_dai_startup on i2s-hifi: -19
[ 16.507199] hdmi-audio-codec hdmi-audio-codec.1.auto: ASoC: error at snd_soc_dai_startup on i2s-hifi: -19
[ 16.761943] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 17.601785] Bluetooth: Core ver 2.22
[ 17.601874] NET: Registered protocol family 31
[ 17.601881] Bluetooth: HCI device and connection manager initialized
[ 17.601901] Bluetooth: HCI socket layer initialized
[ 17.601912] Bluetooth: L2CAP socket layer initialized
[ 17.601929] Bluetooth: SCO socket layer initialized
[ 17.616878] Bluetooth: HCI UART driver ver 2.3
[ 17.616896] Bluetooth: HCI UART protocol H4 registered
[ 17.616982] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 17.617169] Bluetooth: HCI UART protocol Broadcom registered
[ 18.082238] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.wlan0.retrans_time - use net.ipv6.neigh.wlan0.retrans_time_ms instead
[ 18.363088] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 18.363102] Bluetooth: BNEP filters: protocol multicast
[ 18.363120] Bluetooth: BNEP socket layer initialized
[ 18.421849] NET: Registered protocol family 38
[ 18.500292] cryptd: max_cpu_qlen set to 1000
[ 18.696407] Bluetooth: RFCOMM TTY layer initialized
[ 18.696434] Bluetooth: RFCOMM socket layer initialized
[ 18.696462] Bluetooth: RFCOMM ver 1.11
[ 20.315370] vc4-drm soc:gpu: [drm] Cannot find any crtc or sizes
[ 33.115894] cam1-reg: disabling
[ 33.115920] cam-dummy-reg: disabling
[ 94.226546] usb 1-1-port2: over-current change #1
[ 94.425537] usb 1-1.1-port2: over-current change #1
[ 94.458986] usb 1-1-port2: over-current condition
[ 94.459168] usb 1-1-port3: over-current change #1
[ 94.658937] usb 1-1.1-port2: over-current condition
[ 94.659125] usb 1-1.1-port3: over-current change #1
[ 94.698954] usb 1-1-port3: over-current condition
[ 94.699145] usb 1-1-port4: over-current change #1
[ 94.898966] usb 1-1.1-port3: over-current condition
[ 94.938942] usb 1-1-port4: over-current condition
Igual le conecto un pendrive y me sigue mostrando los mismos mensajes.
Así que debo suponer que se debieron quemar los puertos usb porque antes ya había checado las conexiones del pcb con un multímetro y marcaba corto.
