21 Dic 2022, 23:00
Ejecute el comando indicado pero me da error
Te adjunto el error :
Configuring network interface. Please wait ...
{'response': None, 'error': {'code': 0, 'message': 'Failed to execute command \'export PATH=/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin:/usr/local/sbin; export LANG=C.UTF-8; omv-salt deploy run --no-color systemd-networkd 2>&1\' with exit code \'1\': raspberrypi:\n----------\n ID: remove_systemd_networkd_config_files\n Function: module.run\n Result: True\n Comment: file.find: []\n Started: 21:41:18.151285\n Duration: 4.943 ms\n Changes:\n ----------\n file.find:\n----------\n ID: remove_empty_systemd_networkd_config_files\n Function: module.run\n Result: True\n Comment: file.find: []\n Started: 21:41:18.156630\n Duration: 7.334 ms\n Changes:\n ----------\n file.find:\n----------\n ID: remove_netplan_config_files\n Function: module.run\n Result: True\n Comment: file.find: [\'/etc/netplan/10-openmediavault-default.yaml\', \'/etc/netplan/20-openmediavault-eth0.yaml\']\n Started: 21:41:18.164329\n Duration: 4.779 ms\n Changes:\n ----------\n file.find:\n - /etc/netplan/10-openmediavault-default.yaml\n - /etc/netplan/20-openmediavault-eth0.yaml\n----------\n ID: configure_etc_network_interfaces\n Function: file.managed\n Name: /etc/network/interfaces\n Result: True\n Comment: File /etc/network/interfaces is in the correct state\n Started: 21:41:18.174698\n Duration: 96.389 ms\n Changes:\n----------\n ID: symlink_systemd_resolvconf\n Function: file.symlink\n Name: /etc/resolv.conf\n Result: True\n Comment: Symlink /etc/resolv.conf is present and owned by root:root\n Started: 21:41:18.271475\n Duration: 6508.642 ms\n Changes:\n----------\n ID: configure_netplan_default\n Function: file.managed\n Name: /etc/netplan/10-openmediavault-default.yaml\n Result: True\n Comment: File /etc/netplan/10-openmediavault-default.yaml updated\n Started: 21:41:24.780832\n Duration: 33.971 ms\n Changes:\n ----------\n diff:\n New file\n mode:\n 0644\n----------\n ID: configure_netplan_wifi_wlan0\n Function: file.managed\n Name: /etc/netplan/30-openmediavault-wlan0.yaml\n Result: True\n Comment: File /etc/netplan/30-openmediavault-wlan0.yaml updated\n Started: 21:41:24.815179\n Duration: 84.841 ms\n Changes:\n ----------\n diff:\n New file\n mode:\n 0644\n----------\n ID: apply_netplan_config\n Function: cmd.run\n Name: netplan apply\n Result: False\n Comment: Command "netplan apply" run\n Started: 21:41:24.900434\n Duration: 369.538 ms\n Changes:\n ----------\n pid:\n 10270\n retcode:\n 1\n stderr:\n Traceback (most recent call last):\n File "/sbin/netplan", line 23, in <module>\n netplan.main()\n File "/usr/share/netplan/netplan/cli/core.py", line 50, in main\n self.run_command()\n File "/usr/share/netplan/netplan/cli/utils.py", line 130, in run_command\n self.func()\n File "/usr/share/netplan/netplan/cli/commands/apply.py", line 43, in run\n self.run_command()\n File "/usr/share/netplan/netplan/cli/utils.py", line 130, in run_command\n self.func()\n File "/usr/share/netplan/netplan/cli/commands/apply.py", line 93, in command_apply\n stderr=subprocess.DEVNULL)\n File "/usr/lib/python3.7/subprocess.py", line 347, in check_call\n raise CalledProcessError(retcode, cmd)\n subprocess.CalledProcessError: Command \'[\'udevadm\', \'test-builtin\', \'net_setup_link\', \'/sys/class/net/lo\']\' returned non-zero exit status 1.\n stdout:\n\nSummary for raspberrypi\n------------\nSucceeded: 7 (changed=6)\nFailed: 1\n------------\nTotal states run: 8\nTotal run time: 7.110 s', 'trace': 'OMV\\ExecException: Failed to execute command \'export PATH=/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin:/usr/local/sbin; export LANG=C.UTF-8; omv-salt deploy run --no-color systemd-networkd 2>&1\' with exit code \'1\': raspberrypi:\n----------\n ID: remove_systemd_networkd_config_files\n Function: module.run\n Result: True\n Comment: file.find: []\n Started: 21:41:18.151285\n Duration: 4.943 ms\n Changes:\n ----------\n file.find:\n----------\n ID: remove_empty_systemd_networkd_config_files\n Function: module.run\n Result: True\n Comment: file.find: []\n Started: 21:41:18.156630\n Duration: 7.334 ms\n Changes:\n ----------\n file.find:\n----------\n ID: remove_netplan_config_files\n Function: module.run\n Result: True\n Comment: file.find: [\'/etc/netplan/10-openmediavault-default.yaml\', \'/etc/netplan/20-openmediavault-eth0.yaml\']\n Started: 21:41:18.164329\n Duration: 4.779 ms\n Changes:\n ----------\n file.find:\n - /etc/netplan/10-openmediavault-default.yaml\n - /etc/netplan/20-openmediavault-eth0.yaml\n----------\n ID: configure_etc_network_interfaces\n Function: file.managed\n Name: /etc/network/interfaces\n Result: True\n Comment: File /etc/network/interfaces is in the correct state\n Started: 21:41:18.174698\n Duration: 96.389 ms\n Changes:\n----------\n ID: symlink_systemd_resolvconf\n Function: file.symlink\n Name: /etc/resolv.conf\n Result: True\n Comment: Symlink /etc/resolv.conf is present and owned by root:root\n Started: 21:41:18.271475\n Duration: 6508.642 ms\n Changes:\n----------\n ID: configure_netplan_default\n Function: file.managed\n Name: /etc/netplan/10-openmediavault-default.yaml\n Result: True\n Comment: File /etc/netplan/10-openmediavault-default.yaml updated\n Started: 21:41:24.780832\n Duration: 33.971 ms\n Changes:\n ----------\n diff:\n New file\n mode:\n 0644\n----------\n ID: configure_netplan_wifi_wlan0\n Function: file.managed\n Name: /etc/netplan/30-openmediavault-wlan0.yaml\n Result: True\n Comment: File /etc/netplan/30-openmediavault-wlan0.yaml updated\n Started: 21:41:24.815179\n Duration: 84.841 ms\n Changes:\n ----------\n diff:\n New file\n mode:\n 0644\n----------\n ID: apply_netplan_config\n Function: cmd.run\n Name: netplan apply\n Result: False\n Comment: Command "netplan apply" run\n Started: 21:41:24.900434\n Duration: 369.538 ms\n Changes:\n ----------\n pid:\n 10270\n retcode:\n 1\n stderr:\n Traceback (most recent call last):\n File "/sbin/netplan", line 23, in <module>\n netplan.main()\n File "/usr/share/netplan/netplan/cli/core.py", line 50, in main\n self.run_command()\n File "/usr/share/netplan/netplan/cli/utils.py", line 130, in run_command\n self.func()\n File "/usr/share/netplan/netplan/cli/commands/apply.py", line 43, in run\n self.run_command()\n File "/usr/share/netplan/netplan/cli/utils.py", line 130, in run_command\n self.func()\n File "/usr/share/netplan/netplan/cli/commands/apply.py", line 93, in command_apply\n stderr=subprocess.DEVNULL)\n File "/usr/lib/python3.7/subprocess.py", line 347, in check_call\n raise CalledProcessError(retcode, cmd)\n subprocess.CalledProcessError: Command \'[\'udevadm\', \'test-builtin\', \'net_setup_link\', \'/sys/class/net/lo\']\' returned non-zero exit status 1.\n stdout:\n\nSummary for raspberrypi\n------------\nSucceeded: 7 (changed=6)\nFailed: 1\n------------\nTotal states run: 8\nTotal run time: 7.110 s in /usr/share/php/openmediavault/system/process.inc:196\nStack trace:\n#0 /usr/share/php/openmediavault/engine/module/serviceabstract.inc(62): OMV\\System\\Process->execute()\n#1 /usr/share/openmediavault/engined/rpc/config.inc(167): OMV\\Engine\\Module\\ServiceAbstract->deploy()\n#2 [internal function]: Engined\\Rpc\\Config->applyChanges(Array, Array)\n#3 /usr/share/php/openmediavault/rpc/serviceabstract.inc(123): call_user_func_array(Array, Array)\n#4 /usr/share/php/openmediavault/rpc/rpc.inc(86): OMV\\Rpc\\ServiceAbstract->callMethod(\'applyChanges\', Array, Array)\n#5 /usr/sbin/omv-engined(537): OMV\\Rpc\\Rpc::call(\'Config\', \'applyChanges\', Array, Array, 1)\n#6 {main}', 'http_status_code': 500}}
ERROR: Failed to execute command 'export PATH=/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin:/usr/local/sbin; export LANG=C.UTF-8; omv-salt deploy run --no-color systemd-networkd 2>&1' with exit code '1': raspberrypi:
Result: True
Duration: 4.943 ms
Changes:
file.find:
Result: True
Duration: 7.334 ms
Changes:
file.find:
Result: True
Comment: file.find: ['/etc/netplan/10-openmediavault-default.yaml', '/etc/netplan/20-openmediavault-eth0.yaml']
Duration: 4.779 ms
Changes:
file.find:
Result: True
Duration: 96.389 ms
Changes:
Result: True
Changes:
Result: True
Duration: 33.971 ms
Changes:
diff:
New file
mode:
0644
Result: True
Duration: 84.841 ms
Changes:
diff:
New file
mode:
0644
Function: cmd.run
Result: False
Changes:
pid:
10270
retcode:
1
stderr:
netplan.main()
self.run_command()
self.func()
self.run_command()
self.func()
subprocess.CalledProcessError: Command '['udevadm', 'test-builtin', 'net_setup_link', '/sys/class/net/lo']' returned non-zero exit status 1.
stdout:
Failed: 1
Total states run: 8
Estoy tratando de volver a instalar dhcpcd para al menos tener conexión vía wifi y descargar los paquetes que fallan.
Os iré informando. Gracias
